A_rod510 Posted November 29, 2013 Report Share Posted November 29, 2013 Im getting ready to hopefully buy a 411 off a guy I know but I'm planning on lowering it but I'm not sure what options of lowering I have since I haven't seen a lot of threads on it but I wanna see how is the best way of lowering is . I don't just wanna cut off the springs or if there's any swap or parts I can use off some other car . My plan is to lower it and camber it and hopefully it'll turn out the way I want . If anyone can help id appreciate it . Quote Link to comment
MikeRL411 Posted November 29, 2013 Report Share Posted November 29, 2013 A little use of the search function would have led you to the "Cars / 410/411 / Roadster springs on a 411" which goes into front springs and rear lowering blocks. Good luck, why would you want to camber it? Quote Link to comment
EricJB Posted November 29, 2013 Report Share Posted November 29, 2013 The roadster springs I used didn't fit very well. But I used them anyways. In the back I started with 3 inch blocks, but cut them down to 2 1/2 to level it out. 1 Quote Link to comment
MikeRL411 Posted November 29, 2013 Report Share Posted November 29, 2013 Good stance! Quote Link to comment
EricJB Posted November 29, 2013 Report Share Posted November 29, 2013 The 411's are deceiving since the body lines go down in the back. I just tried to make the rocker trim parallel to the ground. Quote Link to comment
MikeRL411 Posted December 3, 2013 Report Share Posted December 3, 2013 The 411's are deceiving since the body lines go down in the back. I just tried to make the rocker trim parallel to the ground. Your 411 appears to be an early model with what I call the "Droopy drawers" rear fender line. [Think a 2 year old with a load in his Doctor Dentons and you have the look] Later versions "cleaned up" the rear fender [and in the sedan the trunk] lines to a neater non-Pinin Farina and cleaner looking appearance. For example, the body creases on the rear quarter panels are much straighter and don't slump to the rear. Quote Link to comment
reza Posted July 16, 2017 Report Share Posted July 16, 2017 Your 411 appears to be an early model with what I call the "Droopy drawers" rear fender line. [Think a 2 year old with a load in his Doctor Dentons and you have the look] Later versions "cleaned up" the rear fender [and in the sedan the trunk] lines to a neater non-Pinin Farina and cleaner looking appearance. For example, the body creases on the rear quarter panels are much straighter and don't slump to the rear. I know this is an old thread, but holy shit. I have to stick up for the 410 body style, I think it's obvious that the rear quarters and deck lid are complimentary to the 410. 411 looks so-so, but the 410 was the real deal. 2 Quote Link to comment
MikeRL411 Posted July 17, 2017 Report Share Posted July 17, 2017 I know this is an old thread, but holy shit. I have to stick up for the 410 body style, I think it's obvious that the rear quarters and deck lid are complimentary to the 410. 411 looks so-so, but the 410 was the real deal. Then be prepared for water leaks around the lowered trunk lid! 1 Quote Link to comment
reza Posted July 17, 2017 Report Share Posted July 17, 2017 Then be prepared for water leaks around the lowered trunk lid! Alright, you got me :) Quote Link to comment
bananahamuck Posted July 17, 2017 Report Share Posted July 17, 2017 Trunk , wing windows , door seals,,,, it's all the same. Quote Link to comment
reza Posted July 18, 2017 Report Share Posted July 18, 2017 I know that many 410 trunks are rusted on the bottom edge, I'd still take the rusted trunk with the more elegant body line. Quote Link to comment
reza Posted July 18, 2017 Report Share Posted July 18, 2017 I just can't let Mikes very colorful description go unchallenged. Quote Link to comment
MikeRL411 Posted July 18, 2017 Report Share Posted July 18, 2017 I just can't let Mikes very colorful description go unchallenged. Fire away! I bought my 1967 RL411 new and am driving it to this day. I am VERY familiar with the Pinin Farina design defects and what Datsun did to attempt to correct them. Yokohama yes! Milan no. Quote Link to comment
reza Posted July 18, 2017 Report Share Posted July 18, 2017 Fire away! I bought my 1967 RL411 new and am driving it to this day. I am VERY familiar with the Pinin Farina design defects and what Datsun did to attempt to correct them. Yokohama yes! Milan no. Its okay to cheat on your car with the sweet body lines of a 410. Quote Link to comment
reza Posted July 18, 2017 Report Share Posted July 18, 2017 on the topic of lowering your 411, cutting 2 and a half coils is too much. I still have travel but not acceptable. will have to pick up some other coils or spacers or source roadster comp. Quote Link to comment
