Wireing not lookin so good
I'm having Wireing issues lately. Just yesterday I looked out my window at my house and saw a little smoke comming from my truck then as I walked over a ton of smoke. When I popped the hood I found one of my horns burned up because of a short caused by a split wire rubbing on a bracket. And before that my headlights quit working and it looks like the wires have been getting a little too hot in a sketchy connector someone rigged up
Does it sound like something as simple as old wires or am I having a more serious problem?
  • Replies 15
I am not sure as I dont own a 620 but that doesn't sound right unless key was in "on" position or a bad relay? Idk
Replace any (+) wires/bare connections that maybe in the same predictament.
Make sure to execute hot solder joints and heat shrink wrap/electrical tape/liquid electrical tape
Quality wiring connectors will work ok if you can't/don't solder
The horn gets constant power cause you can honk when the key is off and the fuse did blow after a bit but I think it was too hight amp might be why is got melted so much.
Might be right about the Barnes but I hope not.... I'm not an electrician so I'd rather fix what I have I guess I dunno at this point
You're forgetting the horn relay. There is battery power through the horn relay coil then to the steering wheel horn button and to ground when pushed. When energized, the relay connects power to the horn which is grounded.
Time to do some serious wire tracing.
Do you have a factory service manual?
Could a bad ground do that? Check for bare wires,wires twisted together,and anything that doesn't look 'right'.
And see if the fuses have the right rating.
oh man reading this thread is bringing back some bad memories. as far as your headlight problem goes, i don't think this could make the connector hot, BUT...
most of the electrical problems in my 620 were because of the turn signal assembly. your headlights, horn, turn signals and brake lights run through it.
the turn signal assembly on a '79 is mostly made of plastic, it is old now so it is brittle and little bits chip off. on mine the headlights only worked sometimes, turn signals only worked sometimes, etc. i rebuilt it and it worked but a month later more brittle plastic chipped off and everything stopped working again.
maybe the problem is in there somewhere.
sorry to add to the confusion, but that is my two cents.
