laotsu Posted May 22, 2014 Report Share Posted May 22, 2014 Rubbish! Good on any 4 cylinder L series. On the L16 it does drop the compression slightly unless it also includes the SSS pistons. It (the 219 head) has monster size valves and ports for extreme RPM breathing. On an L18 the compression jumps to 9. On an L20b it jumps to 8.9. The benefits of a closed chamber head are best realized if you also have flattop pistons. Any dish defeats the purpose some. I had no idea I was mistaken, so is it just the rarity that makes the 219 peanut so sought after? Why not just increase the valve size on any other peanut? Quote Link to comment
datzenmike Posted May 22, 2014 Report Share Posted May 22, 2014 Sure, you could replace with larger valves. The 219 has cast in larger ports and some heads may not survive porting them out that much and the 219 probably could be ported out even more. It also comes with an SSS cam upgrade similar in specs to the L20B stock cam. Larger ports only benefit extreme RPM air flow and in many cases are not that good for the street. 1 Quote Link to comment
jimmy billy Posted May 22, 2014 Author Report Share Posted May 22, 2014 Ok so the Lz22 sounds great but you were saying that its not a easy build... what if i go with a L20 and stick my head on that? I think i can get my hands on one of those. And what about using the z car pistons? Would they work with the L20? And i was going to rejet 1000cc bike carbs and throw them on my engine. Ill probobly have to jet them for a 2L then. Quote Link to comment
Sealik Posted May 22, 2014 Report Share Posted May 22, 2014 Ok so the Lz22 sounds great but you were saying that its not a easy build... what if i go with a L20 and stick my head on that? I think i can get my hands on one of those. Easy...and well documented 9 holes in Felpro HG 7 in Z22S block That's it...then slap your 219 on it Quote Link to comment
datzenmike Posted May 22, 2014 Report Share Posted May 22, 2014 The parts and build is close to the same cost for any L or Z series motor. You don't have to go crazy (but you can) by rebuilding a stock Z22 engine and simply putting that 219 head, intake and exhaust on it. Find an L20B and get everything forward of the block.... (timing cover, chain, oil pump, dizzy, guides what ever) and put on the front. Add your L16 oil pan and likely the engine brackets and mounts and you have a 2.2 L series motor. Makes respectable power and lots of torque. Not rocket science, all parts are Nissan and easy enough to search out and collect. Byron from The 510 Realm made a 2.2 with an unknown cam and some side drafts. Here's the dyno sheet when EFI was added. It only made 4-6 more HP over the carbs.... Quote Link to comment
jimmy billy Posted May 22, 2014 Author Report Share Posted May 22, 2014 Thats prity good :-) Quote Link to comment
jimmy billy Posted May 22, 2014 Author Report Share Posted May 22, 2014 Alright...lets say i get it all and make this motor. You say the tranny mite not handle the power. But it will bolt up after i build the motor right? And if that tranny is no good do i swap to a 5speed out of a.......? Quote Link to comment
laotsu Posted May 22, 2014 Report Share Posted May 22, 2014 are we being trolled by Lou? Quote Link to comment
ggzilla Posted May 22, 2014 Report Share Posted May 22, 2014 Let's say swap a good used S14 5-speed in there ... and the stock motor with 154 HP ... is that good? Then you can sell that 135 HP head you have now and pay for the 5-spped. Quote Link to comment
datzenmike Posted May 22, 2014 Report Share Posted May 22, 2014 You could, but everything has now become more expensive and difficult. Nothing 'bolts in'. 1 Quote Link to comment
jimmy billy Posted May 22, 2014 Author Report Share Posted May 22, 2014 Let's say swap a good used S14 5-speed in there ... and the stock motor with 154 HP ... is that good? Then you can sell that 135 HP head you have now and pay for the 5-spped. You know i coulda had the hole swap for $500 but i turned it down and sent it to my wifes cusin for his 510 race car. I want to stay old school for this car. Everyone these days go the easyer rout and swap a ka or sr into their dime. I want to build my car not to be like everyone else and have something that when i open the hood the real datsun guys go holyshit! And cant take their eyes off of it. Quote Link to comment
jimmy billy Posted May 22, 2014 Author Report Share Posted May 22, 2014 I would but photobucket isnt running right now. I just tryed. But you can see pics of the motor in my car in project datto under my first 510 resto <3 Ive got a pic ove the front of the head showing 219 but i cant load it onto this page. It says it tho i looked 3 times to make sure that i was reading it right. Quote Link to comment
flatcat19 Posted May 22, 2014 Report Share Posted May 22, 2014 You could c/p the link. Quote Link to comment
jimmy billy Posted May 22, 2014 Author Report Share Posted May 22, 2014 Or i can text or email it to someone and they can post it. Just pm me it insted of posting it on here. Quote Link to comment
ggzilla Posted May 22, 2014 Report Share Posted May 22, 2014 Looks like a 219 head to me. Even has the 510 valve cover Quote Link to comment
jimmy billy Posted May 22, 2014 Author Report Share Posted May 22, 2014 Anyone have a pic of the number on the head? Then i can say ya thats it haha Quote Link to comment
Tristin Posted May 22, 2014 Report Share Posted May 22, 2014 Uh the number on the head will say 219... Quote Link to comment
banzai510(hainz) Posted May 22, 2014 Report Share Posted May 22, 2014 WTF!!!!!!!!!!!!!!!! just get a l20 use the L16 mounts and the oil pan. Use the 200mm flywheel Use a roadster clutch. if 225mm flywheel use a 620 clutch and T/O bearing and sleeve. Quote Link to comment
laotsu Posted May 22, 2014 Report Share Posted May 22, 2014 now go look at the bottom of the head between the first and second plug.... is there a number there? I think some A87 heads had a 219 at the front. Quote Link to comment
jimmy billy Posted May 22, 2014 Author Report Share Posted May 22, 2014 I took a quick peek this morning and didnt see anything. Ill clean off the grease when i get home. Quote Link to comment
jimmy billy Posted May 22, 2014 Author Report Share Posted May 22, 2014 So does this mean its a A87 or a 219??? I did not see the A87 stamped on it this morning. Is it still a good headn and i guess o wont know if its open or closed unless i pull the head off. And last question...does this head have the sss cam?? Quote Link to comment
