Anyone know if these camber plates are comparable to T3's plates?
tylor
I was researching the cheapest way to go about installing dc2 integra coils on my 280z and read that needed camber plates. t3's plates would cost a total of 400 dollars alone, which is why i looked on ebay for another resort. i found these and was just wondering if they would be similar to the plates at techno toy tuning. they would save nearly half of what i would originally spend. so.. obviously if they work, i'd buy them. thanks!
  • Replies 9
Keep in mind that those are "UNIVERSAL FIT", and that there is fab'ing work to be done. If you are a confident fabricator, then it is just your additional labor & hardware cost. It would be imperative to get them lined up & drilled out straight, otherwise you would ill affect the castor and camber. I don't remember........do the T3's have serrations in the slide halves, to lock them in place better, once tightened down? I doubt those universal ones do. Just my 2c's!
blah blah mcpherson type struts blah blah lateral movement with compression blah blah you need a pillowball to compensate.
Most people don't get that the CAMBER PLATE itself isn't NECESSARY but the PILLOWBALL BEARING inside it IS. Especially with shocks as small as DC2's.
