wobble Posted September 18, 2016 Author Report Share Posted September 18, 2016 Thanks for that, that's awesome. How did you go with the radiator, it looks like I'll need to do some mods might need to remove the metal shroud and run an after market rad. The 620 had removed the fan and added an electronic fan to the front. 1 Quote Link to comment
Charlie69 Posted September 18, 2016 Report Share Posted September 18, 2016 There is all the info on my build in my build thread. The main problem I had with my 520 and fitting the L20B is that the distance from the 520 firewall to the radiator support is 5" less than your 521. You should be able to fit the 521 radiator in but you will have to have I believe the upper radiator hose moved to the other side. http://community.ratsun.net/topic/9197-charlie69s-66-520-build/ 1 Quote Link to comment
wobble Posted September 19, 2016 Author Report Share Posted September 19, 2016 That's great, I'll have a good read of it. That's going to help me a lot 1 Quote Link to comment
mrbigtanker Posted September 19, 2016 Report Share Posted September 19, 2016 Thanks mate Trying to find a long wheel base tub in Australia has been impossible. I've found a couple but with freight cost of over $1000 I had to let them go No mate keep it it looks good, you made me a better man. 2 Quote Link to comment
wobble Posted October 4, 2016 Author Report Share Posted October 4, 2016 I have to add a couple of things to the list after the weekend. I went for a sneaky drive up the road and back and it runs like shit. Coughing and popping all the way, I'm thinking the dizzy is the problem and I'm looking for an electronic dizzy for the J15 to swap it out. The brakes were shit locking up at the drop of a hat but they have not been adjusted yet so that can be fixed. The front suspension is rock hard and bouncing all over the place, I think lowering it has compressed the shocks too much and they have no travel. The fuel and engine temp gauges are not working, I'll need to look into that. On a positive the clutch worked well. 1 Quote Link to comment
Elkie Posted October 9, 2016 Report Share Posted October 9, 2016 Did you make that rocker panel? Looks good. 1 Quote Link to comment
wobble Posted October 12, 2016 Author Report Share Posted October 12, 2016 I had the centre section bent up at z local metal shop but I had to hand make the ends, it's not perfect and you wouldn't want to compare one side to the other but fuck it it will do 1 Quote Link to comment
wobble Posted October 28, 2016 Author Report Share Posted October 28, 2016 Great day today. 2 years 8 months and 7 days after I purchased it I have now registered it and it's on the road. Super happy with getting it done, I still have a couple of little things to finish off, and its at the mechanic tuning in the carby and brakes I should get it back on the weekend 2 Quote Link to comment
wayno Posted October 29, 2016 Report Share Posted October 29, 2016 Did they let you keep your solid steering column, I have heard guys over there talking about them needing a collapsible type column. 1 Quote Link to comment
wobble Posted October 29, 2016 Author Report Share Posted October 29, 2016 yep no problem, if it was fine when it came off the show room floor they have to pass it. might not be the best idea 1 Quote Link to comment
wayno Posted October 29, 2016 Report Share Posted October 29, 2016 Well that benefits you, as it is a pain in the ass to change over unless you put a different front clip on the frame, and that's a pain in the ass also. I have heard of guys that cut there column down at the steering gear, and then making some kind of connection that accepts a collapsible column, never seen one done myself in person. 1 Quote Link to comment
Charlie69 Posted October 29, 2016 Report Share Posted October 29, 2016 Congrats Wobble! If you have any questions while reading through my build thread please ask. Quote Link to comment
wobble Posted October 31, 2016 Author Report Share Posted October 31, 2016 I got to take the car for a drive this weekend for the first time for real, it went well didn't over heat no major leaks breaks worked fine so happy with that. I really enjoy it. I wasn't super happy with the clutch pedal, it wasn't very smooth when releasing the clutch not real sure why it was like it needed greasing just not moving smoothly 1 Quote Link to comment
wobble Posted November 7, 2016 Author Report Share Posted November 7, 2016 So the clutch slave popped and I replaced it, it's working much better it was also missing a spring from the slave to the actuator arm. 1 Quote Link to comment
Stoffregen Motorsports Posted November 7, 2016 Report Share Posted November 7, 2016 Are you sure it has an adjustable slave on it? If it doesn't have the hole in the arm or the adjustable rod, it's probably a self adjusting slave, in which case, you don't need the spring. 1 Quote Link to comment
wobble Posted November 19, 2016 Author Report Share Posted November 19, 2016 I'm still having clutch problems, after the car has wormed up, I'm finding the the clutch pedal is getting stuck on the floor. I was wondering what brake fluid I should be using. Currently it's dot 4. I'm getting another slave with the correct mounting for the return spring but that has not yet arrived 1 Quote Link to comment
wayno Posted November 19, 2016 Report Share Posted November 19, 2016 It's starting to sound like the clutch rod is not adjusted properly or it's not the correct length. The only time I ever had a pedal stick to the floor is when the master seized. When the clutch slave is bottomed out, there should be around a 16th inch play between the clutch arm and the slave when adjusted properly. 2 Quote Link to comment
Stoffregen Motorsports Posted November 21, 2016 Report Share Posted November 21, 2016 How about a pic of the assembled clutch slave on the bellhousing. I'm pretty sure a simple pic there would make it obvious. 1 Quote Link to comment
wobble Posted July 31, 2017 Author Report Share Posted July 31, 2017 Hi guys, its been a while since an update, the clutch was fixed by greasing the input shaft, who knew. i still have some little issues that need working through, but for now we are rolling. Putting her to work I had the rear leaf spring reset to to lower the rear by 60mm, I might drop the rear a little more. I had to make my own hot box gasket, i'm still chasing vacuum leaks in the carbie, ill get there Ive been playing with a visor, i haven't got it to work yet I replaced the rear wheel bearing and oil seals. But I think it didn't work as well as i wanted it to. I now have grease webs coming from under the hubcap Enjoy guys 2 Quote Link to comment
datson4life Posted August 1, 2017 Report Share Posted August 1, 2017 I like it alot 2 Quote Link to comment
wayno Posted August 2, 2017 Report Share Posted August 2, 2017 That last photo is cool, it would even be cooler as a dually. 2 Quote Link to comment
wobble Posted November 3, 2017 Author Report Share Posted November 3, 2017 So ive been on the road for a year now, the old girl is running really well and i'm loving it. 1 Quote Link to comment
wayno Posted November 3, 2017 Report Share Posted November 3, 2017 You do know the 1985/86 Nissan dually axle will basically bolt right into your truck except for the brake line connections. 1 Quote Link to comment
Charlie69 Posted November 4, 2017 Report Share Posted November 4, 2017 This truck speaks volumes for what Datsun trucks were designed for, work trucks. I love the flat tray (bed) on this truck. Beautiful!!!! 1 Quote Link to comment
