camsta97 Posted November 22, 2013 Report Share Posted November 22, 2013 So ive been thinking about this for awhile now and theirs the intake, then a hole half way up and im not sure whether to pump it full of sillicone or put a cap on it because it must of done something back in the day? im just not sure what The Whole Intake The Hole Im Talking About Quote Link to comment
67_1600 Posted November 22, 2013 Report Share Posted November 22, 2013 That looks like where the heat riser would go to your air box. Your truck won't run any different whether it's plugged or not since it's not being fed warm air. The idea behind the heat riser is to get your engine to temperature faster by funneling warmer air in using heat from the exhaust manifold. There would have been a tube of some sort going from your exhaust manifold to the air box. Quote Link to comment
datzenmike Posted November 22, 2013 Report Share Posted November 22, 2013 It's to prevent carb icing in near freezing high humidity weather like freezing rain. Quote Link to comment
jrock4224 Posted November 22, 2013 Report Share Posted November 22, 2013 was expecting to see a pic of a ass or something else when I read title ...haven't seenone hooked up in a while on a datto .... get some small dryer vent type hose .....if needed...most don't Quote Link to comment
DanielC Posted November 22, 2013 Report Share Posted November 22, 2013 It depends on where you live. Southern Arizona, no big deal, do with it what you want. I live in western Oregon. My Datsun is much happier getting warn air into the engine this time of year. I have a 521, and there is a manual valve on the air cleaner snorkel, that you can put on cold or hot. Quote Link to comment
jrock4224 Posted November 22, 2013 Report Share Posted November 22, 2013 that's a nice looking cake top Daniel .. .is it pc'd Quote Link to comment
DanielC Posted November 23, 2013 Report Share Posted November 23, 2013 I took this air cleaner lid, and first put it is electrolysis, to remove the rust, then washed it, sandblasted it, primer, and paint. The paint is Dupont Centari, with hardner. 1968-69 VW Chrome Blue, but my paint supplier shaded is slightly darker Quote Link to comment
DaveyDaveDaveDave Posted November 23, 2013 Report Share Posted November 23, 2013 It's to prevent carb icing in near freezing high humidity weather like freezing rain. guessing this is a good thing to have here in western WA? Quote Link to comment
datzenmike Posted November 23, 2013 Report Share Posted November 23, 2013 Damn right. When near freezing the fuel absorbs heat from the air to evaporate. This can drop the air several degrees or more causing the water vapor to frost over the venturi and eventually cover it. You may have noticed the base of a carb with frost on it in the winter??? Anyway the venturi can't form a vacuum to suck fuel in and it runs lean. You find yourself stepping down on the gas more and more until it quits. A couple of minutes on the side of the road and it thaws out and away you go, only to quit in about a 1/4 mile. Most warm air set ups rust off over the years. My 620 was this way. I cut a Maxwell coffee can open and wrapped around the exhaust manifold. Slipped a metallic hose from a chevy stove pipe under it and wired it on. Worked like a hot damn... next summer I found a good one and put it on properly. Quote Link to comment
