datzenmike Posted May 20, 2007 Report Share Posted May 20, 2007 Was in the yard yesterday and finally!!!! there's a RWD KA truck in. The first yet seen. It's the high volume oil pump that I want out of it, but while looking around I noticed the distributor. There are a few FWD motors here but the distributor drives off the rear of the head. I don't suppose it would fit an L series would it? Quote Link to comment
Icehouse Posted May 20, 2007 Report Share Posted May 20, 2007 I new a kid who put all the ka injection on a L motor, he had a little difficulty with the distributor, he said something had to be grinded or it was bad new. Thats all I remember. Quote Link to comment
DISLEXICDIME Posted May 21, 2007 Report Share Posted May 21, 2007 I new a kid who put all the ka injection on a L motor, he had a little difficulty with the distributor, he said something had to be grinded or it was bad new. Thats all I remember. how did he do that that sounds interesting Quote Link to comment
kiznook Posted May 21, 2007 Report Share Posted May 21, 2007 I think that the FWDs were cam driven. not much chance of using the FWD dizzy, but you could probably make the RWD one work. It is just an overglorified L motor Quote Link to comment
datzenmike Posted May 22, 2007 Author Report Share Posted May 22, 2007 I think that the FWDs were cam driven. not much chance of using the FWD dizzy, but you could probably make the RWD one work. It is just an overglorified L motor They (FWD) are mounted and clamped in place between the head and valve cover and lock into rear of the single camshaft. The FWD have a totally different timing cover with internal crank driven eccentric oil pump. (Stanza) The RWD KAs have the higher out put oil pump that will fit any L and Z series motor. I removed one from a 240 sx with a rod through the block and the rotors are ground up with metal particals.(crap!) I did measure the internal rotors and they are 14% longer than the stock L/Z ones. The KA drive spindle looks similar but the distributor end has a small spline on it so you might need it, if it WILL swap. Agree, it's an over glorified L. In theory, the KA head would fit an L16. Quote Link to comment
kiznook Posted May 22, 2007 Report Share Posted May 22, 2007 in theory, it's been done. here on ozdat Quote Link to comment
Jester Posted April 1, 2008 Report Share Posted April 1, 2008 Clear the hell down to page 18 before I found it. LOL Copied from Kiz's link: you could use a ka24e rwd distributor. These basically drop in to an L or Z cover/drive, and have nissan 360/4-1long basic CAS as well as a rotor and 4 plug leads on the cap. They work with any single coil nissan ECCS system, such as the U12 ka24e (highly recommended efi setup). Quote Link to comment
