Duke Posted April 25, 2007 Report Share Posted April 25, 2007 Just joined and wanted to say whats up to everybody. Been a datto fan for a while and I've had my '72 for a few years. I'd say that it defineatly fits the Ratsun style...hopefully not for much longer though. Quote Link to comment
slodat Posted April 25, 2007 Report Share Posted April 25, 2007 Welcome Duke! Info on your car?? Quote Link to comment
]2eDeYe Posted April 25, 2007 Report Share Posted April 25, 2007 Nice ratsun, welcome :D Quote Link to comment
Duke Posted April 30, 2007 Author Report Share Posted April 30, 2007 Welcome Duke! Info on your car?? Some info... sss jdm L-18 with tuna can SU's, nismo header, nothing special, peppy little motor. Suspension (what I really like): Front:280zx struts with Porche 911 koni inserts, coilovers, 300# springs, custom camber/caster plates, 1 1/8" sway bar, etc... Rear:1100# springs, "special" shocks, adjustable x-member, solid x-member mounts. Alot of other stuff like custom roll bar, seat mounts, gas tank... And really crappy looking paint and body! Quote Link to comment
freekwonder Posted April 30, 2007 Report Share Posted April 30, 2007 Nice dime. Welcome aboard. Quote Link to comment
Icehouse Posted April 30, 2007 Report Share Posted April 30, 2007 Some info...sss jdm L-18 with tuna can SU's, nismo header, nothing special, peppy little motor. Suspension (what I really like): Front:280zx struts with Porche 911 koni inserts, coilovers, 300# springs, custom camber/caster plates, 1 1/8" sway bar, etc... Rear:1100# springs, "special" shocks, adjustable x-member, solid x-member mounts. Alot of other stuff like custom roll bar, seat mounts, gas tank... And really crappy looking paint and body! Suspension is my favorite to :D So for a daily how does it ride? After the big discussion on the realm it seems like high lbs springs with less dampening shouldn't be to bad on the street. I have 185 lbs springs in the front with VW inserts WAY to soft in the rear I have 300lbs coilovers, they are the T3 ones, the adjustable dampening does nothing. I think they kinda suck but I'm going to try them with lighter springs and a rear bar. I guess overall I just want to know what you would do different if anything, thanks :D I like the no bumper look to, I'm going the same route. Quote Link to comment
Duke Posted April 30, 2007 Author Report Share Posted April 30, 2007 The springs in the back aren't bad at all. I would say that I am running about the same rear wheel rate as you in the back, and I think its about perfect. I used to run a rear bar and softer springs which had about the same roll rate as the setup that I have now but the major downfall was how bad the suspension geometry is with a 510. Because of the excessive toe change, as little movement as possible (especially when cornering) was what I was going for. I have even heard of racers running solid struts in the rear to do away with any movement at all (and any toe change that this causes). I had some long messages with Keith (Bertvorogon from the realm) about this and the sugestions that he had really worked out well. I haven't auto-x yet, but I will be doing a few soon so that will help me really dial in the setup. From what I have heard from people alot of the 510 rear coilover kits are overdampened. I was considering getting some coilovers for the availablity of springs, but I ended up going the way I did because of the shocks. Plus, I don't really see the point in coilovers unless you are going to corner weight the car. So what would I do different...well, I don't really know. I'm kinda a young buck so I'm still learning...if I change anything I will let you know. I came to the setup I have now by talking to other people, so I haven't really personalized it yet. And as for the no bumper thing, I think we both fell in love with the same 510 back in the day...blue turbo rotary in sport compact car??? Quote Link to comment
Icehouse Posted April 30, 2007 Report Share Posted April 30, 2007 The springs in the back aren't bad at all. I would say that I am running about the same rear wheel rate as you in the back, and I think its about perfect. I used to run a rear bar and softer springs which had about the same roll rate as the setup that I have now but the major downfall was how bad the suspension geometry is with a 510. Because of the excessive toe change, as little movement as possible (especially when cornering) was what I was going for. I have even heard of racers running solid struts in the rear to do away with any movement at all (and any toe change that this causes). I had some long messages with Keith (Bertvorogon from the realm) about this and the sugestions that he had really worked out well. I haven't auto-x yet, but I will be doing a few soon so that will help me really dial in the setup. From what I have heard from people alot of the 510 rear coilover kits are overdampened. I was considering getting some coilovers for the availablity of springs, but I ended up going the way I did because of the shocks. Plus, I don't really see the point in coilovers unless you are going to corner weight the car. So what would I do