1971 Datsun 521 Snack Shack
  • Replies 1.3k
space it out is the best way...... I am mounting two pusher fans behind the grill so making a little 3/8 spacer is easiest... then I use some door edge guard around the opening to seal the core support to the radiator...boom lifetime radiator success.....I need to finish my roadster over flow mod though.....not gonna have an temp issues now .... not that I ever did ...
  • 3 weeks later...
l20 about ready to enter the shack...
phixius sighting....me hollering ...throw a new carb on it...
now me yelling throw a new match box and coil at it....
hi going to get the crimpers to fix a wire connector gone bad.,..
spaced out radiator 3/8 of a inch.....thought about slotting so I could move it down a little .... but dont want the cap to be a pain off and on..... gonna have to cut some out of the core support for my dual pusher fans .....should still be hidden
It would be a good idea,the cap does sit close but far enough away from the hood.Post pics of your core support cut,im next.Looking good to more power here you come.
not my shop .... but mines similar at home..... but for now this will be my shop till some shit stops rolling down hill... most of my datto stuff gets worked on out here.....at least the major stuff ... I got a mazda and boat in my shop that are being worked on...
I do have this though.... new headlight on the appropriately named "assisted suicide."  bike .... got most f the bugs ....got about 600 miles on it and for u scoring at home that's barely tank of gas in my 521....
finally got my lower heater box that I powdercoated back in the truck with a working valve and handle thanks to phixius....
ok this is chronological ...l 20 is in yea!!!!!
but then .....doh!!
and to top it off I put the wrong pan on.... put a 620 pan on it and that's no bueno for steering safely...
got my radiator in and core support painted after trimming....fits nice and the fans look good as pushersu don't even see them behind the grillIMG_20130920_212827_zps1428c9b2.jpg
off to my favorite machine shop to see if they can help me with my head problem.....
u can see it in the pic .... any guesses
Heater box looks killer. And so do the fans. Not seeing the problem with the head. What am I overlooking?
Let me rephrase that. I can see pics by clicking on the links. But what I can't see is the problem you speak of with the head.
