highdesertdatsun Posted April 26, 2013 Report Share Posted April 26, 2013 I think we need to start a 520 parts thread. I searched and could not find one. so i will post the part numbers ive been using. 1. brake drum part # brake best 9110dgs from Oreillys// is threaded like a toyota drum to pull 2. front brake hardware kit 1 needed for vech part # brake best 17200 3. front brake shoes part # brake best 405 4. upper out control arm bush 1 box per side 2 bush in box moog # 9207 I need a part # for front 520 wheel studs ? I cant find jack Quote Link to comment
highdesertdatsun Posted April 29, 2013 Author Report Share Posted April 29, 2013 520 front wheel stud from napa . its got a knurl on it but fit good . pn# 641-16153take this number down , it wasnt easy to findmoog uper control arm outer bushings. i have already installed a set in my 520 Quote Link to comment
highdesertdatsun Posted May 2, 2013 Author Report Share Posted May 2, 2013 trans output shaft seal timken #3771 i havnt installed this yet nissan oem #3213607200 Quote Link to comment
XXL Posted May 3, 2013 Report Share Posted May 3, 2013 How about an oil pan gasket for the J1300? Any suggestions? Quote Link to comment
XXL Posted May 3, 2013 Report Share Posted May 3, 2013 4-speed rear seal-- Beck-Arnley #052-1328 Quote Link to comment
XXL Posted May 3, 2013 Report Share Posted May 3, 2013 Thermostat-- Beck-Arnley #143-0685 (OEM 180°) Gasket-- Beck-Arnley #039-0036 1 Quote Link to comment
highdesertdatsun Posted May 3, 2013 Author Report Share Posted May 3, 2013 complete gasket set on ebay from us. 55.0 or somtingbut make sure its not the j1500-j1800 set.im gonna buy one soon just spent all my cabage. i hope they have more. or grey silicone worksgreat too! if you get it real clean How about an oil pan gasket for the J1300? Any suggestions? http://www.ebay.com/itm/370797915722?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_1164wt_679 1 Quote Link to comment
highdesertdatsun Posted May 3, 2013 Author Report Share Posted May 3, 2013 napa part # for a japan made by tama t-stat# 154-0701 they catalog it on napa pro link napa light bulb socket for cluster # 78714 i think it will work for all places but two on cluster are offset. nippon ultra8 light blue oil filter "small" nippon # 361 0702 napa#atm3610702 throw out bearing napa #brg n1722 oe stye dist cap with all wires out ot top napa #ech-ep304 inner wheel brg napa #br30206 out wheel brg napa #br302044 wheel seal napa # nos550225 timming chain kit napa # ntp 940525 brake master napa # nmc p97032 complete rt tie rod asm napa# ncp 2695046 lft side # ncp 2695045 w/pump new napa # 42324 r diff carrier gasket napa # fpg rds55330 if i listed the part they showed to have to on locator somewhere!! even the unubtainium bearings all of above parts catalog for a 66 520 Thermostat-- Beck-Arnley #143-0685 (OEM 180°) Gasket-- Beck-Arnley #039-0036 Quote Link to comment
XXL Posted May 7, 2013 Report Share Posted May 7, 2013 complete gasket set on ebay from us. 55.0 or somting but make sure its not the j1500-j1800 set. im gonna buy one soon just spent all my cabage. i hope they have more. or grey silicone worksgreat too! if you get it real clean http://www.ebay.com/itm/370797915722?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_1164wt_679 Gasket set arrived today. Payen #FJ061 Fitment says it's for "Bluebird 411, P411, VP411, PL411, WPL411 1965-1967, A321, U520, 521, L520, L521, U620, L620 1965-Sept. 1979 Datsun J & J13 Engine 4 Cylinder OHV 1299cc" It's brand new, factory sealed, and looks like it was made about the same time as my truck! Vintage. 1 Quote Link to comment
XXL Posted May 8, 2013 Report Share Posted May 8, 2013 J13 oil sending unit (for idiot light) Intermotor #PS171 This unit has 1/8" BST (British Standard Thread) threads, and triggers at 9# of pressure. 1 Quote Link to comment
highdesertdatsun Posted May 16, 2013 Author Report Share Posted May 16, 2013 ebay sppedo cable #380639432718 fits my 520 worked perfect not to long priced at 17.00 but i made offer of 10.00 and he took it. plus 7.95 shipping. i got it in a day !!! he has 37 of them. Quote Link to comment
highdesertdatsun Posted May 25, 2013 Author Report Share Posted May 25, 2013 Anyone do the door seals on a 520 ,if so can you post info po had included one with purchase. It appeared cheap, when installed was way to thick.. I'm also unclear on the welt strip ? I think it should go on pinch weld? Around the door Opening ? But then where dose the seal mount. Thanks Sean Quote Link to comment
wayno Posted May 25, 2013 Report Share Posted May 25, 2013 The 520 and 521 are the same, the 1984 mazda B series is also the same seal, I found that certain mid 90s mazda SUVs have a seal that works great, but needs to be cut in the corner. 1 Quote Link to comment
