Yealla510 Posted May 1, 2014 Report Share Posted May 1, 2014 1971 521 stock wiring . When try to turn off tje truck stay on .. Quote Link to comment
wayno Posted May 1, 2014 Report Share Posted May 1, 2014 It's likely the fuse block, mine did the same thing, and it was the fuse block, heater fan stayed on also. Quote Link to comment
datzenmike Posted May 1, 2014 Report Share Posted May 1, 2014 Have you replaced the alternator??? Quote Link to comment
EastBay521 Posted May 1, 2014 Report Share Posted May 1, 2014 alternator has been replaced along with the engine.but its been doing it ever since he got the truck like 2 years now? Quote Link to comment
ggzilla Posted May 1, 2014 Report Share Posted May 1, 2014 Wrong alternator can cause the engine to keep running. Does the alternator have F N on the back, or L S ? Quote Link to comment
wayno Posted May 1, 2014 Report Share Posted May 1, 2014 Pull all the fuses, does it keep running? Quote Link to comment
EastBay521 Posted May 1, 2014 Report Share Posted May 1, 2014 I don't think weve tried that yet.not sure about the alternator either he will have to chime in or ill check tamoro when I go over there Quote Link to comment
banzai510(hainz) Posted May 1, 2014 Report Share Posted May 1, 2014 unplug the volt reg then sut off. Heard of bad volt reg but if wrong alternator that could be it also Yeallas if your alternator has the black cage in back then its the stock alternator and most likely the volt reg. get a solid state volt reg. Quote Link to comment
Trashdatsun Posted September 17, 2014 Report Share Posted September 17, 2014 did replacing the voltage reg work? Quote Link to comment
