LilBullit Posted March 17, 2013 Report Share Posted March 17, 2013 Im replacing the bushings in my leaf spring, going with Super Pro. They offer a 11mm and a13mm for the front eye bushing. Which one do I need? I've been digging on datsun1200 and can't find an answer. Thx for the help 1200's!! Quote Link to comment
Guest 510kamikazifreak Posted March 17, 2013 Report Share Posted March 17, 2013 http://datsun1200.com/modules/mediawiki/index.php?title=Rear_Suspension Quote Link to comment
LilBullit Posted March 20, 2013 Author Report Share Posted March 20, 2013 Thanks for the link. Quote Link to comment
LilBullit Posted March 21, 2013 Author Report Share Posted March 21, 2013 Still no answers though, anybody on 11mm or 13mm??? I called my local nissan dealer with the part #, but he didnt know the bore size. Quote Link to comment
graveltrapp Posted March 21, 2013 Report Share Posted March 21, 2013 No way to pull a measurement off the original part? Quote Link to comment
Morrisun Posted March 21, 2013 Report Share Posted March 21, 2013 I have read this several times, and neither 11mm or 13mm are right. IF you are talking about the lower pin on the front leaf spring mounting plate it is .472" or 12mm The 2 upper pins are 0.500" and the chassis has .918" holes. The front eye in the leaf spring is 1.375". MY turn, where do you get 11mm OR 13mm out of these parts?? Quote Link to comment
LilBullit Posted March 21, 2013 Author Report Share Posted March 21, 2013 Super Pro has two listings for front spring eye bushing. One is listed with a 11mm bore size, other 13mm bore size. http://www.superpro.com.au/find-superpro-parts-for-my-vehicle/vehiclelookup/NISSAN-1200-Sedan--Utility/49-106-159 Quote Link to comment
Davec Posted March 23, 2013 Report Share Posted March 23, 2013 i would say 11mm cuz it would make it a tight fit at .433 Quote Link to comment
datsunfreak Posted March 23, 2013 Report Share Posted March 23, 2013 Why not spin the bolt out and measure it? :thumbup: Quote Link to comment
datzenmike Posted March 23, 2013 Report Share Posted March 23, 2013 And use rubber bushings. Polly are noisy, (squeak) wear out from chafing and transmit vibration and noise. Quote Link to comment
