Bad Wagon, 71 510 Goon +SR + Holset = Giggles
  • Replies 60
oh you have a hx351ve?, sweet. and your using a waste gate actuator to change the veins?, great minds think alike.
at full boost on that turbo the SR would be fine........ with ARP head studs, and connecting rod bolts, main bolts, a stand alone, a little head work, big injectors and a good dyno tune with dual knock sensors and wideband.
in other words over kill.
careful.
and on that T fitting you should be able to just put a pair of vice grips on it and twist. but remember you need to replace it or move it somewhere else, the other one is not enough, you need both.
We toyed with using a spring instead but others have used the WG with great results
As for full boost. . Im completely ok blowing this motor up as long as it does so in a rebuildable fashion lol
Yeah I can keep the portion of that vent that faces forward, but that rearward bung has gotta go...
Can you put an L fitting in instead?
WTF did you do to that truck?  My stock 01 maxes at 24PSI
You has cummins??  :thumbup:  your turbo can handle a lot more then 24psi........ hx's & hy's can easily handle into the high 30's low 40's  there are few guys who have even gotten them into the 50's on the cummins forum.  They wont last long with that much though
I am just about to turn 200k on my truck and It still has lots of get up in it.  I will more then likely need a new turbo in the next 10-20k though...... :confused:   from reading your thread, your car knowledge is far superior then mine..... I just didn't want you to think these turbos can be used all out on a 4cyl and the engine would be fine. Then I read your ok with it blowing as long as you can rebuild it somewhat!! lol
  • 6 months later...
I am ALMOST hoping it wont fit under the hood :devil:
Nah - get it to fit under there. It's a better "surprise" for everyone if they don't expect anything. You just throw down and they say "WTF". Then they can't wait for you to open the hood. I get this all the time with the MX520 and the 411 Goon, Misinformation.
Not much of an update.... ended up doing more visiting with the few buddies that came over than working
#becauserum
Front suspension removed
into the blaster for clean up
and just a picture of the work space... and DAMN SNOW,,,,
  • Like 4
