jastrunk97 Posted July 18, 2013 Author Report Share Posted July 18, 2013 I needa upload new pics..it now as new wheels and cold air intake complete :D Quote Link to comment
jastrunk97 Posted August 26, 2013 Author Report Share Posted August 26, 2013 Update, just completed my auto to 5 speed swap and its now a 5 speed :D 1 Quote Link to comment
jastrunk97 Posted October 9, 2013 Author Report Share Posted October 9, 2013 Was wondering if anyone can help me out, when i push in the clutch it sounds like a dry bearing. Probably the TO bearing but I was told that was a sealed bearing and did not needed to be greased? any thoughts. Quote Link to comment
jastrunk97 Posted October 9, 2013 Author Report Share Posted October 9, 2013 MAG WHEELS FOR THE WIN!!!!!!! 1 Quote Link to comment
jastrunk97 Posted October 13, 2013 Author Report Share Posted October 13, 2013 Just about lost 5th gear today...Grinds and pops out if i released the clutch anywhere near quickly...have to let it out very slow...:/ Quote Link to comment
vk56debt Posted October 13, 2013 Report Share Posted October 13, 2013 Do you know the kind of wheels that are on the truck to the left? And good luck with your tranny issues. I will be undergoing a auto->manual swap myself before too long. Quote Link to comment
datzenmike Posted October 13, 2013 Report Share Posted October 13, 2013 Was wondering if anyone can help me out, when i push in the clutch it sounds like a dry bearing. Probably the TO bearing but I was told that was a sealed bearing and did not needed to be greased? any thoughts. . Is it on facing the correct direction??? That would be the rounded face towards the motor. Just about lost 5th gear today...Grinds and pops out if i released the clutch anywhere near quickly...have to let it out very slow...:/ . Early 5 speeds have a large nut on the output shaft that basically holds 5th and reverse on. They have a tendency to work loose and 5th becomes erratic and often goes away. Nissan re designed the nut so it could be stated when in position. You could re tighten the nut and tack with some weld. Not saying this is it just possible. The seller probably knew there was a problem. Easy enough fix when the trans is out. Quote Link to comment
mikeanike99 Posted October 13, 2013 Report Share Posted October 13, 2013 Do you know the kind of wheels that are on the truck to the left? And good luck with your tranny issues. I will be undergoing a auto->manual swap myself before too long. They are hurricanes/turbines but don't know the make and they are nice but I need to clean them. Quote Link to comment
jastrunk97 Posted October 14, 2013 Author Report Share Posted October 14, 2013 . Is it on facing the correct direction??? That would be the rounded face towards the motor. . Early 5 speeds have a large nut on the output shaft that basically holds 5th and reverse on. They have a tendency to work loose and 5th becomes erratic and often goes away. Nissan re designed the nut so it could be stated when in position. You could re tighten the nut and tack with some weld. Not saying this is it just possible. The seller probably knew there was a problem. Easy enough fix when the trans is out. Slick sold me the tranny and I trust him to not rip me off. and as far as the output shaft I would need to tear apart the tranny dont I? Really hesitant to take it out again....Was a pain last time. The throw-out bearing is facing the right way. Il double check though. Quote Link to comment
jastrunk97 Posted October 15, 2013 Author Report Share Posted October 15, 2013 I think I may have put GL5 in my tranny, so i am going to get that stuff out and out some GL4 in. Quote Link to comment
jastrunk97 Posted October 15, 2013 Author Report Share Posted October 15, 2013 My transmission pooped out some bearings or bearing...Gonna rebuild it soonish... Quote Link to comment
jastrunk97 Posted October 17, 2013 Author Report Share Posted October 17, 2013 Selling my 5 speed to Red76Datsun and buying a ZX tranny from a friend. Quote Link to comment
jastrunk97 Posted October 22, 2013 Author Report Share Posted October 22, 2013 Wanting to snatch these up for my truck! :) http://seattle.craigslist.org/kit/pts/4124480338.html Quote Link to comment
GRpufnstuf Posted October 22, 2013 Report Share Posted October 22, 2013 Wanting to snatch these up for my truck! :) Those will look sweet! Maybe refresh the black and polish that big ol' lip? Quote Link to comment
mikeanike99 Posted October 22, 2013 Report Share Posted October 22, 2013 I saw those first but... He has money I have dept Quote Link to comment
jastrunk97 Posted October 22, 2013 Author Report Share Posted October 22, 2013 Those will look sweet! Maybe refresh the black and polish that big ol' lip? How would I go about refreshing the black? Quote Link to comment
GRpufnstuf Posted October 22, 2013 Report Share Posted October 22, 2013 Time and patience. I'd probably get some cheap pinstripe tape or the thinnest blue table and tape all the "spokes" off then tape everything else. Get a good quality rattle can spray paint and do a lot of thin coats from kinda far away. It's tough to get in there with direct spray unless you don't mind drips. Quote Link to comment
jastrunk97 Posted October 22, 2013 Author Report Share Posted October 22, 2013 Il prolly just polish them, doing what you said sounds like alot of work for right now. Quote Link to comment
jastrunk97 Posted October 23, 2013 Author Report Share Posted October 23, 2013 http://seattle.craigslist.org/kit/pts/4124480338.html Quote Link to comment
jastrunk97 Posted October 23, 2013 Author Report Share Posted October 23, 2013 Prolly getting them either today or tomorrow. Quote Link to comment
jastrunk97 Posted October 23, 2013 Author Report Share Posted October 23, 2013 They need tires but I got them for 100 delivered :) 1 Quote Link to comment
mikeanike99 Posted October 23, 2013 Report Share Posted October 23, 2013 I wanna put them on my truck:( Quote Link to comment
jastrunk97 Posted October 23, 2013 Author Report Share Posted October 23, 2013 Any thoughts? Quote Link to comment
mikeanike99 Posted October 23, 2013 Report Share Posted October 23, 2013 Really looks good Quote Link to comment
