71kat510 Posted October 13, 2012 Report Share Posted October 13, 2012 hey guys just picked up a 74 datsun 620 that needs some work its my first old school vehicle im used to driving and working on s13 240sx"s so this is a little new to me first problem im having and cant figure out is that my front driver side turn signal doesnt work but it works when i put my hazards on two bulbs?? second problem that happened today is that my door handle stopped working havent had a chance to look at it but any info would help third problem is that my radio fuse keeps blowing (2nd one down right hand side) then randomly my dash lights stopped working but i guess this is what i get for wanting to save a truck from the scrapyard but back to the truck 74 datsun 620 stock L 18 engine 4 speed manual lowered on 3" blocks and leaf spring packs removed torsion bared down in the front Pic from when i picked it up from spokane for $900 after i got it home future plans swap in a ka24de or build the L18 lower a inch or so all around throwing the sparco sprint in tomorrow Mock up pic Quote Link to comment
Wide14u Posted October 13, 2012 Report Share Posted October 13, 2012 looks good Quote Link to comment
Farmer Joe Posted October 13, 2012 Report Share Posted October 13, 2012 wasnt this the one we just saw on CL? jason? i swear lorri found it on her phone the other day.. i like how its low.. Quote Link to comment
71kat510 Posted October 13, 2012 Author Report Share Posted October 13, 2012 gonna go lower after i fix all the problems and good chance u saw it on cl thats where i found it Quote Link to comment
bonvo Posted October 13, 2012 Report Share Posted October 13, 2012 its only the one turn signal that doesnt work? could be the switch is dirty or it could be a connection at the light itself Quote Link to comment
71kat510 Posted October 13, 2012 Author Report Share Posted October 13, 2012 ya just the driver side front the rear turn works fine but not the front but lights up with the hazards on Quote Link to comment
datzenmike Posted October 13, 2012 Report Share Posted October 13, 2012 First off, unplug the fuse box, remove the fuses and soak in a bowl of vinegar. This will remove any corrosion that could be causing/masking any problems later. Replace the fuses, they are cheap and not to be trusted simply on "they look ok to me" Turn signal. The L turn and 4 way flasher share the same wires and bulb so if the 4 way works it's not these. Are you sure that the LEFT REAR is flashing? If it is, the problem is a poor connection at the harness plug to the turn signal lever or the turn signal lever itself. (try unplugging the connector several times to clear any corrosion) I had a similar problem on my 620 and one of the soldered wires had come off inside. Remove the steering wheel and black plastic clam shell that surrounds the ignition switch to access it. There is a 19mm or 21mm nut securing the wheel. Remove it and the star washer. TURN HEAD TO RIGHT and using the palms of both hands bring them towards you together and the back side of the steering wheel, hitting it firmly several times. The wheel should slide towards you and off the splined steering column. Don't forget to turn your head or you will either knock yourself out or knock your teeth out. Door handle You'll have to remove the door handle and arm rest and un clip the door card or panel to get at the inner workings of the door. You don't say if it's the inside, outside or both. There is a vertical pushrod near the latch that has a nylon adjustment nut that sets the stroke for the outside handle lift. I've had one door that would not unlatch unless you lift upwards very firmly. I adjusted this plastic nut and it would unlatch with much less effort and handle movement. It could simply be that the lever linkage has just come undone. Quote Link to comment
71kat510 Posted October 13, 2012 Author Report Share Posted October 13, 2012 its the inside handle and ill try your suggestions on blinker and fuse box thanks for the help also what fuse does the dash lights run off of so i can get those fixed Quote Link to comment
datzenmike Posted October 13, 2012 Report Share Posted October 13, 2012 Dash lights are 15 amp but this might be fixed by the vinegar bath and new fuses. Quote Link to comment
peanutbuttercups Posted October 14, 2012 Report Share Posted October 14, 2012 ^ Good job DatsunMike!! And nice 620 71kat510, it looks really straight. Get the bugs out and start pimping that thing out!!! What part of Montana?? I had family in Stevensville. I love Montana!!! Quote Link to comment
71kat510 Posted October 18, 2012 Author Report Share Posted October 18, 2012 ya its super straight gonna get it painted soon but on sunday i went up to the shop and started making it reliable through fixed the slave cylinder that was in two pieces prepped and cleaned the floor will be getting bed liner me and my friend started to make a seat mount for my sparco all mounted belts still need to be mounted found a air filter at the shop looks alot better changed the oil and spark plugs friend gave me a msd blaster 2 coil made a huge difference and i live in missoula stevensville is not far from missoula at all Quote Link to comment
sergent Posted October 19, 2012 Report Share Posted October 19, 2012 whoa! what is that air filter set up? Looks like a bundt cake tin. cool truck . Im watching some 620 builds from now on to check them out closer. The stance is cool with those wheels. What color are you thinking about in the future? Quote Link to comment
71kat510 Posted October 19, 2012 Author Report Share Posted October 19, 2012 gonna be teal with white wheels and the air filter is a knock off hks filter its temporary Quote Link to comment
peanutbuttercups Posted October 19, 2012 Report Share Posted October 19, 2012 ^^ loving that msd coil. I love Missoula, such a cool town. Good progress. Quote Link to comment
71kat510 Posted October 21, 2012 Author Report Share Posted October 21, 2012 ya its a fun place to grow up wanna move to seattle or down south somewhere but if anyone finds themselves in missoula mt let me know we can might up and talk bout our datsuns Quote Link to comment
banzai510(hainz) Posted October 22, 2012 Report Share Posted October 22, 2012 Dude you you still have points in the distributor youll burn them up!!!!!!!! You have a 74 620 so I assume you still have points igntition. If you have a Matchbox or 1st Gen Nissan electric your OK. If still running pouints you need a ballast resisitor(which I see) and the stock point coil. Hopefully you still have this. For soem reason kids like buying these MSD coils and fucking up there cars(poitns last half as long) if still points installed. MY recommendation is put the stock coil back in. Its DESIGNED for POINTS!!!!!!!. MDS is made for EI type ignitions.Or you have to add another ballast in series with the stock one. Im sure starting was faster but ck you points I bet they burning up already Quote Link to comment
71kat510 Posted October 22, 2012 Author Report Share Posted October 22, 2012 what ballast would i need and i got it for free from a friend that installed it and stole my stock coil Quote Link to comment
banzai510(hainz) Posted October 22, 2012 Report Share Posted October 22, 2012 stock coil is 1.6 ohms Ballast is 1.6 ohm = 3.2ohm you put a .7 ohm coil(MSD) in there. so make up the difference add a .7 ohms up to a say 1 ohm.Resistor But these arnt that cheap either. But a stock coil datsun 74 coil is pretty cheap. Just buy that at Napa or soemthing. plus looks stock. Free doesnt always mean BETTER 1 Quote Link to comment
