bigblockgq Posted August 11, 2013 Author Report Share Posted August 11, 2013 OBP hydraulic handbrake installed, shares the rear brake line series circuit. It has a drop leg to keep it engaged to act as an emergency brake. Works well Quote Link to comment
bigblockgq Posted August 11, 2013 Author Report Share Posted August 11, 2013 Installing roll cage, I decided to design this cage so I could remove the belt cross bar to access the rear as the car is small inside, I still need to install the rear seat for aesthetics, it is near impossible to access the rear without removal of cross bar, so glad I did it. Quote Link to comment
datsunwizard Posted August 11, 2013 Report Share Posted August 11, 2013 Ya I did put a shim in, maybe I need more? [see picture] Is this a common problem/concern with 510? Have you had to shorten the links as well ? Bend the lip of the engine cross member ? Thanks On the BRE racecars they bent up the area around the sway bar by the cross member mounts. Quote Link to comment
Supra510 Posted August 11, 2013 Report Share Posted August 11, 2013 Nice build. Love the RX too. Quote Link to comment
bigblockgq Posted August 11, 2013 Author Report Share Posted August 11, 2013 On the BRE racecars they bent up the area around the sway bar by the cross member mounts. That's good information, I have had a lot of trouble getting it to work. still concerned that it might be working as a torsion bar under full compression. Quote Link to comment
bigblockgq Posted August 11, 2013 Author Report Share Posted August 11, 2013 Oil cooler install - Earl's cooler Earl's sandwich plate oil thermostat 180 deg nice billet piece Quote Link to comment
Eagle_Adam Posted August 12, 2013 Report Share Posted August 12, 2013 what a freekn build man!!!! lovn it Quote Link to comment
bigblockgq Posted August 14, 2013 Author Report Share Posted August 14, 2013 Does anyone recognize this tach? not sure what its from but I have tried to get it working. It moves but is way way off actual RPM. I wired it as follows? Red wire to white = 12v yellow wire to yellow = tach signal black wire to black = ground Quote Link to comment
aintnobiscuit Posted December 23, 2013 Report Share Posted December 23, 2013 Any updates? Quote Link to comment
bigblockgq Posted February 16, 2014 Author Report Share Posted February 16, 2014 Not a ton. I have been busy elsewhere for most of the winter and will get back to it in the spring hopefully. I did however dyno the car last fall and was happy to see it make some reasonable power. It dynoed at 209 rear wheel with a very wide power band. This with an AFR that was way off and we had problems trying to get it leaner. AFR was around 10.5:1. The problem I think was the jets I had bought did not seem to be correct. The jets that were in place when I got the Carbs appeared to be 160 mains which were way rich according to my AFR gauge. I purchased an assortment of main jets to move lean, I started with a 155 and the AFR went from 10:2 to 15:0 and climbing in WOT.. shut down! Back to the drawing board. So the conclusion after some deliberation, the mains have been drilled! I hate when stuff like that happens, scratching your head, wtf. I have purchased 165, 170, 175 so on, now I can get a handle on it. I was thinking when it was on the dyno there is no way a 155 main will support that hp, and it didn't. We decided to re-install the rich unknown main size and make a couple pulls to get a base line rich. I also attended a track day in the fall which was great to find all the stuff that does not work on the car! lol I found out how manual brakes work for threshold braking! ouch, they need to be pushed real hard! Going to change compound (wilwood). Any input here would be great. Also found out my starter does not like heat. My car lovesss to be push started! "hey guys I'm going out how about a push..." got old fast, lol. I since have had a high torque gear reduction starter built by IMI. Awesome stuff, I have a very small odyssey battery so all is good, spins it over with no effort. Lots of stuff came loose, it's amazing what the track will tell you in a couple hot laps. I would like to get more tire under the car is one of the big quests I'll be on for phase two. 1 Quote Link to comment
Cpl620 Posted February 16, 2014 Report Share Posted February 16, 2014 i want to do dirty, dirty things to this whole build. that engine is freaking awesome! Quote Link to comment
bigblockgq Posted February 16, 2014 Author Report Share Posted February 16, 2014 Quote Link to comment
bigblockgq Posted February 16, 2014 Author Report Share Posted February 16, 2014 1 Quote Link to comment
datzenmike Posted February 17, 2014 Report Share Posted February 17, 2014 You can also fill the jet with solder and drill to any size you like. Old trick Quote Link to comment
aintnobiscuit Posted February 18, 2014 Report Share Posted February 18, 2014 ZOMG.... 209 on a dyno dynamics? :D I bet that thing is QUICK. Awesome job on the engine! Quote Link to comment
Farmer Joe Posted February 18, 2014 Report Share Posted February 18, 2014 dang! all those 200 horses are cuz of that headwork! looks like its time to find an extra head to start working on... :lol: whats the cam this ended up with? Quote Link to comment
aintnobiscuit Posted February 19, 2014 Report Share Posted February 19, 2014 On a dynojet or other crappy dyno this should put out around 241hp. So that gives you an idea of how fast it is :) They call the dyno dynamics the "heart breaker" because people get their cars tuned and do dyno runs on dyno jets and other dynos and then come do a run on this and see what their car actually puts down LOL. Quote Link to comment
bigblockgq Posted February 22, 2014 Author Report Share Posted February 22, 2014 dang! all those 200 horses are cuz of that headwork! looks like its time to find an extra head to start working on... :lol: whats the cam this ended up with? I would have to check for the exact spec on the cam, I can tell you it does not like to idle well, luuumpy ! The engine is race built top to bottom to make power not just head work, although the head has seen a lot of input from valves, valve train machine work, lots of porting.. It does breath well from carbs to header. The power band is very linear and very wide, peak hp is made around 6800. I have the rev limiter set to 7600 rpm at the track, I have to stretch a couple gears, sounds pretty sweet around there I must say..... I was actually trying to find a polyurethane engine mounts to help with idle lump, the engine just jumps around with the stock rubber new mounts. I was unable to find anything.. anyone ? anyone ? bueller bueller..... Quote Link to comment
bigblockgq Posted February 22, 2014 Author Report Share Posted February 22, 2014 ZOMG.... 209 on a dyno dynamics? :D I bet that thing is QUICK. Awesome job on the engine! 209rwhp at 10.5:1 air fuel. I will go back with the correct jets and hope to see 220 + rwhp at 13.2:1 Quote Link to comment
bigblockgq Posted February 22, 2014 Author Report Share Posted February 22, 2014 On a dynojet or other crappy dyno this should put out around 241hp. So that gives you an idea of how fast it is :) They call the dyno dynamics the "heart breaker" because people get their cars tuned and do dyno runs on dyno jets and other dynos and then come do a run on this and see what their car actually puts down LOL. Very very true, been there done that, 241 does have a nice ring to it though, lol Any eddy current dyno is the real deal for numbers 1 Quote Link to comment
bigblockgq Posted February 22, 2014 Author Report Share Posted February 22, 2014 IMI gear reduction starter, awesome Quote Link to comment
