DREWSDIME Posted October 1, 2012 Report Share Posted October 1, 2012 I am looking to get some drop spindles for my 85 720, I heard there is spacer needed to use hard body drop spindles on 720 but all the pics I see show no spacer? Quote Link to comment
dscottdatsun Posted October 1, 2012 Report Share Posted October 1, 2012 No spacers are needed. Just r&r brakes and hubs, unbolt the stock spindle and replace it with your drop spindle. Quote Link to comment
wayno Posted October 1, 2012 Report Share Posted October 1, 2012 Maybe they were talking about a spacer between the rim and hub. Quote Link to comment
thisismatt Posted October 1, 2012 Report Share Posted October 1, 2012 Pretty sure, yes, there are thick washers for spacing the 720 caliper when using 720 hubs/rotors. Quote Link to comment
wayno Posted October 1, 2012 Report Share Posted October 1, 2012 The issue that some people might talk about is that when the hub spindle is moved higher, it brings the lower arm(LCA)/balljoint closer to the inside of the rim, 720s came with 14 inch rims, without a spacer between the hub and rim to move it out, it is likely you will not be able to use your 14 inch rims anymore, and you will have to buy/use 15 inch rims minimum. The calipers/rotors should be a bolt on in there stock alignment, just raised to the new position, after all, you are buying a drop spindle, if everything wasn't re-positioned properly, no one would buy them. Quote Link to comment
thisismatt Posted October 1, 2012 Report Share Posted October 1, 2012 I'm not saying I've installed them, but my belltec spindles did come with washer spacers for mounting 720 calipers Quote Link to comment
nis720 Posted October 1, 2012 Report Share Posted October 1, 2012 If you switch over to Hardbody rotors you won't need to use the caliper bracket spacers. Rotor offset is the only difference between the HB and 720 front brakes, brackets and calipers are the same. I'll get pics of the spacers when I get home. I think the thicknes is 1/4". Quote Link to comment
irishevox Posted December 27, 2012 Report Share Posted December 27, 2012 on an 80 720 what spindles would work ? Quote Link to comment
DISLEXICDIME Posted December 28, 2012 Report Share Posted December 28, 2012 But what about the 86 720 I thought they had the same front brakes as the hard body Quote Link to comment
