mklotz70 Posted November 15, 2012 Report Share Posted November 15, 2012 This isn't so much of a how-to, but it didn't seem to fit anywhere else. I had these blanks water jet cut a couple of years ago by a member in VA. Got a pm recently requesting one. I said I wouldn't do anything with them unless I got a wild hair up my butt.......well, apparently I did. :) I'm sure the vid won't be done until tonight. Quote Link to comment
tdaaj Posted November 15, 2012 Report Share Posted November 15, 2012 Will you be selling these? Quote Link to comment
Eagle_Adam Posted November 15, 2012 Report Share Posted November 15, 2012 X2 ^^^ im putting my dads motor back together in the next week or so Quote Link to comment
ggzilla Posted November 15, 2012 Report Share Posted November 15, 2012 Nice. I made a pair of them in the late 1980s. But the transitiosn were hand-finished so couldn't make them for less than the $27 bucks weber adapters cost. Quote Link to comment
mklotz70 Posted November 16, 2012 Author Report Share Posted November 16, 2012 At this point, I don't have any plans of making them, but I might go ahead and submit the CAD art to the laser cutter and see what the blanks will cost. I'm pretty sure I'd have to sell them for at least $50ea to make it worth it. I could have them completely machined, but unless I could buy a large batch of them, they'd probably be even more. I might check on that too. I first need to see what's available on the market.Here's the vid. Quote Link to comment
dat521gatherer Posted November 16, 2012 Report Share Posted November 16, 2012 I'm just going to throw this out there. I seem to be the only person to notice this or have had this problem. On 3 different occasions I've had to slightly hog out the carb base mounting holes because the adapters are not lined up as they should be. The carb will go down almost all the way and then bind. I've mentioned this before on numerous threads but nobody seems to know what I'm talking about. My conclusion is that people force them the rest of the way down. I've seen this with new factory weber kits. Quote Link to comment
ggzilla Posted November 16, 2012 Report Share Posted November 16, 2012 Are you using the thick weber insulator between adapter and carb? It won't bind with that. Quote Link to comment
mklotz70 Posted November 16, 2012 Author Report Share Posted November 16, 2012 you're saying the bolts are too close or too far apart? Two of the studs will just be longer ones mounted in the manifold, the other two (to the carb) will be studs that were removed from the mani....... which brings up a questions I have. Do you guys know what the size/thread pitch is of the holes in the mani? I can go pull some studs from a mani here, but I thought I'd ask in case you know off the top of your head. :) 1 Quote Link to comment
Eagle_Adam Posted November 16, 2012 Report Share Posted November 16, 2012 im wrapping up a head and carb swap, ill take note of the size when i re-tap the holes Lolz - retap the holes - giggity Quote Link to comment
bananahamuck Posted November 17, 2012 Report Share Posted November 17, 2012 I'm just going to throw this out there. I seem to be the only person to notice this or have had this problem. On 3 different occasions I've had to slightly hog out the carb base mounting holes because the adapters are not lined up as they should be. The carb will go down almost all the way and then bind. I've mentioned this before on numerous threads but nobody seems to know what I'm talking about. My conclusion is that people force them the rest of the way down. I've seen this with new factory weber kits. I have seen this on more than one carb and different adapters also and drilled them out just like you,,, i can`t remember which way the studs were to close, just remember they were. Quote Link to comment
datsunaholic Posted November 17, 2012 Report Share Posted November 17, 2012 I haven't had that problem, because I don't use the thin 1-piece adapters. Every one I've seen had the threads ripped out from them being gorilla torqued, but maybe that's because they bound up and got forces sideways. I use the tall Trans-Dapt cast adapters, but that does require a short filter in some cases. I've also used the 2-piece adapters with decent luck, but I had to locktite the allen bolts to the manifold because they always back out. Quote Link to comment
mklotz70 Posted November 17, 2012 Author Report Share Posted November 17, 2012 not sure if these will even work, but I put about 5-1/2hrs into them today. They're not done, but they're getting close. I figured out to use the boring bar!! lol Read the siggy!Here's the vid link, it's still uploading but I had the link handy. Quote Link to comment
mklotz70 Posted November 17, 2012 Author Report Share Posted November 17, 2012 ....and some pics. Quote Link to comment
dscottdatsun Posted November 17, 2012 Report Share Posted November 17, 2012 Those are b - e - utiful looking Mike. B) I be wantin one of them half inchers. :thumbup: Scott Quote Link to comment
MicroMachinery Posted November 17, 2012 Report Share Posted November 17, 2012 moar tasty Klotz ingenuity.. Quote Link to comment
Eagle_Adam Posted November 18, 2012 Report Share Posted November 18, 2012 DO WANT!! Quote Link to comment
mklotz70 Posted November 18, 2012 Author Report Share Posted November 18, 2012 I made two posts to this this morning....before the hiccup. Now I don't even remember what all I put in them. hhmm.....They won't be cheap. I'm ordering helicoils for the threaded holes, so these will go on the shelf for at least a week or so. Turns out I already have the insert tool and tap....."new in the box". Probably bought it back when I had these blanks made....but I don't remember...oh well, I can take that $60 of stuff on the McMaster order now :) Maybe if someone got the email notification, they can copy/paste what I put in it. :) Quote Link to comment
mklotz70 Posted November 18, 2012 Author Report Share Posted November 18, 2012 hhmm....can't remember if I put this here or in the 3D modeling thread..... Quote Link to comment
mklotz70 Posted December 16, 2012 Author Report Share Posted December 16, 2012 Not sure if this will post correctly. Ratsun is having trouble with image links and I see the two previous youtube links in this thread are not coming up correctly. Quote Link to comment
mklotz70 Posted December 16, 2012 Author Report Share Posted December 16, 2012 Let's see if posting pics works. The last of the reference pics..... So...here's what's left. I'm keeping one of each for myself. One 1/2" is getting shipped out tomorrow to a very patient buyer. The 3/8" goes out with long and short bolts since I don't know how thick the insulator is. The 1/2" goes out with longer studs and just long bolts. The stock studs won't reach through the 1/2" adapter, hence the longer studs. I'll post up a for sale thread when I get a chance, but I can tell you right now....I'm not making any more of these anytime soon. When/if I do, I won't say anything until they're done. I need to quit selling stuff before it's finished.....it keeps forcing me into someone else's schedule, not mine. Anyway....This project is done! :) Quote Link to comment
ggzilla Posted December 17, 2012 Report Share Posted December 17, 2012 Beautiful workmanship. Makes mine look home made. Yours look better than the commercial ones. Quote Link to comment
mklotz70 Posted December 17, 2012 Author Report Share Posted December 17, 2012 Thanks. :) They took a good bit more work and time than I thought they would. If I ever do them again, I'll redo the CAD work again and get a quote to have them fully cnc'd. Quote Link to comment
Eagle_Adam Posted December 17, 2012 Report Share Posted December 17, 2012 Holy shit! those look great man!!! cant wait for a FS thread!!! Quote Link to comment
