BlackBird620 Posted October 2, 2013 Report Share Posted October 2, 2013 Would there be any advantages of putting an l16 head on a l20 block? I'd like to know the pros and cons of this thinking I've been curious if anyone has done this And if it was worth it Quote Link to comment
bonvo Posted October 2, 2013 Report Share Posted October 2, 2013 pros compression goes up cons the ports and valves are TINY restricting flow so unless your ready to drop some cash on porting it and stuffing z car valves in it its not really worth it 1 Quote Link to comment
wayno Posted October 2, 2013 Report Share Posted October 2, 2013 It actually depends on what L16 head it is, a 210 is not worth putting money into in my opinion, as mentioned they have small valves and ports, but they are also known for cracking inside the head in the oil jacket, and they start pumping oil into the radiator/water jacket. Quote Link to comment
BlackBird620 Posted October 2, 2013 Author Report Share Posted October 2, 2013 Its a 72 510 head the car might be getting scrapped so he can get a 73 620 that belonged to his great grandfather and I was wondering if it would be worth it to save the few good parts not to worried about having it refitted with bigger valves for I know a few machinists around the area that aren't rediculous on price for that kind of work of course they would be shocked to find that I'm only bringing them 1 head not 2 lots of drag cars built around here. Also would there be any benefits of putting the l20 cam on the l16 head as opposed to keeping the l16 cam Quote Link to comment
datzenmike Posted October 2, 2013 Report Share Posted October 2, 2013 A stock closed chamber L16 210 head will up the L20B's compression to 9.23. I did this back in the late 70s but gas was better. It ran fine in my L20B swapped 521 while the L20B head was out being planed. Only drove it a week or so. Probably give good low mid range economy but lack above 4K sooner. The stock L20B cam is almost identical to the L16SSS cam with way more lift. Quote Link to comment
BlackBird620 Posted October 2, 2013 Author Report Share Posted October 2, 2013 OK I'm not sure if my l20 had a stock can guy I got the truck from claimed to have had a custom cam ground for it, it did have a bit more lope than a stock l20 so I can't really say for sure if it had a cam or if it was from how the timing was set. I will more than likely get the head resurfaced and ported along with the bigger valves Quote Link to comment
banzai510(hainz) Posted October 2, 2013 Report Share Posted October 2, 2013 I use the 210 head for just get car/truck going if needed Thats about it. or just run it on a l16. But you can use it to get it running Quote Link to comment
BlackBird620 Posted October 2, 2013 Author Report Share Posted October 2, 2013 Well not really thinking about putting it in a car, rather making a yard buggy with the block and trany I have at the house. Just really searching my options want it to sound mean but not be crazy will only be used in parades and at salvage yards when getting the heavier parts motors, tranys, axles, ect. 1 Quote Link to comment
