BEEBANI Posted May 1, 2007 Report Share Posted May 1, 2007 Has anyone ever tried to bolt a brake booster from a 720 into a 620? Just curious what the size difference is. Quote Link to comment
]2eDeYe Posted May 1, 2007 Report Share Posted May 1, 2007 Good question.. How about adding the hardbody booster to the comparison list? Quote Link to comment
BEEBANI Posted May 1, 2007 Author Report Share Posted May 1, 2007 The hardbody, 240sx, and sentra all use the same size booster........huge. I have a '87 sentra booster I was going to use, but it hits the steering column and would require being about 6" from the firewall. Quote Link to comment
datzenmike Posted May 1, 2007 Report Share Posted May 1, 2007 Negative! The 720 booster is huge and sits on a pedistal 8-9" away from the firewall. There is even a dimple in the inner fender to allow this. The reason this is possible is that the Z series motors have their intake on the pass side and with only the small exhaust manifold, there's plenty of room on the driver's. The pedistal allows room for the clutch master and places the large diameter booster out in front of it. If some way could be found to move the clutch master over a couple of inches you could 'squeeze' it in, but without the long pedistal, as it would hit the stock L intake let alone the air filter. I agree it is a good question. Would love to use a 15/16 or 1" M/C but you would need a larger booster than the stock 620 one for sure. I've got 2 or 3 720, 2 '80 200sx, an '80 280Z, and at least 3 620 M/Cs all with boosters, and I'm still trying to come up with something. Did not notice clearance issues with the steering column Beebani, but it's easy to overlook. I have a 720 column in there, maybe its at a different angle. It has a U joint into the P/S unit. Quote Link to comment
BEEBANI Posted May 1, 2007 Author Report Share Posted May 1, 2007 So, you know for sure that the 720 m/c won't work on the 620 booster? I have the 720 m/c already, just trying to decide which booster to use. Quote Link to comment
yello620 Posted May 2, 2007 Report Share Posted May 2, 2007 I am using the 15/16" master from a ZX on the stock 620 booster. Bolts right on and works perfect. I have about 20k miles on it like this so far. The pedal is a little stiff, but so much better than the 13/16" stocker. I would not go to a 1" bore though. Jason Quote Link to comment
Icehouse Posted May 2, 2007 Report Share Posted May 2, 2007 Maybe you guys could get a vacuum pump off a s12 turbo, hook that up to the master instead of the intake. Maybe it would create the effect of a "bigger" booster. Quote Link to comment
datzenmike Posted May 3, 2007 Report Share Posted May 3, 2007 So, you know for sure that the 720 m/c won't work on the 620 booster? I have the 720 m/c already, just trying to decide which booster to use. Beebani your post said: Has anyone ever tried to bolt a brake booster from a 720 into a 620? Just curious what the size difference is. The 720 booster won't fit into the 620, as I said. The M/C would though. Some have vertical and some have horizontal mounting bolts onto the booster. Some have an adapter to use either. Quote Link to comment
BEEBANI Posted May 3, 2007 Author Report Share Posted May 3, 2007 I think I'll just modify it and make it fit. Quote Link to comment
datzenmike Posted May 3, 2007 Report Share Posted May 3, 2007 Check out Harshman b near the bottom, trucks section, 'brake booster into a pl 521' http://www.nwde.org/extras/forum/main.htm M/C clears the weber air filter but not a stocker. I know it's a 521 but 620 is similar. mike Quote Link to comment
BEEBANI Posted May 3, 2007 Author Report Share Posted May 3, 2007 Mike, I guess you missed the part about me having a ka24 motor? Quote Link to comment
CameronT Posted November 29, 2013 Report Share Posted November 29, 2013 So it won't clear sticker, but it will clear a weber?? Would you still have to move the clutch master? Quote Link to comment
