KlassicMotion Posted July 17, 2013 Author Report Share Posted July 17, 2013 Regarding the gasket, in every car I can possibly run it in, I only run Remflex exhaust gaskets. They are pricey but you will not leak unless it's your fault on installation. These things will make up some serious gap and seal hardcore. If you need a custom install and your good with a razor and punches, they also sell blank sheets. Here's the Datsun / Nissan link: http://catalog.remflex.com/category_s/50.htm I might have to try that some time. So far, so good with my Felpro gasket. Curious... they suggest 20 ftlbs of torque on this gasket. The stock torque setting is 8.7-11.6 ftlbs. It's my understanding that torque setting is all about the diameter and threads on the bolts/studs. Quote Link to comment
oldskoolvws Posted July 17, 2013 Report Share Posted July 17, 2013 20 ftlbs is their "nominal torque" for everything across the board. Quote Link to comment
oldskoolvws Posted July 17, 2013 Report Share Posted July 17, 2013 Here's some pics of the header. You be the judge (before only, not my ugly ass stuff). The collector welds are good from them though. Quote Link to comment
KlassicMotion Posted July 17, 2013 Author Report Share Posted July 17, 2013 Yeah that looks good. I should probably weld the exterior flange/tubes when I remove it to re-route the down pipe and put on a ball and socket connector. 1 Quote Link to comment
wayno Posted July 17, 2013 Report Share Posted July 17, 2013 For some reason I missed something, so I am going to ask, why was this done to the header. Here's some pics of the header. You be the judge (before only, not my ugly ass stuff). The collector welds are good from them though. Quote Link to comment
datzenmike Posted July 18, 2013 Report Share Posted July 18, 2013 For some reason I missed something, so I am going to ask, why was this done to the header. Yeah, I'm at a loss too. Individual O2 sensors for ITBs? Quote Link to comment
Stoffregen Motorsports Posted July 18, 2013 Report Share Posted July 18, 2013 Franken-header. Quote Link to comment
KlassicMotion Posted July 18, 2013 Author Report Share Posted July 18, 2013 I can't comment on the individual plugs, but I was looking at the fully welded flange plate versus the tack welded original version. Quote Link to comment
flatcat19 Posted July 18, 2013 Report Share Posted July 18, 2013 Old school stoic testing. Quote Link to comment
oldskoolvws Posted July 18, 2013 Report Share Posted July 18, 2013 Old school stoic testing. Correct. Syncronizers and vacuum are great for dual carbs, however nothing beats a wideband setup to validate everything is burning correctly, especially on the fly. I will use all three for final tuning though. 1 Quote Link to comment
EricJB Posted July 18, 2013 Report Share Posted July 18, 2013 You guys are too smart for me. I have no idea what to do with any of that electronic gadgetry. Quote Link to comment
datzenmike Posted July 18, 2013 Report Share Posted July 18, 2013 Old school stoic testing. . Smokey Unick did this back in the 60s but the holes have to be smaller and closer to the head so you can actually see the flame. This won't be good for that except for a wide band. Quote Link to comment
nerdistmonk Posted July 18, 2013 Report Share Posted July 18, 2013 To clearify: 1980 L20B Top-end performance header 2" exhaust Weber 38 DGES Matchbox dizzy 280zx trans wooo its so clean and shiny! I can see my reflection in the valve cover B) Quote Link to comment
KlassicMotion Posted July 18, 2013 Author Report Share Posted July 18, 2013 Thanks Quote Link to comment
oldskoolvws Posted July 19, 2013 Report Share Posted July 19, 2013 . Smokey Unick did this back in the 60s but the holes have to be smaller and closer to the head so you can actually see the flame. This won't be good for that except for a wide band. Thats what it is D-Mike. Wideband, all four holes. Quote Link to comment
