ArchetypeDatsun Posted January 25, 2013 Report Share Posted January 25, 2013 I'll get a set once I have the $$$. Quote Link to comment
freekwonder Posted January 25, 2013 Report Share Posted January 25, 2013 ughhhh, why do I have to be broke right now. I hope the 50 mark is met so I can get these down the road. Quote Link to comment
thisismatt Posted February 6, 2013 Report Share Posted February 6, 2013 These are for bixenon low beams (2 Headlights). You can add halogen high beams (another 2 headlights) if you want (either projector ones or halogen ones). You can add an HID kit as well for your low beams. Excuse my ignorance, but doesn't bixenon infer not only HID but HID with a switchable low to high beam? If I'm correct, then I don't understand why you're selling bixenon low beams and then again giving the option to add an HID kit for the low beams for another $100...? It seems like it should be one pair of bixenon (HID) projector headlights, then the option for a pair of high-only headlights in either reflective or projection lenses with the option of halogen or HID bulb. Is that correct? Is it just that the ad is misworded and you meant to say "High beam light source type" and "You can add an HID kit as well for your high beams"...? 1 Quote Link to comment
Laecaon Posted February 6, 2013 Report Share Posted February 6, 2013 And don't run solo hid high beams. When you flash your high beams you will kill them. Bixenon is fine because all that is happening is you at moving the shiepldn out of the way,not illuminating another bulb. Quote Link to comment
thisismatt Posted February 6, 2013 Report Share Posted February 6, 2013 Yup, I understand those points Quote Link to comment
bens1088 Posted February 6, 2013 Author Report Share Posted February 6, 2013 Excuse my ignorance, but doesn't bixenon infer not only HID but HID with a switchable low to high beam? If I'm correct, then I don't understand why you're selling bixenon low beams and then again giving the option to add an HID kit for the low beams for another $100...? It seems like it should be one pair of bixenon (HID) projector headlights, then the option for a pair of high-only headlights in either reflective or projection lenses with the option of halogen or HID bulb. Is that correct? Is it just that the ad is misworded and you meant to say "High beam light source type" and "You can add an HID kit as well for your high beams"...? Bi-xenon refers to the projector having a solenoid shutter (high/low beam). Just because a projector is bi-xenon, doesn't mean it includes HIDs. We don't carry lower end HIDs so we wouldn't make anything (esp. on a new design) to include HIDs. We include halogen bulbs so you can run something for now and grab an HID kit later. Also some guys want to run their own HID kits. The high beams only come in halogen because of the point Laecaon made. We originally were going to run regular low beams but everyone wanted bi-xenon (thus the added cost). The goal is to unleash all light when you flash high beams (bi-xenon high) and (halogen high). I hope that makes sense. Let me know if I need to clarify. Thanks! Quote Link to comment
thisismatt Posted February 6, 2013 Report Share Posted February 6, 2013 Bi-xenon refers to the projector having a solenoid shutter (high/low beam). Just because a projector is bi-xenon, doesn't mean it includes HIDs. We don't carry lower end HIDs so we wouldn't make anything (esp. on a new design) to include HIDs. We include halogen bulbs so you can run something for now and grab an HID kit later. Also some guys want to run their own HID kits. The high beams only come in halogen because of the point Laecaon made. We originally were going to run regular low beams but everyone wanted bi-xenon (thus the added cost). The goal is to unleash all light when you flash high beams (bi-xenon high) and (halogen high). I hope that makes sense. Let me know if I need to clarify. Thanks! Xenon is an element used in the HID bulb, though, hence the confusion. I guess that makes me wonder is the low setup going to have good cutoff with a halogen bulb or does it rely on the bixenon bulb switching? Quote Link to comment
bens1088 Posted February 6, 2013 Author Report Share Posted February 6, 2013 Xenon is an element used in the HID bulb, though, hence the confusion. I guess that makes me wonder is the low setup going to have good cutoff with a halogen bulb or does it rely on the bixenon bulb switching? Yeah you typically don't see bi-xenon with halogen bulbs. We've just included them so you have something to run for now incase you wanted to get your own HID kit. The cutoff will be exactly the same, the light just won't be as bright. H1 bulbs are single filament bulbs which mean they never move or change- there is only on or off. The shutter in the projector is what manipulates the light to have high/low (shutter open/shutter closed). Quote Link to comment
thisismatt Posted February 15, 2013 Report Share Posted February 15, 2013 What kinds of benefits are seen with the high beam projector housing vs reflective housing? Quote Link to comment
Laecaon Posted February 15, 2013 Report Share Posted February 15, 2013 I highly recommend getting a HID kit from theretrofitsource.com I am running a complete Morimoto 50w setup, 5000k bulbs. The light output is amazing, and the color is pure white, not that blue associated with HID kits. Quote Link to comment
