skyknight789990 Posted August 20, 2012 Report Share Posted August 20, 2012 ok yesterday i was out cruising around in the back country roads in my 620 started heading home an started hearing a clicking loud kinda like something was hitting the drive line pulled over checked it out nothing cairer bearing is fine no bolts are lose just had it on jack stands an checked everything cant find anything wrong this is what it dose sometimes when i give it a lil gas it will stop but not all the time i let off the gas it will stop its something with pressure on the drive line that stops the noise but is not consistent the clicking slows when the truck slows down even out of gear anyone have a idea what it may be thanks Damon Quote Link to comment
Dawa Posted August 20, 2012 Report Share Posted August 20, 2012 the carrier bearing is good? how about that surrounding insulator? when does it click? my insulator is non existent but it only clicks when accelerating from a dead stop. Quote Link to comment
skyknight789990 Posted August 20, 2012 Author Report Share Posted August 20, 2012 the bearing an everything is good its hard to explain what makes it do it sometimes accelerating makes it stop sometimes deaccelerating makes it stop to but there is time nether will make it stop Quote Link to comment
banzai510(hainz) Posted August 20, 2012 Report Share Posted August 20, 2012 If really low and 5 speed the carrier bearing needs to be raised with spacers Quote Link to comment
skyknight789990 Posted August 20, 2012 Author Report Share Posted August 20, 2012 i know gone trough a few bearings i have a 4 speed an spacers tried to put a new you joint but cant get the old one out got the c clips out but the thing is rusted to the drive line so i put it all back together for now i am all most to the point of taking measurements an having a single piece drive line made Quote Link to comment
wayno Posted August 21, 2012 Report Share Posted August 21, 2012 i know gone trough a few bearings i have a 4 speed an spacers tried to put a new you joint but cant get the old one out got the c clips out but the thing is rusted to the drive line so i put it all back together for now i am all most to the point of taking measurements an having a single piece drive line made If you are to the point of having a driveline made, then just take your driveline assembly to a driveline shop and have them replace the u-joints, it will be cheaper than having a driveline made. Quote Link to comment
Tice Posted August 21, 2012 Report Share Posted August 21, 2012 ^Agree If the carrier bearing and insulation are good, then my next guess would be U-Joints. And Waynos got it right, Take it to a shop... Someone's always got a bigger Hammer... Quote Link to comment
skyknight789990 Posted August 22, 2012 Author Report Share Posted August 22, 2012 well i would if i had a press i am just scared to drive it anywhere i know someone in portland with a press that would help me for free but getting there is my problem but ill see if there is anything close to where i am Quote Link to comment
skyknight789990 Posted August 22, 2012 Author Report Share Posted August 22, 2012 got my truck down to a shop an my u joints are good but my rear end may be done for got a bent right axle an me an the guy at the shot thinks the noise is coming from there it didnt sound to good then i listened to it Quote Link to comment
Tice Posted August 23, 2012 Report Share Posted August 23, 2012 ^No Bueno. Even if the noise ISN'T coming from there... I'd get that fixed :rofl: Quote Link to comment
skyknight789990 Posted August 23, 2012 Author Report Share Posted August 23, 2012 Hopefully I'll have it fixed soon Quote Link to comment