different...well, I don't really know. I'm kinda a young buck so I'm still learning...if I change anything I will let you know. I came to the setup I have now by talking to other people, so I haven't really personalized it yet. And as for the no bumper thing, I think we both fell in love with the same 510 back in the day...blue turbo rotary in sport compact car??? That is so true, I had this as my back round for so long!! I want my 68 to have some of the same stylings :D As for the suspension I feel the same way, I've owned a few 510's but still haven't found my "personal" settings yet. I had one dime with a rear bar and it would get sideways in a second. I never autoX, from back road driving I realized I wanted rack and pinion. I guess part of it was comparing my s13 to my 510's. This really got me reading on suspension, and I guess what got me more interested in forums. I even bought some suspension books :D I couldn't understand why the steering on a basically stock s13 was so tight compared to my 510 with quite a few suspension mods. I kinda wish I would have kept the 510 cross member and done a rack setup on it, I could of fit better offset wheels that way.. better looking anyways :D I feel if I built customish suspension again (which I do have planned for my 1200 in the future) I could really build something nice :D I sure love my 510's though. I really need to get mine on the road soon!!! P.S how old are you? Quote Link to comment
Duke Posted April 30, 2007 Author Report Share Posted April 30, 2007 I would be interested to see some pics of the front crossmember setup that you made. From what I remember from the realm, you basically grafted the front crossmember of a 200sx onto a 510. In tearms of basic suspension geometry, I would have to say that the wider track would be a very beneficial thing because it allows you to run wide, high offset wheels. The bigger the lip on the wheel, the more it will wonder under breaking. But yeah, I agree, big lips look cool, thats why I have rewinds. In regards to the tightness of the 510 steering, I found that with a properly adjusted steering box, and some good steering box braces, it makes a BIG difference in the feel...not quite new car good, but way better than what it was. As for my age, I'm 21, so I guess I'm not that young. Quote Link to comment
slodat Posted April 30, 2007 Report Share Posted April 30, 2007 Hey Duke - what did it take to get the rewinds to fit in the fenders? I like them... Quote Link to comment
Duke Posted April 30, 2007 Author Report Share Posted April 30, 2007 Hey Duke - what did it take to get the rewinds to fit in the fenders? I like them... Well, to get them to fit the fenders were rolled and the rear inner fender was massaged a little. Also you need 280zx struts with camber plates. I was running about 3.5 degrees in front and an unmodified crossmember in the rear. Still with this the fronts rubbed in tight turns. FYI I am running 205-50-15 rubber, I have heard that they fit better under stock fenders with 195's To get them to fit RIGHT I have slightly flared the front fenders. By doing this I have been able to run anywhere from 2-3 degrees of camber without rubbing. In the rear I cut out half of the inner fender and made a kind of "mini-tub", if you have read the trans-am section of the how to modify book, that is basically what I copied. I also slightly flared the rear fenders and I am now able to run about 2 degrees of rear camber. Quote Link to comment
Icehouse Posted April 30, 2007 Report Share Posted April 30, 2007 Fitting wheels on a 510 is a challenge in it self. I tried the ZX arms on the rear of my dime, I heard they fit. They do but the toe seems to be way off. The shock/coilover perch is way higher, with my coilovers its still a stomper. The wheels I want are a 4/5 lug universal, they are at fairlady motors and I think they would fit perfect. If I could find the center caps they would be sick! I would love to fit 205's all the way around. Adjusting the steering box does help, on the car I had it was a little to late :( for most of the front suspension. Its funny how s12 suspension with 200,000 + on it can be better than 510 suspension with about the same amount of miles. I did basically just graft it onto a 510, through all my research I found that newer cars were basically just setup better. Like the s13 is set up like a "streetish" or "mild" 510 is setup. Thus the nice handling s13 with just drop springs. I want to build dual A arms for my next suspension project. I want to fit 225 under the front of a dime, that would be nice :D Quote Link to comment
slodat Posted April 30, 2007 Report Share Posted April 30, 2007 When I talked to Steve E about the ZXT rear control arms he told me setting them up is simply a matter of how you make your rear crossmember. So, you can move the wheel in or out, etc by where you place the mounting points. Doing a pentultimate makes this seem pretty straight forward. Quote Link to comment
Icehouse Posted May 1, 2007 Report Share Posted May 1, 2007 I was thinking the same thing, but instead I just want to buy your arms :D I will have the money Wednesday. Quote Link to comment
