muller27x Posted July 28, 2013 Report Share Posted July 28, 2013 It seems the only place to find a new fuse box is ebay. It seems I read somewhere on the forum that the 620 didn't use any 20A fuses, but the only 3 on ebay show a 20 in the top left position, is this correct? Are there any other places to look? or any other options? Mine is melted completely on the right side and not salvageable. http://www.ebay.com/sch/i.html?_trksid=p2050601.m570.l1313.TR4.TRC0.A0.Xdatsun+620+fuse+&_nkw=datsun+620+fuse+&_sacat=0&_from=R40 Quote Link to comment
Draker Posted July 28, 2013 Report Share Posted July 28, 2013 Sure.. post a wanted ad in the classified section here on ratsun and you'll have one on the way to you on Monday. Quote Link to comment
Justin Posted July 28, 2013 Report Share Posted July 28, 2013 I've got an extra from a 510 laying around somewhere if you're savvy Quote Link to comment
datzenmike Posted July 28, 2013 Report Share Posted July 28, 2013 Highest they went was 15 amp. Quote Link to comment
flatcat19 Posted July 28, 2013 Report Share Posted July 28, 2013 PM me. I have part of a 620 left in my yard. Fuse box present. 1 Quote Link to comment
PDX Matt Posted July 28, 2013 Report Share Posted July 28, 2013 PM me. I have part of a 620 left in my yard. Fuse box present. Sent you a PM cat! Quote Link to comment
muller27x Posted July 28, 2013 Author Report Share Posted July 28, 2013 Sorry Drake, still working to get my post count up enough to post to classifieds. Is the eBay box still compatible? I'm assuming I could just run a 15A in that headlamp 20A slot Quote Link to comment
Aibast Posted July 28, 2013 Report Share Posted July 28, 2013 go to parts store - buy modern type fuse box - connect the wires and that is it. Quote Link to comment
muller27x Posted July 28, 2013 Author Report Share Posted July 28, 2013 The issue with those is that they are a single power source. To do it correctly, I would need 2 boxes, 1 for switched power and 1 for constant. Which wouldn't be horrible, I would have available circuits in each for future accessories Quote Link to comment
datzenmike Posted July 28, 2013 Report Share Posted July 28, 2013 I believe the 25 post count was done away with over a month ago or more. Quote Link to comment
Draker Posted July 28, 2013 Report Share Posted July 28, 2013 That's what I thought too.. but I guess not. Quote Link to comment
muller27x Posted July 28, 2013 Author Report Share Posted July 28, 2013 I didn't see it in the forum rules anywhere, but I don't have an option to make a new post anywhere within the classifieds so I figured there was a post regulation. Quote Link to comment
datzenmike Posted July 28, 2013 Report Share Posted July 28, 2013 I'm checking but AFAIK the classifieds is open to all. Quote Link to comment
muller27x Posted July 29, 2013 Author Report Share Posted July 29, 2013 Ah ha! I found the button to 'Add an advert' I was using my phone while at work and the option isn't available on mobile. Now that I am home, I can see it. I may have a solution that will enable me to add additional accessories in the future without much additional wiring. The plan is to use 2 of the Bussmann 6 circuit fuse panels. One using battery/alternator power source and the other using the ignition switched source. This will allow me 4 additional ignition sourced circuits and 2 additional alternator sourced circuits to possibly add in a small amp, switch box, door poppers, etc. Is there anything I'm not thinking about that will not allow this setup to work or is this a plausible solution? Quote Link to comment
