Will Posted July 14, 2013 Report Share Posted July 14, 2013 Do you know how the size of the Z-cars' radiators compare to the 610 radiator? It seems like the Z and ZX radiators can be had for a lot less. Quote Link to comment
zerow Posted July 14, 2013 Report Share Posted July 14, 2013 Will - I went looking myself for a radiator back when. I definitely wanted a radiator that filled the space and have some form of aftermarket support (from an existing car, not custom made). With that being said, I want to think that the stock Z radiator is shorter in height than one from a 10-series car. I chose an 810 radiator because the evolution of the 610/710 lent to the 810 over time. I can take a tape measure to my 810 radiator if needed for reference. 1 Quote Link to comment
Will Posted July 14, 2013 Report Share Posted July 14, 2013 Dimensions are always helpful! The 180B radiator being an easy bolt-in installation is great, but the Z radiators seem to cost about 100$ less, so I was curious about other options. My 710 has been running a bit hot. ...nothing drastic, but I want to get the radiator research done in advance. Quote Link to comment
datsunfreak Posted July 14, 2013 Author Report Share Posted July 14, 2013 Dimensions are always helpful! The 180B radiator being an easy bolt-in installation is great, but the Z radiators seem to cost about 100$ less, so I was curious about other options. My 710 has been running a bit hot. ...nothing drastic, but I want to get the radiator research done in advance. I know comparing the 240Z radiator to the 610, it's generally 1-2" shorter in height and about 3-4" wider. Hoses outlets are obviously spot on, but you'll be drilling some new holes in the core support and you may need to block off a bit of the radiator opening at the bottom. Quote Link to comment
