Can i get a wider wheel on a 510
  • Replies 15
Check the last page on Lazarus (linked in my signature)... I just threw -0deg offset 15x9's on it... with 195/50/15's... At first i was a bit unsure, thinking it looked kinda culturally off for a white guy to drive around... but i think its growing on me more and more... I will be pulling/chopping, and ZG flaring the fenders to fit um. check it out.. it might change your mind.
There's a lot of threads on wider/what wheels an all that is involved to fit.
Suspension upgrades to make more room and such.
280zx struts / camber plates up front for more extreme offset wheels...
Here's 15x8 (0) I have a bit more of a rolled/pulled fenders as well...
I've seen some nice set ups with 15x7's as well
(thread jack warning) what's up with this muffler?
Joel
Dat510, what tires are you running on the rear? What struts do you have in the front? I want to run 15x7 0 offset wheels as well, but I want to run 205's. My rear already has rolled fenders and don't want to modify anything else in the rear (like pull the rear fender).
