DaveZilla Posted December 29, 2013 Report Share Posted December 29, 2013 . Excellent. Thank you. Uhhh. Unfortunately this just begs the question.... Was the Z20 available with California emissions ??? I'll have to look in that chapter of the book to see...I don't remember right off hand Quote Link to comment
DaveZilla Posted December 29, 2013 Report Share Posted December 29, 2013 as a last resort you can buy the correct length and diameter carriage bolts from the hardware store, then braze them to the bed floor to keep them from spinning while you're tightening the nuts from undernieth. The reason for brazing is because you can do it with a mapp torch, propane isn't hot enough to braze, but the mapp gas will do it just fine, Quote Link to comment
nismo24096 Posted January 11, 2014 Author Report Share Posted January 11, 2014 Hey not much new on the truck at the moment, but I did find this roof rack today at the car wash next to my house, not really planning on this one, since it was too narrow and I had to remove some bolts to stretch it enough to fit. but it gives me a good visual to see if I like the look... Quote Link to comment
nismo24096 Posted January 12, 2014 Author Report Share Posted January 12, 2014 Well I finally found one, a 1982 datsun king cab truck model. I will use this to make a model of my truck. so no Its not going to be a 4x4 when Im done. I was truly amazed at how hard it is to find one of these, all you find out there are the re-released single cab versions. So anyone else done up a datsun model? if so lets see them. Quote Link to comment
nismo24096 Posted January 24, 2014 Author Report Share Posted January 24, 2014 hey I picked up a voltage and oil gauge cluster out of a 4x4 truck today, does anyone know if my 82 kingcab already has the wiring for this tucked up in the dash somewhere. or is it something I will have to add in if I want them to function?...I got the gauges and holder to fill the blank hole in the dash..but if I can get them to work that would be a plus. Quote Link to comment
wayno Posted January 24, 2014 Report Share Posted January 24, 2014 hey I picked up a voltage and oil gauge cluster out of a 4x4 truck today, does anyone know if my 82 kingcab already has the wiring for this tucked up in the dash somewhere. or is it something I will have to add in if I want them to function?...I got the gauges and holder to fill the blank hole in the dash..but if I can get them to work that would be a plus. The wiring might be deep back in there on the left side of the heater blower, but you will have to remove the dash to likely find out. Did you get the console gauge cluster pig tail(mini harness) with the gauges? Did you get the oil pressure sender off the side of the block under the intake manifold? Do you already have a console? Quote Link to comment
nismo24096 Posted January 24, 2014 Author Report Share Posted January 24, 2014 I got the console that holds the two gauges and mounts to the existing console that the shifter goes through, and no I did not get the mini pigtail but its still at the yard down the road from me so i can get that in 10 min... the motor was gone so I could not get that.. and do you have a picture of said sending unit. and thanks for the quick response. Quote Link to comment
wayno Posted January 24, 2014 Report Share Posted January 24, 2014 This is what it looks like, but this one is on the driverside on a diesel engine, on the Z22/24 engines it screws right into the block on the passenger side, it is a pain in the ass to remove, as you cannot grab it by the housing and twist, that will ruin it. Quote Link to comment
wayno Posted January 24, 2014 Report Share Posted January 24, 2014 You need that mini harness, as if you cannot find the wiring, you need the plugs to make your own harness. Also when you get it, you will see where the mini harness plugs into the main harness, and that will give you an idea where to look on your harness. Quote Link to comment
nismo24096 Posted January 24, 2014 Author Report Share Posted January 24, 2014 sorry here is a pic... Quote Link to comment
nismo24096 Posted January 24, 2014 Author Report Share Posted January 24, 2014 Thanks man, I will pick up that harness in the next day or so... Quote Link to comment
wayno Posted January 24, 2014 Report Share Posted January 24, 2014 sorry here is a pic... This is an early 4X4 console, or a 2wd kingcab console Quote Link to comment
nismo24096 Posted January 24, 2014 Author Report Share Posted January 24, 2014 2wd king cab...is what I have...i had to finesse it to fit somewhat..to fit the guages from the 4x4... but its better than the gaping hole that was there...I would have gotten the whole console but it was blue and so I just took this part and painted it to match my interior. Quote Link to comment
