280zx strut, which lower ball joint?
  • Replies 9
Depends on what year your 510 is I believe, the 68-69 had smaller diameter studs on the ball joints 12mm vs 14mm of the 70-73. The lower knuckle/steering arm is the only part that is different.
If you have 70-73 the 510 ball joint will work. If you have 68-69 use the lower knuckle/steering arm from the zx strut assemblies and then a ball joint from a 70-73 510
