Trophy24 Posted June 23, 2013 Report Share Posted June 23, 2013 Hey guys looking for some info I can't find a clear answer for while searching the interwebz. My 69 2 door 510 is in need of some lower hinges. Pieces are missing and so are the springs. Are the LH and RH lower hinges interchangeable? I saw an eBay ad for some dude in Australia that said so. I think I have found one side new, the other side is NLA. They do look different to me, but what do I know LOL. What do you guys think? Quote Link to comment
Guest 510kamikazifreak Posted June 23, 2013 Report Share Posted June 23, 2013 Left to right are not interchangable But you can use rear hinges from a 4 dr or wagon(lower only) Quote Link to comment
Trophy24 Posted June 23, 2013 Author Report Share Posted June 23, 2013 Thanks man, I will see what I can find. Quote Link to comment
Guest 510kamikazifreak Posted June 23, 2013 Report Share Posted June 23, 2013 :thumbup: Quote Link to comment
Trophy24 Posted June 23, 2013 Author Report Share Posted June 23, 2013 Found new ones through Nissan. Thanks for the tip on the rears! Quote Link to comment
Guest 510kamikazifreak Posted June 23, 2013 Report Share Posted June 23, 2013 Sweet :thumbup: Quote Link to comment
danfiveten Posted June 23, 2013 Report Share Posted June 23, 2013 I hope their the right ones form nissan, because from last i checked they were NLA for all 510 hinges. Quote Link to comment
banzai510(hainz) Posted June 24, 2013 Report Share Posted June 24, 2013 YOu dont need the spring or that little arm deal to replace the bushings. Quote Link to comment
Trophy24 Posted June 25, 2013 Author Report Share Posted June 25, 2013 So ya I got the email today. None in stock : P I will see what I can do with mine when the car comes back from media blasting. Thanks for the info guys! Quote Link to comment
danfiveten Posted June 25, 2013 Report Share Posted June 25, 2013 You can find a place to rebuild the old ones. Quote Link to comment
danfiveten Posted June 25, 2013 Report Share Posted June 25, 2013 Hope this helps. http://community.ratsun.net/topic/18773-fix-510-door-hinges/ Quote Link to comment
Trophy24 Posted June 25, 2013 Author Report Share Posted June 25, 2013 Thanks, I found that info and will be doing that repair to the upper hinges. I am missing parts from the lowers so was looking for replacements. I may just run without the springs etc on the lowers for now. Thanks Quote Link to comment
hobbes_the_cat Posted June 25, 2013 Report Share Posted June 25, 2013 The springs for all the hinges are the same as far as I could tell, and I used the arms from a passenger hinge to fix my drivers side. The main problem for me was the pins for the arms were sheared off, so I used hinge pins for a typical house door from Home Depot. The heads are almost exactly the same size and the shaft is a little larger in diameter. I used a grinder to turn down the pin to the right size, cut the length to fit, and pressed em in with a vice. Had to rebuild all the hinges on my goon this way and they work great. :ninja: Quote Link to comment
