hippieswithguns Posted April 3, 2014 Report Share Posted April 3, 2014 torque specs on a flywheel for L16 motor Quote Link to comment
ggzilla Posted April 3, 2014 Report Share Posted April 3, 2014 90 ft. lb. torque at the flywheel 96 horsepower at the flywheel Rear-wheel measurements are about 25% less Quote Link to comment
hippieswithguns Posted April 3, 2014 Author Report Share Posted April 3, 2014 Thanks ggzilla Quote Link to comment
datzenmike Posted April 3, 2014 Report Share Posted April 3, 2014 torque specs on a flywheel for L16 motor 101 to 116 ft lbs. on all 5 bolts any order. Quote Link to comment
dr.feltersnatch Posted April 3, 2014 Report Share Posted April 3, 2014 turn them till they strip and back off half a turn. 2 Quote Link to comment
jvb5577 Posted April 3, 2014 Report Share Posted April 3, 2014 I used an air gun with about 180 psi going to it.. worked well :lol: 1 Quote Link to comment
TENDRIL Posted April 4, 2015 Report Share Posted April 4, 2015 Torque specs on ka de flywheel bolts? Quote Link to comment
505plus5 Posted April 4, 2015 Report Share Posted April 4, 2015 I'll be working on my L16 head soon... Torque specs on an L16 bolts, guys? Thanks! Quote Link to comment
shacks510 Posted April 4, 2015 Report Share Posted April 4, 2015 I'll be working on my L16 head soon... Torque specs on an L16 bolts, guys?Depends what head bolts you use. Stock ones are 45 ft lbs; ZX turbo ones (recommended) are 65 ft lbs. Head bolts are a stretchable item, so they can only be used safely so many times, and it's hard to know how many times they've been torqued, unless you bought them new and kept track of how many times they've been torqued; or by measuring them (I don't know specs). I think it was around $50 to buy turbo head bolts from a Nissan parts website online. Online will almost always be cheaper than going to the dealer. ZX Turbo long x4 # 11059-P7600 ZX turbo short x6 # 11056-P6700 1 Quote Link to comment
datzenmike Posted April 4, 2015 Report Share Posted April 4, 2015 L series are not the 'torque to yield' type used later or today. They can be reused over and over if not damaged. L series head bolt torque is 47 to 60 ft. lbs. 1 Quote Link to comment
shacks510 Posted April 4, 2015 Report Share Posted April 4, 2015 L series are not the 'torque to yield' type used later or today. They can be reused over and over if not damaged. L series head bolt torque is 47 to 60 ft. lbs. Oh. Good to know. Another $50 I don't have to spend. 1 Quote Link to comment
Laecaon Posted April 4, 2015 Report Share Posted April 4, 2015 But the head bolts do have different part numbers by engine model for the most part. That said I have torqued L16s to 55ftlb and l18s and l20s to 60ftlb without problem. 1 Quote Link to comment
datzenmike Posted April 4, 2015 Report Share Posted April 4, 2015 11056-21000 was the 127mm short head bolt for the L16. This part number was superseded in April '71 to 11056-P3000 and was used on the L16 and all L18 and L220B engines through '80. 11056-21000 was used on the L24. 11056-3000 was used on late L24 engines and all L26 and L28 engines even in the 280zx non turbo. It's just a different part number for the same thing. Note: the 280zx turbo used a different bolt and number 11056-P7600 Note: I didn't bother with the 157mm long bolts but some thing applies. 1 Quote Link to comment
HRH Posted April 5, 2015 Report Share Posted April 5, 2015 Just buy the damn ARP head stud kit. Worth it's weight in gold!! - That's how I really feel! :) 1 Quote Link to comment
uberkevin Posted April 5, 2015 Report Share Posted April 5, 2015 I agree with HRH ^^ Quote Link to comment
ggzilla Posted April 5, 2015 Report Share Posted April 5, 2015 Its weight in gold is $16,000. Is that really how you feel? 1 Quote Link to comment
HRH Posted April 5, 2015 Report Share Posted April 5, 2015 That's not what gold is worth! You're calculating it wrong. Quote Link to comment
ggzilla Posted April 5, 2015 Report Share Posted April 5, 2015 Gold is $1200 per oz. Ten studs x 1.2 oz each Hey you are right, it should be $14,400 2 Quote Link to comment
HRH Posted April 5, 2015 Report Share Posted April 5, 2015 :rofl: But isn't that Troy ounces? Which are different than regular ounces. In fact, the online calculator says 1.2 regular ounces is actually 1.09375 troy ounces, which is measured for silver or gold. So it's 13,125 actually. :D 2 Quote Link to comment
505plus5 Posted April 6, 2015 Report Share Posted April 6, 2015 Thanks you guys! You were all helpful. Now the thing is, WHERE I can find PLATINUM bolts for cheap!!! Lol!!!!! Quote Link to comment
