akawes Posted October 14, 2013 Report Share Posted October 14, 2013 is there anything special about the nuts that go on the pivot bolts for the 510's if not what does everyone recommend using? Quote Link to comment
Ratwagon1600 Posted October 14, 2013 Report Share Posted October 14, 2013 Pivot bolts? Front control arm pins? More info pls Quote Link to comment
datzenmike Posted October 14, 2013 Report Share Posted October 14, 2013 Pivot the rocker arms sit on??? Quote Link to comment
q-tip Posted October 15, 2013 Report Share Posted October 15, 2013 You talking about where the lower control at attaches to the front crossmember Quote Link to comment
thisismatt Posted October 15, 2013 Report Share Posted October 15, 2013 Twist it, rock it, pop it, lock it. 1 Quote Link to comment
Ranman72 Posted October 15, 2013 Report Share Posted October 15, 2013 what part are we talking about picture is worth 1000 words Quote Link to comment
Ratwagon1600 Posted October 15, 2013 Report Share Posted October 15, 2013 Pivot the rocker arms sit on??? Kinda hope seeing he posted in the suspension section it wasnt an engine part, though, who knows? Quote Link to comment
akawes Posted October 15, 2013 Author Report Share Posted October 15, 2013 Lol yeah it's the bolt that connects the LCA to the crossmember. Quote Link to comment
q-tip Posted October 15, 2013 Report Share Posted October 15, 2013 I believe factory nuts are nylocks (self locking) and they're pretty thin if I remember right Quote Link to comment
Ratwagon1600 Posted October 15, 2013 Report Share Posted October 15, 2013 Lol yeah it's the bolt that connects the LCA to the crossmember. Cant post pics at the moment, but, working from left to right: 14mm nylcoc nut (generally no washer) On the right side i.e. where the groove is machined through the thread: A special washer (thicker than normal) with a chamfer in the centre to align with the chamfer adjacent to the tapered point on the pin LCA Another special washer with a tab in the centre hole which aligns with the groove in the pin 19mm (from memory) nyloc nut Pm me an email address and I can email you pic of what im talking about. Quote Link to comment
