Zlich Posted November 17, 2012 Report Share Posted November 17, 2012 Im just wondering if their is anything different between hardbodys rear end and the older 720 datsuns? and If anyone would happen to have the measurements from the front shackle to the rear shackle and if they are the same it would be super helpful for some aftermarket shackles I just found. 1 Quote Link to comment
datzenmike Posted November 18, 2012 Report Share Posted November 18, 2012 The D21 may be wider than the 720 drum to drum. The late 720 4x4s used a 4.11 C200 rear axle. The D21s with Z24i motors used a 4.375 C200 differential The KA24 used a 4.11 C200 through '92. After that they were all H233 I believe. 1 Quote Link to comment
Zlich Posted November 18, 2012 Author Report Share Posted November 18, 2012 what about shackle to shackle and leaf springs? are they pretty much the same distance apart and what not? 1 Quote Link to comment
DISLEXICDIME Posted November 18, 2012 Report Share Posted November 18, 2012 sinner720 has a pathfinder lsd rear end that he had in his 720 for sale 1 Quote Link to comment
Zlich Posted November 18, 2012 Author Report Share Posted November 18, 2012 lsd would be pretty nice to have. Im just looking into the suspension right now. Im about to just get a tape measure and go to walmart and find a hardbody and measure the length from the front shackle to the back one. 1 Quote Link to comment
DISLEXICDIME Posted November 18, 2012 Report Share Posted November 18, 2012 you need ti cut all the mounts off and move the pads inward and the axle is a inch wider on each side if i remember right 1 Quote Link to comment
Zlich Posted November 18, 2012 Author Report Share Posted November 18, 2012 what If I was to get some aftermarket shackles for a hardbody? they are called revolver shackles. 1 Quote Link to comment
datzenmike Posted November 18, 2012 Report Share Posted November 18, 2012 you need ti cut all the mounts off and move the pads inward and the axle is a inch wider on each side if i remember right Sounds about right. I seem to remember the WD21 (Pathfinder) being about 60" drum to drum. 1 Quote Link to comment
Zlich Posted December 11, 2012 Author Report Share Posted December 11, 2012 Are the leaf springs different at all? like could i put leaf springs that are for a hardbody on my 81? 1 Quote Link to comment
HRH Posted December 15, 2012 Report Share Posted December 15, 2012 Yeah the leaf springs are interchangeable, but the axles are much bigger on the hardbody. The H233B only came with 4wd D21/WD21 after 90, early Pathy and Hardbodies were H190. The C200 is for all 2wd D21s, and may well have been on the 720s, but I thought it was still H190 at that point. 1 Quote Link to comment
Zlich Posted December 15, 2012 Author Report Share Posted December 15, 2012 Yeah the leaf springs are interchangeable, but the axles are much bigger on the hardbody. thank you so much Iv been looking for that answer for the longest time. 1 Quote Link to comment
DISLEXICDIME Posted December 15, 2012 Report Share Posted December 15, 2012 My late 86 720 is still h 190 1 Quote Link to comment
Zlich Posted December 15, 2012 Author Report Share Posted December 15, 2012 any of you guys happen to know how much of a lift I would need to clear 32/33 inch tires? Im fine with doing cutouts if needed. 1 Quote Link to comment
datzenmike Posted December 15, 2012 Report Share Posted December 15, 2012 All 2wd 720s were H-190. The later 720 4x4 switched to C200 with the Z24 motor. 2wd D-21s had H-190 on all 4 cylinder trucks through '93 4X4 D21s with 4 cylinder motors were C200 and VG s got the H-233. 1 Quote Link to comment
Zlich Posted December 15, 2012 Author Report Share Posted December 15, 2012 mines got a h190 1 Quote Link to comment
datzenmike Posted December 15, 2012 Report Share Posted December 15, 2012 All 2wd 720s were H-190. The later 720 4x4 switched to C200 with the Z24 motor. Well if you read between the lines the early 720 4X4 were H-190. Also the driveshaft yoke for the early 4X4 H-190 changed when the driveshaft was made larger diameter. Thank you Nissan for also changing the spline on the pinion so that a 4X4 yoke will not fit a 2wd H-190. Found this out the hard way. 1 Quote Link to comment
HRH Posted December 16, 2012 Report Share Posted December 16, 2012 All 2wd 720s were H-190. The later 720 4x4 switched to C200 with the Z24 motor. 2wd D-21s had H-190 on all 4 cylinder trucks through '93 4X4 D21s with 4 cylinder motors were C200 and VG s got the H-233. Clarification Mike, my D21 is a 4 cylinder 4x4 extended cab, and it got the H233B. I verified the vin with Nissan, though someone had swapped motors, but it's right there on the door tag too. Mine is a late '92, so '93. 1 Quote Link to comment
HRH Posted December 16, 2012 Report Share Posted December 16, 2012 any of you guys happen to know how much of a lift I would need to clear 32/33 inch tires? Im fine with doing cutouts if needed. My 30x9.50s rubbed on the 720 rear fender edge. A sledgehammer will fix that, or a lift. Sawzall fixes the front edge. ;) 1 Quote Link to comment
datzenmike Posted December 16, 2012 Report Share Posted December 16, 2012 Clarification Mike, my D21 is a 4 cylinder 4x4 extended cab, and it got the H233B. I verified the vin with Nissan, though someone had swapped motors, but it's right there on the door tag too. Mine is a late '92, so '93. Matt you are correct. I should have dug deeper. Jan '91 on 4x4... KA24E had H-233. 1 Quote Link to comment
Zlich Posted December 17, 2012 Author Report Share Posted December 17, 2012 I know 31s will fit cause my dad runs them on his pathfinder. But I dont have a set of 32's or 33's on hand to test to see where all itll rub and if anything will get in the way besides the fenders. I know I need some different rims for my truck all the way around cause mine have sucha negative back spacing my tires rub the frame in the back. Quote Link to comment
HRH Posted December 17, 2012 Report Share Posted December 17, 2012 Yeah, but Pathfinder and 720 are vastly different with fender clearances. Hardbody/Pathys had optional tire sizes of 31". 720s did not. Trust me, anything over 30" will rub the firewall. Just don't turn sharp or bottom the suspension all the way out and you'll be okay. Quote Link to comment
datzenmike Posted December 17, 2012 Report Share Posted December 17, 2012 29" is the limit on the stock 720 4x4and they rub on bumpy turns.. Quote Link to comment
Zlich Posted December 17, 2012 Author Report Share Posted December 17, 2012 weird I guess my dads 80 longbed rubbed on bumpy turns he said he ran 31's on his 720. thanks for the help Ill have to try and find a lift or something to run 32's or I might just go with some 31's Quote Link to comment
ssnapz Posted December 29, 2012 Report Share Posted December 29, 2012 i had a 2 wheel drive hb on 31s a while back. had the torsion bars cranked almost all.the way and 2" blocks in rear and still had to sawzall the fenders to keep from rubbing. you can always go body lift if on a budget or try to find some yoda lift leafs dont know what to do in the front Quote Link to comment
_chiefjt Posted December 30, 2012 Report Share Posted December 30, 2012 I have an '86 2wd 720. If its in my junkyard, can i get a hardbody axle and put pathfinder gears and disc brakes on it? I want the 4:3 rear end with lsd and disc brakes is what I'm shooting for. If so, what year hardbodys and pathfinders would I be looking for? Quote Link to comment