wayno Posted January 24, 2014 Report Share Posted January 24, 2014 2wd king cab...i had to finesse it to fit somewhat..but its better than the gaping hole that was there...I would have gotten the whole console but it was blue and so I just took this part and painted it to match my interior. The little change tray in front of the shifter hole means longshaft transmission, early 4X4s and all the 2wd kingcabs had longshafts. Quote Link to comment
nismo24096 Posted March 18, 2014 Author Report Share Posted March 18, 2014 Hey just wanted to update the tread with my progress. been trying to finish up the engine bay so I can move on to other areas. anyways here are the pics. the bay is dark bronze, the radiator is polished and high heat cleared. the valve cover is white. still need to install the new spark plug wires and hook the battery back up and mount the coils...but the wire tuck is done. 1 Quote Link to comment
Omelet720 Posted March 19, 2014 Report Share Posted March 19, 2014 Looks very clean. Did you ever get the volt and oil gauges working? I want to do the same, but I'm a bit timid with the idea. Quote Link to comment
nismo24096 Posted March 19, 2014 Author Report Share Posted March 19, 2014 Looks very clean. Did you ever get the volt and oil gauges working? I want to do the same, but I'm a bit timid with the idea. Not at this time, currently its just covering the hole that was there. Quote Link to comment
stu Posted April 2, 2014 Report Share Posted April 2, 2014 Hey, just found your thread, searching for info on wire tucks and this is the best I've found. Btw... love how this is coming along... I'm in the same position as you, I just got my first 720 and want to make it my own. I just have some questions, if you don't mind.. Where/how did you route all the wires coming off the alternator..? besides the ground I believe its 5 white wires total.. is there a way to simplify that? What all did you have to extend? Where did you end up mounting the coils? Quote Link to comment
nismo24096 Posted April 2, 2014 Author Report Share Posted April 2, 2014 The Wires coming off the alternator are in a wire loom and run into the cab right near the drain hose thats on the fire wall. this way you never really see them since its so low in the engine bay. I will have to look back at the wiring diagram to see exactly what I extended but I mainly just split the harness into two groups of wires. the ones that ran the lights ,horns, blinkers, and such all got routed outside the fender. make sure you sheild them well and use thick rubber grommets to exit the cab. and the second group of wires exit out low on the fire wall I used another grommet from a car in a junkyard that was alot smaller than our stock on. i think it was 1.75 inch. and ran the wires through it right into the alternator, transmission wires, etc. another thing I did was relocate the fuseable link that normally goes off the battery to the bolt on the starter. this puts it out of view also. and didn't effect the operation of the link. coils are going to be mounted right behind the drivers headlights. using the factory rings. mounted right to the wheel well. I will post pics once Im done. Quote Link to comment
Robert Posted April 10, 2014 Report Share Posted April 10, 2014 Wide rims and large backspacing dont work on these trucks when lowered. I have 8 inch rims with 3.5" backspacing and they stick 2" ouside the fender....you will need some serious flares to stuff them in. To fit you will need HUGE offsets. You can order them with proper spacing and they will fit fine. FWD wheels will work better. Quote Link to comment
Robert Posted April 10, 2014 Report Share Posted April 10, 2014 This is an early 4X4 console, or a 2wd kingcab console 84 ST standard cab came with that console, quarts clock, tach, and tilt std. Quote Link to comment
denman516 Posted April 10, 2014 Report Share Posted April 10, 2014 Just got this last week for $500. New exhaust pipe and muffler and it runs great. Only 70,000 original miles on it. Installed a nice audio system, now I am ready to ditch the bench seat for bucket seats. Any suggestions. Quote Link to comment
nismo24096 Posted April 10, 2014 Author Report Share Posted April 10, 2014 Nice truck. now start yourself a build thread for it..lol this ones mine. :w00t: but as far as seats go. I have Rodeo seats in mine, and early 90s 300zx seats are nice as long as they are not the power ones. 1 Quote Link to comment
denman516 Posted April 11, 2014 Report Share Posted April 11, 2014 Sorry dude I thought I did start a new thread I apoologize. Quote Link to comment
nismo24096 Posted April 12, 2014 Author Report Share Posted April 12, 2014 Sorry dude I thought I did start a new thread I apoologize. Its all good man, I was just busting your chops...lol your truck looks very good. a lot better shape than most of ours start out in.. Good luck. Quote Link to comment
