A10's U-nite !!!!
  • Replies 4.1k
Well kids, this is it. I need a trans mount, driveline and radiator + hoses and my swap is complete.
I could have sworn someone named me offered up a radiator a while ago.
Do you need a custom driveline?
I have the one that came of my A10. Z, auto.
Why wouldn't yours work?
Only located in TRI CITIES
Thanks guys for your help.....
Originally I had a '79 A10 w/ L20 (W58) and a 4 speed M/T. I no longer have the trans or engine for reference. I do remember that the trans. shifter was NOT like the KA's trans. i.e - the KA's shifter is "internal" (at the tailhousing) and L series was 'external' if that makes sense??? maybe? no?
It does.
I just gave a 620 driveline away.
So do you have a trans for it?
The 240sx trans? Can you have the driveline cut to fit?
I have the KA24DE from a '92 240sx. I also have the correct trans for the 240sx.
The driveline is not the issue, it's the trans mount. I'm looking for a trans that's able to bolt to the KA and also bolted into the current trans mount. I do not want to spend money and timing paying someone to fabricate one, as I do not have the skills.
You need an automatic driveshaft and a Z22 or Z24 71B 5 speed that is 31.5" long. (or an L series 71B with a Z series front case swap)
Mike, would this trans apply to what I'm looking for? Mounts to the KA, and mounts to A10 chassis with no fabrication needed?
Please don't think I am purposefully trying to go cheap, but I want to do this in a correct manner and not pay hundreds to someone to fab a mounts when i could just use oem nissan and mount it in...
