mhub91 Posted November 2, 2013 Report Share Posted November 2, 2013 Well kids, this is it. I need a trans mount, driveline and radiator + hoses and my swap is complete. Quote Link to comment
mhub91 Posted November 2, 2013 Report Share Posted November 2, 2013 ....and then the fun part comes. Aero, wheels, tint, and all the dress up. I pee a little every time I think of it. 1 Quote Link to comment
flatcat19 Posted November 3, 2013 Report Share Posted November 3, 2013 Well kids, this is it. I need a trans mount, driveline and radiator + hoses and my swap is complete. I could have sworn someone named me offered up a radiator a while ago. Do you need a custom driveline? I have the one that came of my A10. Z, auto. Why wouldn't yours work? Quote Link to comment
ggzilla Posted November 3, 2013 Report Share Posted November 3, 2013 If you swap in a different length transmission, it will need a different drive shaft and mounts. There are three different length transmissions that will work. Quote Link to comment
mhub91 Posted November 3, 2013 Report Share Posted November 3, 2013 Ggzilla you're telling me there is a trans I am able to has that will require no mods at all? Quote Link to comment
mhub91 Posted November 3, 2013 Report Share Posted November 3, 2013 Not has , use Quote Link to comment
flatcat19 Posted November 3, 2013 Report Share Posted November 3, 2013 Did you keep the same size trans? If you did, no mod. Quote Link to comment
Fat510 Posted November 3, 2013 Report Share Posted November 3, 2013 I could have sworn someone named me offered up a radiator a while ago. Do you need a custom driveline? I have the one that came of my A10. Z, auto. Why wouldn't yours work? Only located in TRI CITIES Quote Link to comment
flatcat19 Posted November 3, 2013 Report Share Posted November 3, 2013 Only located in TRI CITIES So? I'm always traveling. Or can send post. So new still. Quote Link to comment
mhub91 Posted November 3, 2013 Report Share Posted November 3, 2013 I had an L series trans. That's doesn't bolt up to a KA. What's the same length as L series but would mount to KA? Hardbody napz trans? Quote Link to comment
flatcat19 Posted November 3, 2013 Report Share Posted November 3, 2013 Which L trans did you have? 4 or 5? 26" or 31" Tech like you knows how to use a tape measure? Quote Link to comment
flatcat19 Posted November 3, 2013 Report Share Posted November 3, 2013 L trans needs Z housing swapped on to bolt on. Dog leg too weak for a KA. Lots of different trans that will work. Quote Link to comment
datzenmike Posted November 3, 2013 Report Share Posted November 3, 2013 Was this an automatic? Now going to KA and you want a 5 speed for it? Too long to go back and read everything. Quote Link to comment
bananahamuck Posted November 3, 2013 Report Share Posted November 3, 2013 Automagical trans car like Flatcats will have the same driveline as longtail 620-280z trans you just need to switch bellhousings .. Quote Link to comment
mhub91 Posted November 3, 2013 Report Share Posted November 3, 2013 Thanks guys for your help..... Originally I had a '79 A10 w/ L20 (W58) and a 4 speed M/T. I no longer have the trans or engine for reference. I do remember that the trans. shifter was NOT like the KA's trans. i.e - the KA's shifter is "internal" (at the tailhousing) and L series was 'external' if that makes sense??? maybe? no? Quote Link to comment
flatcat19 Posted November 3, 2013 Report Share Posted November 3, 2013 It does. I just gave a 620 driveline away. So do you have a trans for it? The 240sx trans? Can you have the driveline cut to fit? Quote Link to comment
datzenmike Posted November 3, 2013 Report Share Posted November 3, 2013 You need an automatic driveshaft and a Z22 or Z24 71B 5 speed that is 31.5" long. (or an L series 71B with a Z series front case swap) Quote Link to comment
bananahamuck Posted November 3, 2013 Report Share Posted November 3, 2013 Couldn't he use one of those short 720 trans also?? I would think using Flats driveline and trans crossmember,,,, longer trans would be way easier to locate and probably cheaper. Quote Link to comment
mhub91 Posted November 3, 2013 Report Share Posted November 3, 2013 It does. I just gave a 620 driveline away. So do you have a trans for it? The 240sx trans? Can you have the driveline cut to fit? I have the KA24DE from a '92 240sx. I also have the correct trans for the 240sx. The driveline is not the issue, it's the trans mount. I'm looking for a trans that's able to bolt to the KA and also bolted into the current trans mount. I do not want to spend money and timing paying someone to fabricate one, as I do not have the skills. You need an automatic driveshaft and a Z22 or Z24 71B 5 speed that is 31.5" long. (or an L series 71B with a Z series front case swap) Mike, would this trans apply to what I'm looking for? Mounts to the KA, and mounts to A10 chassis with no fabrication needed? Please don't think I am purposefully trying to go cheap, but I want to do this in a correct manner and not pay hundreds to someone to fab a mounts when i could just use oem nissan and mount it in... Quote Link to comment
flatcat19 Posted November 3, 2013 Report Share Posted November 3, 2013 Trans mount might be cheaper than a tranny. Flat 1/4" plate and a welder. 1 Quote Link to comment
bananahamuck Posted November 3, 2013 Report Share Posted November 3, 2013 chicken feathers and baling wire 1 Quote Link to comment
flatcat19 Posted November 3, 2013 Report Share Posted November 3, 2013 Epoxy weld it up. 1 Quote Link to comment
mhub91 Posted November 3, 2013 Report Share Posted November 3, 2013 Trans mount might be cheaper than a tranny. Flat 1/4" plate and a welder. Cheaper? What? Dude wants to charge me 4 hours to do it. Quote Link to comment
flatcat19 Posted November 3, 2013 Report Share Posted November 3, 2013 You can buy your own welder for that price. Hell-I think Beebani charges like $100 for his own mount. I'd make a mount with plate, drill, nuts and bolts, and a couple of hockey pucks. Gimme an hour! And make sure I'm drunk first. Quote Link to comment
