Moisabamf Posted August 29, 2008 Report Share Posted August 29, 2008 i have an A15 with a thermostat in it. i get to about half on my temp gauge but in traffic, it starts to get up dangerously any suggestions on what the issue could be? also i was wondering what i could use to upgrade my radiator? any help appreciated ~mo Quote Link to comment
LAYEDOUTB2K Posted August 29, 2008 Report Share Posted August 29, 2008 what type of fan are you runnin? if its a standard clutch type, i would look into getting a bigger electric fan. Quote Link to comment
Moisabamf Posted August 29, 2008 Author Report Share Posted August 29, 2008 its direct drive, no clutch Quote Link to comment
bonvo Posted August 30, 2008 Report Share Posted August 30, 2008 electric fan will help alot and it is considered a performance upgrade also how old is the radiator? might want to look into another one im about to throw a vw rabbit one on my car we will see how it works Quote Link to comment
Moisabamf Posted August 30, 2008 Author Report Share Posted August 30, 2008 its got the stock radiator in it right now Quote Link to comment
moparvwfreak Posted August 30, 2008 Report Share Posted August 30, 2008 my 620 is doing this as well but opposite of yours. runs hot on the freeway but hella cool in town. weird. bout ready to just go rabbit, back to VW again, and slam a new rad in. and an e-fan on hte outside. a pusher if you will. Quote Link to comment
datzenmike Posted August 30, 2008 Report Share Posted August 30, 2008 its got the stock radiator in it right now Does it still have the fan shroud? This will increase the fan efficiency at low speeds and idle. Quote Link to comment
Moisabamf Posted August 30, 2008 Author Report Share Posted August 30, 2008 yes it has a fan shroud Quote Link to comment
bonvo Posted August 30, 2008 Report Share Posted August 30, 2008 sounds like the radiator thats what mine was doing when it started to go out then it got hot no matter what then i had a real problem Quote Link to comment
ggzilla Posted August 31, 2008 Report Share Posted August 31, 2008 i get to about half on my temp gaugebut in traffic, it starts to get up That's normal for a Datsun 1200. As long as it doesn't get to the H mark, it is not dangerous. It can get close to the H mark without hurting anything. You can 'fix' it by fitting a slightly larger radiator (B210 or B310 radiator), but it is not needed. Quote Link to comment
Moisabamf Posted August 31, 2008 Author Report Share Posted August 31, 2008 by comon to the 1200, do you mean A12? because im running A15 i want to make sure the engine will not heat up because i want to be able to take the car on long drives to shows and such (camby.....:D) Quote Link to comment
ggzilla Posted August 31, 2008 Report Share Posted August 31, 2008 I mean Datsun 1200 -- no matter which engine you have in it. Should be OK on a long drive, as long as it never gets to the H mark. Quote Link to comment
