Andres131313 Posted July 31, 2014 Report Share Posted July 31, 2014 I pulled the head of my l20b today and I was shocked to see that cylinder 3 was clean. I could see the metal instead of the carbon. All of the others are caked with it. On the head cylinders 1&2 had biuld up but 3&4 were almost clean. I looked and saw the hashing of a honer on the walls but some had a ghost like wight burn mark on the side. What is going on??? Quote Link to comment
datzenmike Posted July 31, 2014 Report Share Posted July 31, 2014 Head gasket is leaking coolant into that cylinder. This is why it's so clean. Quote Link to comment
flatcat19 Posted July 31, 2014 Report Share Posted July 31, 2014 Steam is a crazy thing. Quote Link to comment
DrRocks0 Posted July 31, 2014 Report Share Posted July 31, 2014 yep that's a steam cleaned cylinder. Quote Link to comment
datzenmike Posted July 31, 2014 Report Share Posted July 31, 2014 Take a look at the old gasket... it's probably obvious where it failed. You blocked the timing chain tensioner from falling out.... right? Quote Link to comment
dr.feltersnatch Posted July 31, 2014 Report Share Posted July 31, 2014 I would assume the leaking head gasket is why you pulled the head. Quote Link to comment
banzai510(hainz) Posted July 31, 2014 Report Share Posted July 31, 2014 spark plug will be clesan also. looked like a minor issue for you. a good gasket will take care of this mostley unless head is warped. Quote Link to comment
Andres131313 Posted August 1, 2014 Author Report Share Posted August 1, 2014 Head gasket is leaking coolant into that cylinder. This is why it's so clean. O.o what?!?! Quote Link to comment
Andres131313 Posted August 1, 2014 Author Report Share Posted August 1, 2014 Take a look at the old gasket... it's probably obvious where it failed. You blocked the timing chain tensioner from falling out.... right? O.o what?!?! Quote Link to comment
flatcat19 Posted August 1, 2014 Report Share Posted August 1, 2014 ^ Lulz. Noob. http://www.amazon.com/Alltrade-648831-Nissan-Timing-Holding/dp/B0002Q8TV4/ref=sr_1_1?ie=UTF8&qid=1406864941&sr=8-1&keywords=datsun+tool 1 Quote Link to comment
TENDRIL Posted August 1, 2014 Report Share Posted August 1, 2014 so you pulled the head without reading about it, it tells you the steps in almost any book dealing with l series, and in some it gives a template or dimensions to make a chain stop, you will most likely be re timing the motor since it also looks like you are not at TDC, so expect to clean and re-seal timing cover and front of oil pan, and at this point inspect water pump, dont forget to drop oil pump bolt (i think one at least) before yanking timing cover. white burn could be detonation and probably why HG failed 1 Quote Link to comment
TENDRIL Posted August 1, 2014 Report Share Posted August 1, 2014 the more im reading this, you need to stop and get a book before you go any further. it seems like you are on a learning curve and thats fine, just try to teach yourself as much as possible before making a costly mistake(s). also just curious... did you think you could just wrap the chain back around the cam sprocket and at any ol' toof? 1 Quote Link to comment
flatcat19 Posted August 1, 2014 Report Share Posted August 1, 2014 Ahhhh....the broken timing cover. That was a fun lesson. And the guy "helping" me learned a few new, choice words. 1 Quote Link to comment
izzo Posted August 1, 2014 Report Share Posted August 1, 2014 so you pulled the head without reading about it, it tells you the steps in almost any book dealing with l series, and in some it gives a template or dimensions to make a chain stop, you will most likely be re timing the motor since it also looks like you are not at TDC, so expect to clean and re-seal timing cover and front of oil pan, and at this point inspect water pump, dont forget to drop oil pump bolt (i think one at least) before yanking timing cover. white burn could be detonation and probably why HG failed the more im reading this, you need to stop and get a book before you go any further. it seems like you are on a learning curve and thats fine, just try to teach yourself as much as possible before making a costly mistake(s). also just curious... did you think you could just wrap the chain back around the cam sprocket and at any ol' toof? Helpful, constructive criticism. Rare these days. Good on you man! Tendril is right. Read read read read read, and read more.. then read again. But, we're here to help :D Quote Link to comment
datzenmike Posted August 1, 2014 Report Share Posted August 1, 2014 It doesn't have to be at TDC but it sure helps if something goes wrong. Well it all has to come off now. Quote Link to comment
Andres131313 Posted August 1, 2014 Author Report Share Posted August 1, 2014 You guys must think I'm stupid XD I'm rebiulding the whole damn thing! I just got it back from the machine shop! Trust me I have read that book all year. I know it's not set to TDC I did that so I could pull the crank and pistons. This is not my first rodeo. Lol 1 Quote Link to comment
izzo Posted August 1, 2014 Report Share Posted August 1, 2014 well then.... Where do we go from here :| :rofl: Get to building sucka fish! Quote Link to comment
TENDRIL Posted August 1, 2014 Report Share Posted August 1, 2014 lol well great thats good to here however on my second rodeo i wouldn't be pulling pistons, and replacing pistons and checking clearances laying on my back. as it seems thats what you will be doing but it seems you have it under control Quote Link to comment
TENDRIL Posted August 1, 2014 Report Share Posted August 1, 2014 Take a look at the old gasket... it's probably obvious where it failed. You blocked the timing chain tensioner from falling out.... right? O.o what?!?! this is all that scared me Quote Link to comment
Andres131313 Posted August 1, 2014 Author Report Share Posted August 1, 2014 I put the chain like that because it was late and I was going to take everything off the next day anyway. But thanks guys! Oh by the way I made my own chain holder Quote Link to comment
Andres131313 Posted August 1, 2014 Author Report Share Posted August 1, 2014 More like my 3rd. I normally rebuild Chevys...real men own Chevys and a datsun. Quote Link to comment
datzenmike Posted August 1, 2014 Report Share Posted August 1, 2014 I pulled the head of my l20b today and I was shocked to see that cylinder 3 was clean. I could see the metal instead of the carbon. All of the others are caked with it. On the head cylinders 1&2 had biuld up but 3&4 were almost clean. I looked and saw the hashing of a honer on the walls but some had a ghost like wight burn mark on the side. What is going on??? You guys must think I'm stupid XD I'm rebiulding the whole damn thing! I just got it back from the machine shop! Trust me I have read that book all year. I know it's not set to TDC I did that so I could pull the crank and pistons. This is not my first rodeo. Lol Your first post says nothing about your plans to bebuild. We see all kinds of stupid shit here. More like my 3rd. I normally rebuild Chevys...real men own Chevys and a datsun. .... and a drum of RTV. 1 Quote Link to comment
