Wilwood pedals in a Dime. Who's done it??? Updated!
spec-bre
Starting my Wilwood pedal instal project and looking to see who has already done it. My goal is that when I am done I will have all the info needed to reproduce the parts when needed. So if you have anything to pass on the help will be appreciated!!!
1B17A2D7-8D03-47CD-8D06-DA8EFA2AAA2A-197
Water jet program
715BA004-EA2A-4EEE-958C-3CB7EB2E0DC6-221
Water jet action
BCC072A6-4B75-4CD6-A7BF-C212C3069FBD-221
35691CBE-3B48-4926-A622-21A3269A84D3-221
E2723E2A-F2C6-4AFD-AE08-F09EB75A639C-221
0E2E021E-600A-4449-9DA6-CAE9EB41D9A4-221
91549D5D-2C32-4C5C-9474-7F8AEDC8AC61-221
0557F561-185A-469A-BDD5-F1BA9D7083FE-221
87E5634F-81DA-4494-8BA9-7960353CA5B5-221
http://photobucket.com/albums/ee290/litefingers376/1972 510 racer/Wilwood pedal box instal
  • Replies 15
After a bit more cyphering I modified my main pedal bracket to allow me to straddle the column instead of both pedals setting on the left side of column. The gap was too great between the gas and brake pedal with that configuration. This will allow me the ability to "Heal Toe" if I learn how!! lol!
9BB6EB28-B78D-4C91-B306-177280A379B6-220
89B8E69E-613A-4C0E-B1E1-672A2A70BD49-220
Next item to address is the column mount. all cages are different so this might not be of any use to some or most but here is what I chose to do.
Using the stock column and machining a UHMW spacer I slid the mounting flange on the column away from the floor pan buy 1" and rotated the flange 180 degs from stock local then pulled some measurements and off to the Jet I went.
CA25257F-BF7D-4211-B51C-ACBE813107B5-220
10FFBD64-9D64-47F1-9518-16F33D71DD9E-220
C5E86A73-4B9E-4A28-B78E-606139F97F44-220
F75FC355-1EAA-4D39-ABDB-028DB085A27B-220
Next was the reservoirs.
I plan on having a Passenger seat for solo as well as needing one for license/school time when I get to the point of putting the car on track. The reason for going to the Wilwood setup in the 1st place was to remove the masters from the engine bay due to ITG breather clearance issues I was having with My 44 mm Muks. Any how here is what I ended up doing.
43A6E7D0-113D-4A0C-8B73-0583493E8D67-220
01943521-5205-481E-AA79-91F25D86043E-220
DC67B625-D95E-457C-8B7B-AA225E042C12-220
1356A3D6-7574-4FE2-B925-F41A776C89C5-220
F72C8F4B-6340-4AD0-82A5-B53342FCF075-220
DC2F66EC-F35F-4DBA-9303-0DE502E0BD3D-220
These are some old pics from my race car build three years ago. The column is just a steel rod with a quick-release steering wheel, I have always planned on going back and installing a double u-joint or some other type of collapse area, but have never gotten around to it. I've been planning an inline steering ratio reduction system (stock car style), so the collapse design has been sidelined.
I installed the same adjustable balance-bar Wilwood system you're using, it is designed for use with a cable operated adjustment knob. But once I got the front/rear balance I was looking for, I never have adjusted it further (just one more thing to distract you while racing). I'm running a 3/4" front m/c and 7/8" rear. I used an inline brake pressure gauge to adjust my bias-bar until I was getting 800psi front and 500 psi rear and have left it there.
Not shown in this photo are the bracket supports I welded in to prevent any flex. I have a vertical support above the pedals from the bracket to the rollcage, and a support under the hood from the firewall side of the bracket to the shock tower rollcage pickup point.
Good job with your fab work, the reservoir access panel is a nice touch. I cut out my whole under-dash cowl panel area, so I access my reservoirs by removing the cowl vent between the hood and the windshield, and go in from the outside. I needed the room under the hood for an airbox.
http://www.racingonthecheap.com/final-prep/
