robopineapple Posted May 13, 2013 Report Share Posted May 13, 2013 i believe my vacuum distributor advance is busted. i would like some help finding the exact part that i need. here are some pictures of the part numbers on the vacuum. i looked them up but i couldnt find what i was looking for... and here are some numbers that i pulled from my carb if it helps. im useless when it comes to figuring shit out on my own. thanks fellas! Quote Link to comment
john510 Posted May 13, 2013 Report Share Posted May 13, 2013 Look on the distributor body itself,underneath the vacuum canister.Its probably covered in grime and you arent going to see it if you dont clean it.There will be a number and it usually starts with a D.The picture you put up is not the vacuum canister but the ignition module.The Nissan dealer should be able to get that part. Quote Link to comment
robopineapple Posted May 13, 2013 Author Report Share Posted May 13, 2013 i was just taking pictures of numbers that i can find around the vacuum canister. i didnt see any under but ill go clean and look. thanks Quote Link to comment
datzenmike Posted May 14, 2013 Report Share Posted May 14, 2013 The distributor part number starts with 22100- ????? and is stamped on the side of the aluminum case. If you give me the number I can get the vacuum advance number for it. Quote Link to comment
robopineapple Posted May 14, 2013 Author Report Share Posted May 14, 2013 22100B9802. the number above that one (if needed) is D4K8-08 9302. thanks Quote Link to comment
datzenmike Posted May 15, 2013 Report Share Posted May 15, 2013 22100B9802. the number above that one (if needed) is D4K8-08 9302. thanks . L20B for '79 620 truck Federal and California manual.... Vacuum advance control.... 22301-N5800 about $50 at the dealer (ouch) If looking in the junk yards it was also used on the '79 manual 200sx, A10 , 1 Quote Link to comment
robopineapple Posted May 15, 2013 Author Report Share Posted May 15, 2013 . L20B for '79 620 truck Federal and California manual.... Vacuum advance control.... 22301-N5800 about $50 at the dealer (ouch) If looking in the junk yards it was also used on the '79 manual 200sx, A10 , rock on! thank you so much Quote Link to comment
Just Joel Posted May 15, 2013 Report Share Posted May 15, 2013 Hey Mike, what part number does 22301-06w22 correspond to? Quote Link to comment
datzenmike Posted May 15, 2013 Report Share Posted May 15, 2013 Have to look it up when I get home. Send me a p/m to remind me. Quote Link to comment
datsunaholic Posted May 15, 2013 Report Share Posted May 15, 2013 06W is a 720 part type number. Quote Link to comment
Just Joel Posted May 15, 2013 Report Share Posted May 15, 2013 knowing weather or not it's a same type party is what I'm after... I have a nos factory unit that the op could potentially be interested in. Quote Link to comment
bilzbobaggins Posted May 15, 2013 Report Share Posted May 15, 2013 22301-06w22 z22 dizzy from my search Quote Link to comment
