Llittle_Llama Posted June 19, 2008 Report Share Posted June 19, 2008 ok, went to the J/Y and found a 5 speed tranny in a 620, but it is kinda wobley adn might need to be rebuilt, on the other hand, i found several (see like 6) 280Z's and they were all fine!. so what would install more easily and which would be better? by the way, "I WANNA GO FAST!!!!!" Quote Link to comment
DISLEXICDIME Posted June 19, 2008 Report Share Posted June 19, 2008 why bother if you are doing an engine swap ?:confused: Quote Link to comment
Llittle_Llama Posted June 19, 2008 Author Report Share Posted June 19, 2008 gave up the engine swap months ago....... Quote Link to comment
datsunaholic Posted June 19, 2008 Report Share Posted June 19, 2008 280Z 5-speeds are identical to '77-78 620 5-speeds except the speedometer drive cog. '79 620 5-speeds don't have as nice an overdrive. 280ZX (80-83) have taller overdrives (81-83 the tallest) but have a really close ratio so takeoffs in 1st are a little (OK, a lot) slow. 280Z and ZX transmissions are easier to remove in the junkyard (trucks are a pain in the ***). Quote Link to comment
Llittle_Llama Posted June 19, 2008 Author Report Share Posted June 19, 2008 just so were all on the same page, it's the 10th vin number that is the year identifier right? and the cars i want have the round headlights right? what letters can i use on the vin? imma go with the 280 tranny. and it just bolts right into my 79 right or do i need to grab something else while im there to make it fit? i know i asked this before, im just making sure. Quote Link to comment
yello620 Posted June 19, 2008 Report Share Posted June 19, 2008 i know i asked this before, im just making sure. Since you know that you asked this before, THEN SEARCH. Not going to give the answer now. Jason Quote Link to comment
79datsun620 Posted June 19, 2008 Report Share Posted June 19, 2008 you need to find you a borg warner 5 speed out of a 280zx turbo:D Quote Link to comment
datzenmike Posted June 19, 2008 Report Share Posted June 19, 2008 T-5 Tremec: You would have to modify the driveshaft length but that's ok because the spline has to be changed to fit the T-5 anyway. Use the end off the 280zx drive shaft. Additionally the clutch disc has to be changed as the spline on it is also different. The tranny is physically larger with much larger bell housing so very tight fit in a 620. Last, the tranny mount needs modification. The Nissan 280z/zx FS5W71B 5 spd literally 'drops' in. Same drive shaft, same clutch spline/disc, same size, same mount. Quote Link to comment
Llittle_Llama Posted June 19, 2008 Author Report Share Posted June 19, 2008 i already found a turbo one, but i dont want all the trouble. was not able to go today so maybe tomorrow :) Quote Link to comment
Llittle_Llama Posted June 20, 2008 Author Report Share Posted June 20, 2008 dont have to be at drill till 12;30 so i am going this morning, WOOT!!! gunna get me a tranny!!! please no one quote that in a sig....... Quote Link to comment
datzenmike Posted June 20, 2008 Report Share Posted June 20, 2008 Before removing, get something to drain the oil into. It's less messy later when you tilt it, nothing runs out the tail stock. Inspect the oil for flecks of silvery metal in it. Also take a good look at the bung, it has a magnet on it and will collect any ferrous metal particles. A black paste with fine particals is normal but beware chips and little pieces. The oil will be anywhere from clear brown (good) to black (still could be ok) If it is silver or milky, or like thickened coffee with cream pass on it. The last one I drained you could hear the gear chips hitting the bottom of the pan as I drained it and the oil looked like thick silver paint. Sure enough, the counter gear shaft was snapped in two. Don't forget, that car was scrapped for some reason. Could have been a busted tranny. And yeah, I did say bung. Quote Link to comment
Bleach Posted June 20, 2008 Report Share Posted June 20, 2008 wow.... you dont' know how to even tell the year of a car or what body style it is? I doubt you know the difference from a 280Z, 280ZX, or 300ZX. You will probably end up buying a 4-speed from a 280Z. :D Quote Link to comment
Llittle_Llama Posted June 20, 2008 Author Report Share Posted June 20, 2008 true, but vin year markings started in 1980, i was looking for a 79....thats right, lol i said WAS....I FOUND AND PULLED MY FIRST TRANNY!!!!!since it is hard to remove a 5 speed from a 620, i assume its harder to install one? Quote Link to comment
freaky510 Posted June 20, 2008 Report Share Posted June 20, 2008 30 min to remove 2hr to out back from under the rig so now i fust pull motor and trans can do the whloe thing in a little over an hour that way.;) Quote Link to comment
Bleach Posted June 20, 2008 Report Share Posted June 20, 2008 The plate in the driver's door tells the manufactured year. September or later of a year is usually the next year's model. VIN numbers don't tell the year of a vehicle. At least not back in the 70's or 80's. Quote Link to comment
Bugeye Posted June 20, 2008 Report Share Posted June 20, 2008 I got lucky today, found 2 5 speeds, one from a z car and the other from a 78 kc, and i bought them both, $65 each Quote Link to comment
Llittle_Llama Posted June 24, 2008 Author Report Share Posted June 24, 2008 The plate in the driver's door tells the manufactured year.September or later of a year is usually the next year's model. VIN numbers don't tell the year of a vehicle. At least not back in the 70's or 80's. actually it started in 1980 if im not mistaken. i will be trying to do the install tomorrow night....wish me luck!!! any hints? Quote Link to comment
