q-tip Posted October 20, 2013 Report Share Posted October 20, 2013 Going to the link describes the part as a "rubber driveshaft support donut". No sure of fittment of this particular part, but if it doesn't fit it if doesn't fit. Quote Link to comment
Dawa Posted October 20, 2013 Report Share Posted October 20, 2013 thats the same one i bought from rockauto for my 620 never got around to installing it though.... Quote Link to comment
datzenmike Posted October 21, 2013 Report Share Posted October 21, 2013 Wow. That was a vague post. Totally deserving of it's own thread. Do you have a build thread? Start one and have all your project related questions there. Will make it much easier for you to reference later. . Yes there is this one... http://community.ratsun.net/topic/57974-new-here-finally-got-me-a-74-620/ moved two other posts there. Quote Link to comment
kevins750 Posted October 21, 2013 Author Report Share Posted October 21, 2013 Thanks, Datzenmike...I installed the new tranny this weekend, all it took was the bell swap....thanks for your help.... 1 Quote Link to comment
datzenmike Posted October 21, 2013 Report Share Posted October 21, 2013 That is good news. I've always wondered what a lock out automatic would run like on my '74 710 with L18. Quote Link to comment
kevins750 Posted October 21, 2013 Author Report Share Posted October 21, 2013 Got the tranny in and took it for a drive earlier and now I am getting some hesitation at low rpm's ....It cruises at freeway speed with no problems though.. Quote Link to comment
datzenmike Posted October 21, 2013 Report Share Posted October 21, 2013 Probably carb related Quote Link to comment
kevins750 Posted October 25, 2013 Author Report Share Posted October 25, 2013 wheels and tires off CL 195/65/15 15X7" w/720 kc mirrors 1 Quote Link to comment
KlassicMotion Posted October 25, 2013 Report Share Posted October 25, 2013 Looks good! Quote Link to comment
kevins750 Posted October 26, 2013 Author Report Share Posted October 26, 2013 I have looked and can't find a part number for the door pin repair kit....anybody got the number? Quote Link to comment
KlassicMotion Posted October 26, 2013 Report Share Posted October 26, 2013 No... But there's some on eBay.... http://www.ebay.com/itm/NISSAN-DATSUN-Truck-620-720-D21-Front-or-Rear-Door-Hinge-Pins-Bushings-x2-Pair-/221290804309?pt=Motors_Car_Truck_Parts_Accessories&hash=item3385f5b455&vxp=mtr http://www.ebay.com/itm/72-79-Datsun-620-Nissan-door-hinge-pin-kit-truck-pickup-/360475429054?pt=Motors_Car_Truck_Parts_Accessories&hash=item53ee0288be&vxp=mtr Quote Link to comment
kevins750 Posted October 26, 2013 Author Report Share Posted October 26, 2013 got my driveline center bearing on the truck today, and fixed the top hinge pin on the drivers door...took a look at the front of my truck and noticed the driver's tire had some camber to it and the passenger tire had some toe out...so I took the wheels off and saw this... drivers side------------------I removed the 3 nuts and one washer and tapped the bolt out a little.. passengers side--------------------------look like it is slightly cocked to one side looks like new bushings will be needed.. Quote Link to comment
kevins750 Posted October 30, 2013 Author Report Share Posted October 30, 2013 got the bushings in today...and lowered the stance just a tad.. Quote Link to comment
KlassicMotion Posted November 4, 2013 Report Share Posted November 4, 2013 Looks alot like the stance I'm about to do. Is that 3 inch blocks in the rear and 2 inch drop up front? Have you noticed any issues with the lack of suspension travel? Quote Link to comment
kevins750 Posted November 5, 2013 Author Report Share Posted November 5, 2013 3 in the rear for sure, and probably 2 In the front...It is a little stiff and we have some bad roads out here....but I knew that going in.... 1 Quote Link to comment
kevins750 Posted November 17, 2013 Author Report Share Posted November 17, 2013 Quote Link to comment
kevins750 Posted December 10, 2013 Author Report Share Posted December 10, 2013 SORRY FOR the links, can't get pics to show up OUT WITH THE OLD %5BIMG%5Dhttp://i141.photobucket.com/albums/r45/GOTFISH_2007/2013-12-09095900.jpg %5BIMG%5Dhttp://i141.photobucket.com/albums/r45/GOTFISH_2007/2013-12-09125817.jpg %5BIMG%5Dhttp://i141.photobucket.com/albums/r45/GOTFISH_2007/2013-12-09125826.jpg I hidden gem, awaiting it's turn %5BIMG%5Dhttp://i141.photobucket.com/albums/r45/GOTFISH_2007/2013-12-09125832.jpg Quote Link to comment
Eagle_Adam Posted December 12, 2013 Report Share Posted December 12, 2013 not even gunna undress the new one for us..... Quote Link to comment
kevins750 Posted December 13, 2013 Author Report Share Posted December 13, 2013 well just your run of the mill L20B, thought it would be more dramatic under raps...I will get some pics of it going in this weekend... 1 Quote Link to comment
kevins750 Posted December 23, 2013 Author Report Share Posted December 23, 2013 In the second picture, where does the fitting on the thermostat housing go to? Quote Link to comment
Eagle_Adam Posted December 23, 2013 Report Share Posted December 23, 2013 i normally block it off with a plug Quote Link to comment
datzenmike Posted December 23, 2013 Report Share Posted December 23, 2013 Nice matchbox dizzy... minus the matchbox. Going with an HEI module??? Run o the mill? Probably a '78 or newer. Has a '79 or newer dizzy on it. Also has the return line on the lower rad fitting. Odd but it should have a water cooled intake but it's sealed up. EGR add on manifold removed probably sealed up. Got W58 head on it? Quote Link to comment
kevins750 Posted December 23, 2013 Author Report Share Posted December 23, 2013 U67 head IIRC...Going with the HEI, had a thread about it answered by you earlier this month....Motor came out of a 74 like mine, obviously not the correct year but should work for me...I am not going to use the Weber it came with instead I will use the one I have..Mike, from reading other threads it seems you don't like headers...Should I remove this one and go with stock? Quote Link to comment