highdesertdatsun Posted May 25, 2013 Author Report Share Posted May 25, 2013 Wow fast. What welt seal is that not used on 520 . I've seen info on the fuzzy and Chanel felt for doors but are the vent window seals made of unobtainium? Thanks Wayno Quote Link to comment
highdesertdatsun Posted May 25, 2013 Author Report Share Posted May 25, 2013 It seems the pilot bearing for a L series is the same for J series. I've bought one ,I've yet to install new/used tranny from a 66 with sincroed first gear. I'll find out then if info is correct. Any feedback would be like.thanks Quote Link to comment
XXL Posted May 25, 2013 Report Share Posted May 25, 2013 Wow fast. What welt seal is that not used on 520 . I've seen info on the fuzzy and Chanel felt for doors but are the vent window seals made of unobtainium? Thanks Wayno Funny. My wife asked me the other day if I ever opened my vent windows. I told her, "absolutely not! ... I can't afford to damage the seal because replacements are made of unobtanium" ;) Quote Link to comment
wayno Posted May 25, 2013 Report Share Posted May 25, 2013 The 520/521 wingwindow gaskets/seals show up every once in a while, but they are expensive, last set on ebay had a "buy it now" for something like $700.00 or $800.00, I don't recall the exact amount right now, but it was a stupid amount to ask, and I doubt they ever sold for that price. 620green also found quite a few sets, but he wanted $400.00 a set as I recall, but he was run off of here, so that bridge has been burnt. Everytime you go to a wrecking yard with a 520/521, you need to check the wingwindow gasket, if it is in good shape, grab it, it will be cheap considering what a new one will set you back. 1 Quote Link to comment
XXL Posted May 25, 2013 Report Share Posted May 25, 2013 if it is in good shape, grab it, it will be cheap considering what a new one will set you back. Luckily, mine are in superb shape... so I've decided never to open them, talk to them lovingly, and massage them with Gummi Pflege every once in a while... 'cuz if I have to pay $800 for replacements, I'll be using a tube of silicone caulk and duct tape. Quote Link to comment
highdesertdatsun Posted May 25, 2013 Author Report Share Posted May 25, 2013 Ah ha OK. So mine get vasoline for now. Ha ha . I'll ck that 521 at u pick it.thanks Quote Link to comment
wayno Posted May 25, 2013 Report Share Posted May 25, 2013 I truely believe that we can delete the wingwindows in our 521 doors, but it will not work with a window crank, it will only work with an electric window conversion, as the window is out of balance when using the crank. I did a little mini write up on what I did, but cannot find it now. As you can see, I tried to fab up something, but it was just out of balance using the crank. This is what it looks like stock, both sides have a significant area of side, when it is one piece the front has very little side, and therefore binds because of the balance issue, if made electric, it can be balanced when installed. 1 Quote Link to comment
highdesertdatsun Posted May 25, 2013 Author Report Share Posted May 25, 2013 That would be cool. Like VW old bug one piece winder kits. How could you get glass though? Quote Link to comment
XXL Posted May 25, 2013 Report Share Posted May 25, 2013 As you can see, I tried to fab up something, but it was just out of balance using the crank. Good work on trying to engineer a mod. I have a '69 C10 with a chopped and raked top that I did one-piece glass on. I had a similar problem with the glass wanting to tip forward, but solved it by making a small triangle in the front corner of the door (I welded it in and blended it in like it belongs there). It's only about 3" tall, but allowed me to shave off just enough glass that it no longer tries to tip forward. How could you get glass though? Since it's flat, just use laminated glass, which can be cut and ground quite easily, and still meets safety requirements. Quote Link to comment
wayno Posted May 25, 2013 Report Share Posted May 25, 2013 Good work on trying to engineer a mod. I have a '69 C10 with a chopped and raked top that I did one-piece glass on. I had a similar problem with the glass wanting to tip forward, but solved it by making a small triangle in the front corner of the door (I welded it in and blended it in like it belongs there). It's only about 3" tall, but allowed me to shave off just enough glass that it no longer tries to tip forward. Do you have a photo of the mod that fixed the glass tipping issue? Quote Link to comment
DanielC Posted May 25, 2013 Report Share Posted May 25, 2013 This should keep you busy for a while. http://www.carpartsmanual.com/datsun520/Datsun520521Index.aspx Quote Link to comment
XXL Posted May 25, 2013 Report Share Posted May 25, 2013 Do you have a photo of the mod that fixed the glass tipping issue? Quote Link to comment
