cg78 Posted June 12, 2008 Report Share Posted June 12, 2008 I am new here so this may be a bit long. First I have a 78 620 king cab with a LZ22. Engine mods.... z22 bottom bored 1mm, balanced with a lightened flywheel, L20b head with 280z valves a custom grind 312dur 510 lift cam and fully ported, turbo oil pump and spray bar, cannon down draft intake and a weber 42 dcnf with 240 jets and 34mm chokes. Drive train....exedy organic stage one, t-5 280zxt trans and pro 5.0 shifter, 4 inch blocks and air bag helper kit. Wheels....16x8 inch american racing python with perilli p6's. Yes they rub. I am sure there is more I always forget since it has been about 4 years since I started. Here are some pics and a idle vid. Quote Link to comment
mrubcic Posted June 12, 2008 Report Share Posted June 12, 2008 sweet 620, i like those king cabs Quote Link to comment
Phlebmaster Posted June 12, 2008 Report Share Posted June 12, 2008 Nice....sounds like a monster!! :eek: hehe, how is it on gas?? :lol: Quote Link to comment
]2eDeYe Posted June 12, 2008 Report Share Posted June 12, 2008 Nice KC, love the color :D Quote Link to comment
808DA6 Posted June 12, 2008 Report Share Posted June 12, 2008 Whoa! ANother DCNF! I thought I was alone on this one. How does yours run? Sounds fuggin animal. What's your jet specs (air/main/idle/tubes)? I really haven't gotten mine to run strong, but i think its because the L16 is starting to die. Oh and its a 42dcnf too. -Brian Quote Link to comment
cg78 Posted June 12, 2008 Author Report Share Posted June 12, 2008 Nice....sounds like a monster!! :eek: hehe, how is it on gas?? :lol: Thanks and its crappy. Around 12 mpg 91 only and I cannot use any thing else. 2eDeYe;63895'']Nice KC, love the color :D Primer black ftw. Gets a scratch just shoot a rattle can lol. Whoa! ANother DCNF! I thought I was alone on this one. How does yours run? Sounds fuggin animal. What's your jet specs (air/main/idle/tubes)? I really haven't gotten mine to run strong, but i think its because the L16 is starting to die. Oh and its a 42dcnf too. -Brian Mine is temperamental but then again I changed the mains with out touching any other jet. I am still up in the air about keeping it. My mains are drilled out to 7/64 inch drill bit which should be a 277 main. I believe my correctors are 175 and my chokes are 34 mm. In your situation it may be a bit too much carb. You might want to see what choke is in yours. As mine sits with those chokes it should be 500cfm. I do not know whats worse the fact that I am up in the air about this carb or the 225 dollar cannon intake I modded to make it work. Just a side note Nathan Gerolamy built my motor son of the infamous B.C. Gerolamy. Quote Link to comment
denveratsun Posted June 12, 2008 Report Share Posted June 12, 2008 Nice work...those motor swap/build/patch together projects can be a ton of fun...or they can end up being a ton of work. How has it been for dependability? Are you still running the stock ring and pinion in the rear? What is top speed? (I won't tell anyone);) Quote Link to comment
cg78 Posted June 12, 2008 Author Report Share Posted June 12, 2008 Nice work...those motor swap/build/patch together projects can be a ton of fun...or they can end up being a ton of work. How has it been for dependability? Are you still running the stock ring and pinion in the rear? What is top speed? (I won't tell anyone);) It has been a pain but with nissan pistons in it now it has been a lot better. Yea stock ring and pinion out of a 73 donor 620. I am not sure of my top speed yet. I know that like 3k rpm is 75 or so. The overdrive is very nice in the t-5. I imagine it has to be like 130 or so. I have had it up to 4500 in 5th and the oem speedo was buried well passed 100. I think I am off by 20 mph. I learned my lesson the first time on rear ends. NO 6K drops it for some reason does not like it. I had to though and man was it fun on the old cam, so I am trying very hard not to do it with this one. I am making more power than before and all I do is drive it normal for now getting on it occasionally. I am having shifting problems though so it may be slowing me down a bit. The 3 4 slider went bad and it has hung in forth again so now it me be the dog teeth. I have the tranny place take it out cause man its a bitch. It is way crammed in there. Being this will be the third time it has been out I may just bend over and have him replace every thing. We will see this monday when I take it to him and get the look of not that dam thing again. Quote Link to comment
datzenmike Posted June 13, 2008 Report Share Posted June 13, 2008 I heard that lots of 300zx owners are getting rid of the T-5s and replacing with FS5W71C trannys from the 240sx. They are apparently quite a tough tranny. Just throw the L series front case half on. Quote Link to comment
nismopu Posted June 13, 2008 Report Share Posted June 13, 2008 All n/a 300zx's had fs5w71c's. Only the 84-86 turbos had the WC-T5 which is a much better shifting and drivable transmission but the fs5w can take a SERIOUS beating. Oh and you will have to machine the bearing recess larger to accept the fs5w's bearing diameter for the main shaft to do a front case swap. peace. Quote Link to comment
cg78 Posted June 13, 2008 Author Report Share Posted June 13, 2008 I heard that lots of 300zx owners are getting rid of the T-5s and replacing with FS5W71C trannys from the 240sx. They are apparently quite a tough tranny. Just throw the L series front case half on. Its a good trans and plenty strong for this lz22. My problem is I got it used and it was worn. We started by replacing the syncros and input shaft. Then the slider got stuck in forth every time I shifted into it. I went back and he replaced the slider now I think the dog teeth are bad because it grinds into forth every time and binds and hangs if you are not dead azz accurate with your shifts. On a good note the gearing is awesome and the shifter is very nice. Quote Link to comment
