Skib Posted November 18, 2012 Report Share Posted November 18, 2012 looking for a junk 240z airbox (ill be cutting it up for the stacks) and a 710 wiper switch. Link to comment
bonvo Posted November 20, 2012 Report Share Posted November 20, 2012 skib i might have the wiper switch ill check tomorrow Link to comment
Skib Posted November 21, 2012 Author Report Share Posted November 21, 2012 bump. could also use a good factory fuel pump. Link to comment
LenRobertson Posted November 21, 2012 Report Share Posted November 21, 2012 Is a 260Z the same? I seem to remember seeing one at P&S, although I think that car may have been crushed by now. Do you need just the bottom that bolts to the carbs, or the top cover too (in case it is missing)? Len Link to comment
karnutz Posted November 21, 2012 Report Share Posted November 21, 2012 L series pump? If so I have one. Link to comment
RedBanner Posted November 21, 2012 Report Share Posted November 21, 2012 Skib, I got you a nos fuel pump. The good one. Link to comment
Eagle_Adam Posted November 21, 2012 Report Share Posted November 21, 2012 jass has a wiper switch - txt her Link to comment
Skib Posted November 21, 2012 Author Report Share Posted November 21, 2012 Is a 260Z the same? I seem to remember seeing one at P&S, although I think that car may have been crushed by now. Do you need just the bottom that bolts to the carbs, or the top cover too (in case it is missing)? Len yeah 260 works too. I just need the back plate cuz Im cutting the airhorns out of it. Skib, I got you a nos fuel pump. The good one. sweet, just let me know what you want for it. jass has a wiper switch - txt her I dont know if the number I have is still good? Link to comment
RedBanner Posted November 21, 2012 Report Share Posted November 21, 2012 I bolted it on to the l20b I'm building, got sidedrafts and electric fuel pump. Gasket is glued to the block for my block off plate, but you can have the pump. Link to comment
Skib Posted November 21, 2012 Author Report Share Posted November 21, 2012 its a reg manual pump? I got a bunch of gaskets Link to comment
Eagle_Adam Posted November 21, 2012 Report Share Posted November 21, 2012 ill have her txt u - im at work Link to comment
RedBanner Posted November 21, 2012 Report Share Posted November 21, 2012 Yes mechanical. You know the good one. Screwy saucer style lol Link to comment
Skib Posted November 21, 2012 Author Report Share Posted November 21, 2012 sweeeet :cool: Link to comment
Eagle_Adam Posted November 21, 2012 Report Share Posted November 21, 2012 will a 620 light switch work? Link to comment
LenRobertson Posted November 25, 2012 Report Share Posted November 25, 2012 No joy on the 260Z airbox today at P&S. As I suspected, that Z has gone to Datsun Heaven via the crusher. Along with a 521 and several 620s that were there a month ago. Too bad. Len Link to comment
Ranman72 Posted November 25, 2012 Report Share Posted November 25, 2012 so are you going to weld the horns to another plate you make or use part of the stock backing plate I might be able to help you out Link to comment
Skib Posted November 25, 2012 Author Report Share Posted November 25, 2012 was gonna use part of the backing plate Link to comment
Ranman72 Posted November 25, 2012 Report Share Posted November 25, 2012 I will see if I can find one of those 73 style nobody likes it can be cut up then how big do you need it ? do you need it in one piece or are you going to make it separate cover the shipping and its yours Link to comment
Skib Posted November 25, 2012 Author Report Share Posted November 25, 2012 sent ya a PM randy Link to comment
