prophet1012 Posted January 21, 2013 Report Share Posted January 21, 2013 I may be mistaken here but if you're using stock struts, there should be no need to cut the strut tube, as the struts are still the same length. you were right the is no need to cut the strut tubes...for moderate lowering at least thanks :) Quote Link to comment
prophet1012 Posted January 21, 2013 Report Share Posted January 21, 2013 hopefully you ordered the coilover kit for the b310, as the 1200 strut is smaller in diameter I cancled the order, thank you very much, I was going to wast 250 dollars, I will order the 280zx weldon coilover kits instead, as the B310 and 280zx strut diameter are both 2" or 51mm. does that seem right to you? Quote Link to comment
LeviGideon Posted May 30, 2013 Author Report Share Posted May 30, 2013 So, I finally got a 5 speed! $125 for a dogleg. :thumbup: Went to put it in, and realized the clutch was different from the 4 speed. :sneaky: So, a new clutch is on the way. Quote Link to comment
bananahamuck Posted May 31, 2013 Report Share Posted May 31, 2013 So i see you all over the map,, literally ,, are you in Oregon now ?? and if you are did you ever decide which car wagoon your bringing to Canby? or both Quote Link to comment
its_karl Posted May 31, 2013 Report Share Posted May 31, 2013 is the throwout/clutch fork different too? I was going to do this swap on my 710 but never got the dogleg shifter or fork, so i kept putting it off until I traded it. Quote Link to comment
dukerollo Posted May 31, 2013 Report Share Posted May 31, 2013 I dig this. I almost like the b310 nose better than the a10 510 nose. I just did coil overs on mine. You can get coil over sleeves and springs meant for circle track cars and build up your own to save a few bucks. If you are interested, I can dig up some part numbers. 1 Quote Link to comment
LeviGideon Posted May 31, 2013 Author Report Share Posted May 31, 2013 So i see you all over the map,, literally ,, are you in Oregon now ?? and if you are did you ever decide which car wagoon your bringing to Canby? or both Trollin' across 'Merica in my 210.... I'm in Eugene semi-permanently now, I'm even signing a rental agreement tomorrow. trololololol We'll see how that lasts. At this point, neither goon is driving, but if I know my 210 like I think I do, I'll probably be taking it. Quote Link to comment
LeviGideon Posted May 31, 2013 Author Report Share Posted May 31, 2013 is the throwout/clutch fork different too? I was going to do this swap on my 710 but never got the dogleg shifter or fork, so i kept putting it off until I traded it. I'm not really sure... I haven't broken my 510 enough to know much about it. 1 Quote Link to comment
LeviGideon Posted June 5, 2013 Author Report Share Posted June 5, 2013 5 speed is in, she cruises nice, but my battery is fried... One thing after another. Oics and details later Quote Link to comment
izzo Posted June 5, 2013 Report Share Posted June 5, 2013 is the throwout/clutch fork different too? I was going to do this swap on my 710 but never got the dogleg shifter or fork, so i kept putting it off until I traded it. If you grab a dogleg, get the fork and throw out with it. It will match. Replace the bearing on the collar. Done deal. A series and L series dogleg are different in a way... mostly the bellhousing IIRC. A weak trans for L series, plenty strong for an A series. 1 Quote Link to comment
LeviGideon Posted June 27, 2013 Author Report Share Posted June 27, 2013 We took the 210 to help a lady replace the water pump in her Chevy. We caught a snake at her house and put it in a container for the ride home. We got home and the container was empty. There's a snake nesting in my 210 somewhere right now... We never found it. 1 Quote Link to comment
prophet1012 Posted June 27, 2013 Report Share Posted June 27, 2013 maybe it got out? :P haha just kidding Quote Link to comment
Eagle_Adam Posted June 27, 2013 Report Share Posted June 27, 2013 what kind of snake? Quote Link to comment
LeviGideon Posted June 27, 2013 Author Report Share Posted June 27, 2013 Just a little garter snake. Nothing to be too concerned about. Quote Link to comment
LeviGideon Posted July 28, 2013 Author Report Share Posted July 28, 2013 Threw some 510 hubcaps back on with steelies for now. Anyone have an idea on how much a full set of bullseye hubcaps goes for these days?Used some of the clips for the old a\c to hold the wiring harness lower on the firewall and declutter the top area, and rerouted the booster hose for more decluttering.Gotta get some purple power in there to clean it all up. Quote Link to comment
Eagle_Adam Posted July 29, 2013 Report Share Posted July 29, 2013 purple power will change your life man... Quote Link to comment
LeviGideon Posted July 29, 2013 Author Report Share Posted July 29, 2013 Yup. It goes quick though. haha We had 2 bottles and I have no idea what we used it on. Quote Link to comment
Eagle_Adam Posted July 29, 2013 Report Share Posted July 29, 2013 the transmission you guys put in the goon..... Cus i couldnt watch it go in dirty.... like i said, it changes ur life Quote Link to comment
LeviGideon Posted July 29, 2013 Author Report Share Posted July 29, 2013 hahaha That is true. That thing was naaasty. Quote Link to comment
