Rat720 Posted March 12, 2013 Report Share Posted March 12, 2013 Hey everyone. Just picked up my 7th 720. It's a 85 st extended cab. Automatic trans. This is my first automatic one and was wondering if its normal for it to be this SLOW!!!?! It has a weber and I'm in the process of tuning it a bit better but it runs fine other than a flat spot right off idle, (any ideas) but its just extremely slow compared to the 5 speeds I'm used to. I plan on swapping in a 5 speed when the auto craps out but I hope that will at least be till near the end of summer. It shifts perfect just feels like it has no power. Also if anyone has a dipstick for this trans I very much so need one. So please let me know. Thanks Quote Link to comment
DREWSDIME Posted March 12, 2013 Report Share Posted March 12, 2013 Yes auto's are slow, I have an 85 xtra cab with auto and its very slow. I did not realize how slow it was until I rode in my friends with 5 speed. Good for cruising and freeway driving if you like doing 65-70mph Quote Link to comment
slemers Posted March 12, 2013 Report Share Posted March 12, 2013 Several guys I have talked to have flat spots off of idle. My 720 has it also if I set the timing @factory specs. When I bought the truck the PO had a bolt crammed into the vacumn advance line and had the timing set to 12 degrees BTDC. It didn't have the hesitation set up this way, but I am now running 5 degrees BTDC and it runs fine except for the occasional stumble below 1500 rpm or so. Quote Link to comment
SHORTDOG Posted March 12, 2013 Report Share Posted March 12, 2013 Let's see pics! :thumbup: Quote Link to comment
ryanw1 Posted March 12, 2013 Report Share Posted March 12, 2013 I also have an auto and it is much much slower than my 5 speed, But I dont have these "flat spots". Quote Link to comment
bryant2482 Posted April 14, 2013 Report Share Posted April 14, 2013 i had the 3 speed auto in mine. its shifted great but shifted way too soon. by the time i got to 25 mph it was already in 3rd. i dumped it and went with the 5 speed. much better!! Quote Link to comment
datzenmike Posted April 15, 2013 Report Share Posted April 15, 2013 The up shift is dependent on engine load and will up shift instantly where if you had a standard you could let up on the gas and cruise along in second or third and shift when YOU feel like it. It's a dumb machine and only follows a governor and shift modulator kind of logic. My 710 goes into second within a car length at light throttle and warmed up and you don't even notice it. But if you floor it from the start it goes pretty good and second is a hard bang into gear. Several guys I have talked to have flat spots off of idle. My 720 has it also if I set the timing @factory specs. When I bought the truck the PO had a bolt crammed into the vacumn advance line and had the timing set to 12 degrees BTDC. It didn't have the hesitation set up this way, but I am now running 5 degrees BTDC and it runs fine except for the occasional stumble below 1500 rpm or so.Correct timing is 3 degrees. Flat spots above idle are likely a worn out accelerator pump. This is particularly noticeable on an automatic. Quote Link to comment
