Rasp933 Posted January 14, 2013 Report Share Posted January 14, 2013 Hello.ratsun I am switching to electronic distributor. I think it s a match box distributor.Will the accel coil work wit it? .cus that's what I have on it right now. Quote Link to comment
Rasp933 Posted January 14, 2013 Author Report Share Posted January 14, 2013 Do I need the stock coil to go wit it? Quote Link to comment
Rasp933 Posted January 14, 2013 Author Report Share Posted January 14, 2013 Kool Quote Link to comment
datsunfreak Posted January 14, 2013 Report Share Posted January 14, 2013 Best thread ever. Quote Link to comment
ggzilla Posted January 14, 2013 Report Share Posted January 14, 2013 The stock matchbox coil works much better than an Accel for a points-based distributor. Quote Link to comment
Rasp933 Posted January 15, 2013 Author Report Share Posted January 15, 2013 Kool guys got it to work.what should I gap the plugs at.now its at 32 I believe! Quote Link to comment
Rasp933 Posted January 15, 2013 Author Report Share Posted January 15, 2013 0.032 Quote Link to comment
datsunfreak Posted January 15, 2013 Report Share Posted January 15, 2013 Assuming this is for the 510, I would just look up the stock gap for a later EI car, maybe '78-79 200SX/truck/510? I usually just buy new NGK BPR6ES-11 plugs and toss 'em in. :rofl: Quote Link to comment
datzenmike Posted January 15, 2013 Report Share Posted January 15, 2013 The EI dizzys and coil, either remote igniter or the matchbox, has superior voltage output in addition to NOT having points in them. Not much sense having extra voltage available if you don't take advantage of it. The points dizzy will fire a 0.032" gap but the EI dizzys will fire a 0.038"-0.043" gap. This provides a longer spark to light the fire. Especially good for leaner idle and cruise mixtures. By leaner I mean closer to 14.7 to one. Often there are the odd miss or stumble trying to fire these mixtures. The Matchbox will improve or remove this. Quote Link to comment
Rasp933 Posted January 15, 2013 Author Report Share Posted January 15, 2013 Yup I don't hear any misses any more.should time it at 12degs at idle? Quote Link to comment
ggzilla Posted January 15, 2013 Report Share Posted January 15, 2013 But if you continue to use the Accel coil, set the plug gap to .032 to .034, because that coil is not high energy. Quote Link to comment
Rasp933 Posted January 15, 2013 Author Report Share Posted January 15, 2013 Or 10degrees .I have l20b Quote Link to comment
Rasp933 Posted January 15, 2013 Author Report Share Posted January 15, 2013 Its at 32 at the moment Quote Link to comment
Rasp933 Posted January 15, 2013 Author Report Share Posted January 15, 2013 What bout coils at autozone.for 26 bucks.can use dem if I wana use wider gap? Quote Link to comment
ggzilla Posted January 15, 2013 Report Share Posted January 15, 2013 Yes, this coil is for the 1978-1980 L20B electronic ignition: http://www.autozone.com/autozone/parts/1979-Nissan-Datsun-620/Ignition-Coil/_/N-imh6xZ9n80r?filterByKeyWord=coil&fromString=search And then short across the Resistor (or remove resistor and connect all three wires together). Quote Link to comment
Rasp933 Posted January 15, 2013 Author Report Share Posted January 15, 2013 K kool thanx for the infos bud Quote Link to comment
banzai510(hainz) Posted January 15, 2013 Report Share Posted January 15, 2013 What accel coil is it Super Coil? Super coils are .7ohms and do come wit a ballast in the kit. But Im unsure if you can run it w/o the ballast. or the SSuper sotck coil which is a Point SPEC based coil and shoutd run a ballast resisitor If i douht stay with the stock set up. or just buy a MSDblaster 2 coil. NO BALLAST and youll be fine and have your go faster Bling coil Quote Link to comment
datsunfreak Posted January 16, 2013 Report Share Posted January 16, 2013 Or 10degrees .I have l20b 12 degrees at idle is a good starting point. :thumbup: Quote Link to comment
Rasp933 Posted January 16, 2013 Author Report Share Posted January 16, 2013 Its accel 8140c Quote Link to comment
Rasp933 Posted January 16, 2013 Author Report Share Posted January 16, 2013 Super stock universal performance coil Quote Link to comment
Rasp933 Posted January 16, 2013 Author Report Share Posted January 16, 2013 Its a 8140c.super stock performance coil Quote Link to comment
ggzilla Posted January 16, 2013 Report Share Posted January 16, 2013 The key word is "stock" performance. Not a high-energy EFI coil. Accel says the 8104C is "for points ignition systems" Quote Link to comment
banzai510(hainz) Posted January 16, 2013 Report Share Posted January 16, 2013 That means run this coil with the stock ballast resisitor. PS the Super stock Accels are all made in China Now. You might be going backwards. Quote Link to comment