mrbigtanker Posted February 15, 2013 Report Share Posted February 15, 2013 Yeah you typically don't see bi-xenon with halogen bulbs. We've just included them so you have something to run for now incase you wanted to get your own HID kit. The cutoff will be exactly the same, the light just won't be as bright. H1 bulbs are single filament bulbs which mean they never move or change- there is only on or off. The shutter in the projector is what manipulates the light to have high/low (shutter open/shutter closed). How many ordered already I will have some one order from you to make up for me. Quote Link to comment
bens1088 Posted February 15, 2013 Author Report Share Posted February 15, 2013 What kinds of benefits are seen with the high beam projector housing vs reflective housing? It's mostly for looks. Some guys want to have all for headlights look the same. I highly recommend getting a HID kit from theretrofitsource.com I am running a complete Morimoto 50w setup, 5000k bulbs. The light output is amazing, and the color is pure white, not that blue associated with HID kits. Make sure you use proper housings. You can buy HID kits anywhere. How many ordered already I will have some one order from you to make up for me. We only recieved 3 orders. We'll start pushing again after our next order comes in. Quote Link to comment
thisismatt Posted February 15, 2013 Report Share Posted February 15, 2013 It's mostly for looks. Some guys want to have all for headlights look the same. Understandable. So if I didn't care about them matching, then really there isn't much, if any, benefit to lighting performance? I appreciate the honesty, thanks. Quote Link to comment
bens1088 Posted February 15, 2013 Author Report Share Posted February 15, 2013 Understandable. So if I didn't car about them matching, then really there isn't much, if any, benefit to lighting performance? I appreciate the honesty, thanks. Exactly. Not worth it unless you HAVE to have all the headlights match. Quote Link to comment
thisismatt Posted February 23, 2013 Report Share Posted February 23, 2013 I wish more people were interested. It seems like the 7" have been well received. I think I'm in the same boat as a lot of people - I'd probably buy a set if they were ready right now, but since it's kind of an impulse decision I'm having a hard time wanting to pay up front for a group buy :P Quote Link to comment
bens1088 Posted February 23, 2013 Author Report Share Posted February 23, 2013 I wish more people were interested. It seems like the 7" have been well received. I think I'm in the same boat as a lot of people - I'd probably buy a set if they were ready right now, but since it's kind of an impulse decision I'm having a hard time wanting to pay up front for a group buy :P I wish more people were interested too. We've only received about 4 pre-orders. The 7" demand is growing too rapidly and we can't get enough inventory to meet the demand. If the 7" slows down, then we can start to move faster in this direction and get them ready without the pre-orders. If we can get at least half the pre-orders, we'll probably be able to make it happen. Quote Link to comment
q-tip Posted February 24, 2013 Report Share Posted February 24, 2013 Have you tried posting this on the 510 realm? Im too lazy to look myself... Quote Link to comment
thisismatt Posted February 24, 2013 Report Share Posted February 24, 2013 It's over there with about the same amount of response. Quote Link to comment
Laecaon Posted February 24, 2013 Report Share Posted February 24, 2013 No worries about my housings. Though I wish I went with a different projector, I have Morimoto FX-R V3 Quote Link to comment
q-tip Posted April 10, 2013 Report Share Posted April 10, 2013 Any updates on this? Quote Link to comment
bens1088 Posted April 10, 2013 Author Report Share Posted April 10, 2013 Didn't get enough interest. I have some different prototypes coming in a couple months. We'll see how well those work and go from there. Quote Link to comment
q-tip Posted April 10, 2013 Report Share Posted April 10, 2013 Too bad there isn't enough interest. Still going forward with the classic design just and enthusiasticly as with more interest? Quote Link to comment
bens1088 Posted April 11, 2013 Author Report Share Posted April 11, 2013 Too bad there isn't enough interest. Still going forward with the classic design just and enthusiasticly as with more interest? We're going forward more cautiously. With the 7", there was a lot more momentum going forward. We'll slowly be testing different prototypes and adding in produts we think best fit our customer's needs. Our goal is to have the most diverse selection of sealed beam replacement projector headlights on the market. Quote Link to comment
q-tip Posted April 11, 2013 Report Share Posted April 11, 2013 Will those that have paid already still be getting product once its finished Quote Link to comment
bens1088 Posted April 11, 2013 Author Report Share Posted April 11, 2013 Will those that have paid already still be getting product once its finished Anyone who paid for a group buy has first dibs on the prototypes coming (1-2 months). We have between 5-10 kits coming in. If you end up not liking them and theres nothing else you want from our store, we'll refund your money. Quote Link to comment
