Psycho Killer 521
  • Replies 85
Got home after work, mysterious package by the door....
NAWS!
All I need now is to find the damn 1/4 window seals. Think I'll just take a hammer to my dick instead.
Here is a link to the wingwindow seals you speak of, I found this link to work, but cannot find it in the US ebay, only the Australia ebay.
http://www.ebay.com/itm/121219473123?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
I have a set I could sell you from this guy, but you can get a set for about the same price direct from him, if you buy more than one set from him, it will likely be cheaper.
Some of you may notice that this truck is very similar to another thread and it is because they are one in the same. I am finally getting around to starting a thread of my own for this build.
I bought the truck in January from a guy who had done an SR20 install but stopped before finishing it. I picked it up and have been working on it ever since. I decided to pull the motor out and apart to put in some fresh new parts. That is pretty much where I am at this point, I've done some light body work and prepping the truck for the motor to go back in.
Mods, so far:
Engine:
Tomei 2.2 Stroker Kit, 87mm Pistions
Tomei Procams 270/270
Tomei Cam Gears
Tomei Valve Guides
Tomei 1mm Oversize Valves
Tomei Solid Lifters
Tomei Rocker Arm Stoppers
Tomei N2 Oil Block
Tomei Oversize Oil Pan
Tomei Fuel Pressure Regulator Type L
Brian Crower Valve Springs
Brian Crower Titanium Retainers
Super Tech Valve Stem Seals
Stance Water Neck Adapter
Stance Oversize Water Pump Pulley
Cometic 1.01mm Head Gasket
ARP Head Studs
ARP Main Studs
ACL Race Bearings
Nismo Thermostat
Mishimoto Oil Cooler
Aeromotive 340 Stealth Pump
Z32 Fuel Filter
Aluminum Radiator
New Water Neck
New Oil Pump/Front Cover
New Water Pump
Full Gasket Kit
New Timing Chain Kit
Bored and Sleeved Block from Darton
Port and Polished Head (Bench flowed)
3 Angle Valve Job
Powder Coated Valve Cover
Powder Coated Engine Bits
Body:
Light rust removal
Transmission tunnel cut to fit
Hood Struts
Old school wing mirrors
Rhino-Lined bed :/
18 x 8.5 Tuner style wheels
Powder Coated Grill
Powder Coated Headlight Bezels
Day 1
The teardown
mind if i ask what rims it came with ?
Mad parts ordering recently, should start coming in today. Wiring Specialties S13 harness, Splitfire Ignition Coils, ARP Flywheel Bolts, Tomei Expreme Turbine Outlet, Tomei Expreme Turbo Manifold, *SPEC Stage 3 Clutch and *SPEC Billet Steel Lightweight Flywheel. As soon as the clutch/flywheel and bolts come in then the motor is back into the truck. I'm going to wait on the Z32 transmission conversion for now. Oics when I can...
