metalmonkey47 Posted October 2, 2013 Report Share Posted October 2, 2013 Can anyone snap some detailed pictures, or provide some of the linkages on the L4 SU's, where the throttle cable connects to the linkage, and the linkage itself? In fact, as many pictures as possible would be great. I have Z car SU's on an N14 manifold that I'm getting together, I just wanna make sure I have the linkages right before I try and throw this together. Yes I've searched. Haven't found anything super helpful. Quote Link to comment
bonvo Posted October 2, 2013 Report Share Posted October 2, 2013 the 4 cyl linkage is just that linkage cables dont connect to it your gonna need to do a little welding to make a cable connect to the su linkage Quote Link to comment
flatcat19 Posted October 2, 2013 Report Share Posted October 2, 2013 Or this... I wish I had a better picture for ya. Quote Link to comment
datzenmike Posted October 2, 2013 Report Share Posted October 2, 2013 http://community.ratsun.net/user/2344-sealik/ might have some pictures. Quote Link to comment
jvb5577 Posted October 2, 2013 Report Share Posted October 2, 2013 http://community.ratsun.net/user/2344-sealik/ might have some pictures. Second this. Very helpful Quote Link to comment
Sealik Posted October 2, 2013 Report Share Posted October 2, 2013 Can anyone snap some detailed pictures, or provide some of the linkages on the L4 SU's, where the throttle cable connects to the linkage, and the linkage itself? In fact, as many pictures as possible would be great. I have Z car SU's on an N14 manifold that I'm getting together, I just wanna make sure I have the linkages right before I try and throw this together. Yes I've searched. Haven't found anything super helpful. Assuming you mean the K14 manifold.... Not sure what throttle rod (between SUs) you are going to use, but the L4 is too long. I shortened a L6 rod and had a Hitachi carb trunnion welded to it.....linkage/throttle cable pulls from bottom Cut L6....upper right L4....center Modified rod for 46SUs...lower right Heat shield... With transitional isolators....38-46mm 240Z horns.... A wibeband is a must to tune the SUs......profile the needles. Quote Link to comment
jrock4224 Posted October 2, 2013 Report Share Posted October 2, 2013 where can I get the l 4 linkage new link u have it pictured.....I am missing that push rod on the left .......on my l20 in my 521 I use a cam like the linkagae on the far left .......I am missing everything but the push rod ....oh and base gaskets ......that heat shield is beefy!!! so any ideas on where to get su parts ... I was about to start a thread.... Quote Link to comment
metalmonkey47 Posted October 3, 2013 Author Report Share Posted October 3, 2013 Thanks sealik! You're a huge help. I'm gonna have to make some measurements and get a hole saw. I'll end up blocking PCV though, I have a catch can run for everything that works great. Oh yeah and I mean K14, I was retarded and in a hurry when I typed that Only thing I'm missing is a cable pull, so I'll have to find one of those. FYI Jrock http://www.courtesyparts.com/99996-d1110-p-622287.html http://www.nissanusa.com/nismo-web/Nismo-Motorsports-Catalog-2010.pdf Looks like it's only through NISMO. I'm gonna call em and ask tomorrow probably. EDIT: NVM here you go. Hainz saved the day again. Found this link VIA 510 Realm. http://www.nissanparts.cc/cart/?pn=m-99996-D1110 Quote Link to comment
