ohmrchristopher Posted March 18, 2014 Report Share Posted March 18, 2014 This is a mix of questions about the mounting of the door cards rather then the cards themselves. Below is the final result, my question is: Where the screws are around the perimeter, is that the stock 510 mounting hole? For a fir tree or other body clip? If so then I will mount mine in the same holes so I am not drilling into the door a whole bunch. Also the pull strap, is that where the stock arm rest is? If I bought there billet handles I think the would be smaller than the 620 arm rests. So I would have to mouth those differently too. I ask this because I am making my own cards for my 620 and the way the door card mounts is a little different. If anyone has a picture of a stock 510 2 door, door card to compare that would be nice. Thanks Quote Link to comment
q-tip Posted March 18, 2014 Report Share Posted March 18, 2014 some of those holes are stock mounting holes for steel clips, its been a while since I've had my door card off to know if all of the holes are there Quote Link to comment
ohmrchristopher Posted March 20, 2014 Author Report Share Posted March 20, 2014 Ok cool, it looks like it picks up on the factory holes, no mounting tabs or weird stuff is used. I will do the same. Does the stock 510 door car have an armrest? Can I get a picture of a stock one for comparison? Thanks. Quote Link to comment
q-tip Posted March 21, 2014 Report Share Posted March 21, 2014 yes they do have arm rests, I don't have a picture butnim sure someone does Quote Link to comment
KlassicMotion Posted March 21, 2014 Report Share Posted March 21, 2014 Does the stock 510 door car have an armrest? Can I get a picture of a stock one for comparison? Maybe this will help a little: http://community.ratsun.net/topic/56424-arm 1 Quote Link to comment
KyushaKai Posted April 8, 2014 Report Share Posted April 8, 2014 The OEM cards have those push clips to hold the cards in. My friend has T3 door cards for his TE72 Corolla and his are held on by self tapping screws, so IDK if the T3 cards for the 510 require extra holes to be drilled. Quote Link to comment
yellow510 Posted April 9, 2014 Report Share Posted April 9, 2014 based on the pictures above, it looks like new holes need to be drilled. if you look at the screw right next to the door striker and latch, the screw is slightly lower than the original hole. i doubt that T3 supplies hardware big enough to use in the factory holes. the factory panels mounted with metal compression clips that fit into rubber/plastic cup inserts. (at least thats what i found on my doors.) the other door hardware like handle, window crank, and door release should all line up. there are a couple of options: 1. the factory panel mounting holes will accept the plastic fasteners that are used on a lot of newer cars for bumpers, interior panels, etc. but this will require drilling new holes into your T3 panels. 2. drill new holes in your door to mount the T3 panels. they will be close to the original hole positions, but not exactly. it would have been nice if T3 made them to line up with the factory holes where we can use some sort of insert to accept standard hardware. it would also have been nice if there was a provision for the upper handle too, but I suppose not everyone wants that and probably drill it themselves. Quote Link to comment
KlassicMotion Posted April 9, 2014 Report Share Posted April 9, 2014 Just a thought, but it would be easy enough to just buy your own plastic door boards, cut your own pattern out, and drill your own holes. Quote Link to comment
ohmrchristopher Posted April 10, 2014 Author Report Share Posted April 10, 2014 Check my build thread: http://community.ratsun.net/topic/41321-1973-620-low-and-slow-progress-new-oics-march-28/page-9 I made some myself. Easy peasy. The blind well nuts will fit in to the factory hole. 8-32 machine screw with a Allen button head. done deal. 1 Quote Link to comment
ohmrchristopher Posted April 10, 2014 Author Report Share Posted April 10, 2014 Oh I E-Mailed T3 about the billet door pulls, the eye-to-eye of the pulls go from 5" to 7.5" and the Milstraps are 6.75" eye-to-eye but can be cut to fit. I may go this way or make something. I much more like making my own stuff. Quote Link to comment
yenpit Posted April 12, 2014 Report Share Posted April 12, 2014 If you made your own panels, patterned after a stock board, you could buy some black plastic clean rounded head fir-tree push in clips (NAPA or any good upholstery shop etc etc), that would go "thru" the new panel into the OEM holes, even retaining those OEM soft rubber "inserts" (still available from Nissan) that are pushed into the holes in the door. You would see the clean rounded head of these clips once installed, but you can't really see black on black anyway! The plastic fir-tree clips are a l'il tricky to remove if you need to go back into the door, often breaking upon removal. Those trim screws are quick & easy, AND they are also available in black anodize, so you can't see them as well as the chrome ones. Quote Link to comment
