datzenmike Posted June 12, 2008 Report Share Posted June 12, 2008 OR keep the Z22 and put it back in for every smog test. A week later put your 426 HEMI back in. Well maybe not a hemi but something substantial. Build it with the idea of being able to easily swap it back and forth. Cake and eat it too. Quote Link to comment
mmsonic Posted June 12, 2008 Author Report Share Posted June 12, 2008 OR keep the Z22 and put it back in for every smog test. A week later put your 426 HEMI back in. Well maybe not a hemi but something substantial. Build it with the idea of being able to easily swap it back and forth. Cake and eat it too. Hmm, HEMI, now there's an idea...:D Back to the real world:(, upgrading the z22 or putting a KA in would be simplest, especially if I have to go through the trouble of going back to stock. nismopu's idea would actually seem to be the easiest, and the funnest, if it got me that kind of power. I'm a little hesitant with the forced induction (with the KA or Z22) because of smog and early detonation risks, but if those risks weren't there, I would be all for it. Also, Mike, could you enlighten me about your EFI setups? Whats the real gain with efi on a Z22? What else would I need? That CARB is really fogging up my mind. Quote Link to comment
cg78 Posted June 12, 2008 Report Share Posted June 12, 2008 I am not sure about the 720 but if it is any thing like the 620 the sr is out. The oil pan is a front sump and is part of the block. You can get them for about 2500 for just the motor, but there is no way it will smog. Another possibility is running a us truck or car v6. Like a vg30e or a vg30et all you have to do is find one out of a newer car than yours get it to pass the bar and you will have all you want. Good economy and power. Quote Link to comment
dat u racing Posted June 12, 2008 Report Share Posted June 12, 2008 im puttin a ka24 in my 521 with a set of Suzuki ITB's to the intake ports on the ka24de head. i found a great deal of info in the engine deparment here at ratsun on how to Quote Link to comment
datzenmike Posted June 12, 2008 Report Share Posted June 12, 2008 Also, Mike, could you enlighten me about your EFI setups? Whats the real gain with efi on a Z22? What else would I need?That CARB is really fogging up my mind. Performance wise... nothing. Better starting. No choke. Better fuel mixture at all RPMs and temperatures, so better drive ability (no flat spots) and fuel economy. Not affected by hard cornering, bumps or severe off road tilts. Much better for possible future turbo addition including an IC. A draw or suck through carb has it's limitations. The early EFI was very rudimentary and ruggedly simple. I'm still working on it. Have the Z24 engine in and as of yesterday I have the electric fuel pump hooked up. Quote Link to comment
78savage Posted June 14, 2008 Report Share Posted June 14, 2008 So, has anyone done a sr20det into a 620. My engine is almost done , previous owner did b2200 fi engine, runs but sure smokes. And I really want a turbo engine, and the cash has burned through my pocket and its onto my leg now What Im really trying to find out is how many mods have to be made, and what it really takes to get one in. The company Im thinking of buying from has a plug and play wiring harness, so to me the hardest part is done. Ive done V8,s into S10"s, so a sr20 into a 620 should not be that bad. Please, any info would be greatly appreciated. Thanks, Darren Quote Link to comment
mmsonic Posted June 14, 2008 Author Report Share Posted June 14, 2008 DON'T POST IN MY THREAD GRRR..... No just kidding:p But hey, why don't you check out the FAQ page. It really helps. 620s are everybody's beloved truck, but it also helps if your's is pre-76. no smog. Quote Link to comment
Llittle_Llama Posted June 14, 2008 Report Share Posted June 14, 2008 it also helps if your's is pre-76. no smog. not true, im 79 and deleted all my smog stuff...plus i have discs up front.....i win :D lol and vg30 wont fit.... Quote Link to comment
yello620 Posted June 14, 2008 Report Share Posted June 14, 2008 not true, im 79 and deleted all my smog stuff...plus i have discs up front.....i win :D lol and vg30 wont fit.... You minght have deleted all your smog stuff, but that didnt make it legal. You just dont have to get inspected. And why wont a vg30 fit. Bet you tried to make it happen didnt you.:lol: Jason Quote Link to comment
makya Posted June 14, 2008 Report Share Posted June 14, 2008 http://www.attarco.com/index.php?cPath=2&sort=20a&main_page=index&filter_id=8 for 2k you could probably find something here that would get you close. you would have to meet the smog requirements of the motor if it is newer than the truck, so you'd have to scrounge those up. 200hp is not doable without some serious downtime to your truck though. Quote Link to comment
Llittle_Llama Posted June 14, 2008 Report Share Posted June 14, 2008 And why wont a vg30 fit. Bet you tried to make it happen didnt you.:lol: Jason if im not mistaken it's the exhaust manifold on the T-0bars thats the problem....VG30=wide Quote Link to comment
datzenmike Posted June 14, 2008 Report Share Posted June 14, 2008 Anything can be done. A VG is a lot closer to the high end of difficult. Exhaust pipes on both sides. Quote Link to comment
mmsonic Posted June 15, 2008 Author Report Share Posted June 15, 2008 Gotta agree, anything is possible, especially with a welder. As nice as a V6 VG30 turboed would be in my truck, I don't really want to sell my soul for gas. Mike, that FI setup, what do I need? That involves an ECU (dosen't bother me, I'm pretty good with programming, computers, and wiring) and new fuel equipment?(fuel rail, pump, tank) Right? BTW what would you do? KAt or Z22t? Or maybe something else? Quote Link to comment
datzenmike Posted June 15, 2008 Report Share Posted June 15, 2008 Here's a write up for a 510 I think but most applies to ANY 4cyl gas engine. :http://datsun1200.com/modules/nsections/index.php?op=viewarticle&artid=99 It's not very complicated, reasonably easy to do, and not much to go wrong. The KA system is much more complex, with more sensors but with better fuel management control and results. Power but poor economy the KA24ET but for economy and some power and the 200sx system bolts right on, the Z22ET. Quote Link to comment
nismopu Posted June 15, 2008 Report Share Posted June 15, 2008 z22et, you wont be dissapointed. PLus its the easiest! peace. Quote Link to comment
datzenmike Posted June 15, 2008 Report Share Posted June 15, 2008 z22et, you wont be dissapointed. PLus its the easiest! peace. I hope he goes with this. I don't know of anyone with that combo. The Z22 is like a stroker L20B. The Z motors have a breathing limitation that the turbo will take care of. They actually had Z18ETs in Japan. Here's a pic: http://i138.photobucket.com/albums/q251/datzenmike/motorZ18ET.jpg[/img]"] Isn't that a clean little motor? 135hp too. A Z22ET should be good for a 22.22% increase, so over 160. Only drawback is the Z cranks aren't fully counterweighted so 6,500-7,000 maybe. More than enough for the street. One of those turbo exhaust manifolds would make the conversion a lot smoother eh? Quote Link to comment
mmsonic Posted June 16, 2008 Author Report Share Posted June 16, 2008 WOW Yeah, would really love to get one of those exhaust manifolds, could actually have it on the road this summer if I had one. The FI setup I'd also take, but having all of it would take the fun out of experimenting. 160 could be really nice, could probably increase more if I could get better compression, and all the extra parts. (intercooler, cold air, HUGE exhaust, High flow-cat, ect) Any estimate on the torque Mike? BTW what are you putting the Z24 in? Quote Link to comment
