Daryl Posted February 25, 2013 Report Share Posted February 25, 2013 I need your guys wise help, for i am in a pickle! Here's the issue, I am getting a 1981 Datsun 510 with a blown z20 engine and the guy i am getting it from gave me the option to replace or rebuild. The question is can the block be removed and can a L26 be dropped in? Any help would be great. Quote Link to comment
Farmer Joe Posted February 25, 2013 Report Share Posted February 25, 2013 nah. that 4 vs 6 cylinder. the l26 is 2 cylinders longer than the z20... find another z20-22-24, and put it in... Quote Link to comment
Daryl Posted February 25, 2013 Author Report Share Posted February 25, 2013 In the end i am left with the only option of replacing the engine with the same "z" engine. I'll throw a z24 in it. thanks Farmer Joe. Quote Link to comment
datzenmike Posted February 25, 2013 Report Share Posted February 25, 2013 An L24/26/28 can be done but ruins the car. Sealik had one, swapped it back to 4 cylinder. Also the L series motor will need an L series transmission. It won't bolt (properly, that is) to the Z series transmission in the car now. I assume that you have a carb Z20? Easiest thing is a Z series motor transplant. The Z20 and Z22 are identical other than displacement. The Z24 (only found in the 720 truck and early D21 Hardbody) is 3/4" taller than the Z20/22 motors but can fit. The Z24i found in the Hardbody has fuel injection so best to swap a carb and intake on it for your use. Most stuff on the Z20/22 will fit a Z24. Quote Link to comment
INDY510 Posted February 25, 2013 Report Share Posted February 25, 2013 Did they stop doing SMOG tests in California?? .... :confused: ...... .. didn't think so ..... any motor out of ANY car sounds better than a straight six 81 510 Quote Link to comment
datzenmike Posted February 25, 2013 Report Share Posted February 25, 2013 An L20B is a good motor, but you still need to address the transmission. I assume it's a 4 speed? Quote Link to comment
Sealik Posted February 25, 2013 Report Share Posted February 25, 2013 An L24/26/28 can be done but ruins the car. Sealik had one, swapped it back to 4 cylinder. Yeah....although the bored L28 is going back in, eventually..... :hyper: Firewall is already MIA......so why not. Just have one more part to acquire...P90 or P79 head Quote Link to comment
Daryl Posted February 25, 2013 Author Report Share Posted February 25, 2013 Sadly, it has 3 spd Automatic in it. Quote Link to comment
bonvo Posted February 25, 2013 Report Share Posted February 25, 2013 your in california if you ever want to smog the thing again you need to stick to the z series you cannot go with an older engine as it is illegal and wont pass you can go newer so a z24 but not older Quote Link to comment
Daryl Posted February 25, 2013 Author Report Share Posted February 25, 2013 Dam smog! Cool, was planning to do that. Quote Link to comment
Tristin Posted February 25, 2013 Report Share Posted February 25, 2013 An L20B is a good motor, but you still need to address the transmission. I assume it's a 4 speed? For an L block, he can just swap an L front case onto the Z trans. Quote Link to comment
datzenmike Posted February 25, 2013 Report Share Posted February 25, 2013 As it turns out it's an '81 and there were no 4 cylinder L motors. Quote Link to comment
Tristin Posted February 25, 2013 Report Share Posted February 25, 2013 I thought the last year for the L20 was the '81... hmmm Edit: Years were mixed up. I see they stopped in '79. Quote Link to comment
datzenmike Posted February 25, 2013 Report Share Posted February 25, 2013 The '80 720 was it for the 4 cylinder and '84 for the six. Quote Link to comment
